96 3.2TL i'm having problems with my system
Old Oct 20, 2003 | 09:43 PM
mctwist159's Avatar
Question 96 3.2TL i'm having problems with my system
my amp cuts off when i turn the bass up...i used a good ground in the bottom of my trunk..i had this same problem with the amp before this one too. could it be because i don't have a capicator? i am at a loss for ideas at this point.
Old Oct 20, 2003 | 11:11 PM
StreetEffectz's Avatar
Are you using the same sub?
Old Oct 20, 2003 | 11:19 PM
mctwist159's Avatar
nope...different sub also
Old Oct 20, 2003 | 11:30 PM
Are you running the factory headunit?
Old Oct 20, 2003 | 11:46 PM
mctwist159's Avatar
nope...i originally thought that was the problem so i got an alpine headunit..a pretty good one too and it still cuts off
Old Oct 23, 2003 | 07:11 PM
tlondubs's Avatar
There can be two reason for your problem
1. Your amp may be two small for the subs
2. Your Gain may to high or the Amp jus may jus had it time
try hooking up one sub to the amp and see what happen if it doesn't cut off then. the amp is two small.
Old Oct 23, 2003 | 10:52 PM
mctwist159's Avatar
it is hooked up to one sub though...it's hooked up to last years kicker L7 12"....next week i am buying the JL 500/1 amp, that should make a huge difference in my system
Old Oct 24, 2003 | 08:30 AM
Scott P's Avatar
Mobile Elec. Guru
granted without knowing what sub and amp you are using, it sounds like a protection circuit firing
Old Oct 28, 2003 | 09:19 PM
shag's Avatar
Do you want to sell your head unit?
Old Oct 29, 2003 | 05:31 PM
mctwist159's Avatar
who?
saberlove
Mar 11, 2021 09:29 AM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
max4swag
Sep 14, 2015 07:55 AM
brandnewcolony
Sep 12, 2015 10:39 AM
