4-channel Amp question
Old Jul 26, 2005 | 01:16 AM
glassjaw's Avatar
i had 2 12" subs hooked to a 4 channel amp in my old car. Now in my tsx i plan on putting only 1 sub and using that same 4-channel amp to power it just as a temp. Will this work without any damage to the amp or sub? Basically it will only be running that 1 sub only, nothing else.
Old Jul 26, 2005 | 08:58 AM
elduderino's Avatar
VP Electricity
A few amps say that you shouldn't run them with any channels unconnected - but very few say that.
Is your sub a dual voicecoil? If so you can run both channels.
But usually it's not a problem.
Old Jul 26, 2005 | 08:59 AM
CJams's Avatar
Guinea Pig
What kind of amp is it?
Old Jul 26, 2005 | 12:28 PM
glassjaw's Avatar
its a kicker 800.4
and the sub is only a single voice coil
Old Jul 26, 2005 | 01:18 PM
C The "S"'s Avatar
I wouldn't run an amplifier without a load on it. Why not use the other 2 channels to run the fronts?
Old Jul 26, 2005 | 07:15 PM
glassjaw's Avatar
will that be too much power? i'm using my factory speakers still
oh yea, and what about the back speakers, to me it would seem like the extra 400 watts would benefit the back speakers than the front. but i'm not to bright when it comes to audio
Old Jul 26, 2005 | 07:16 PM
dark inspire's Avatar
El Presidente
its worth a shot
Old Jul 26, 2005 | 07:50 PM
C The "S"'s Avatar
No it won't be too much power, should make the factory speakers sing. Also I wouldn't amplify the rear speakers. I would definitely amp the fronts, reason being, when you go to a concert where does the majority of the sound come from? The front, so why would you want more volume coming from the rear? Get it?
Old Jul 26, 2005 | 08:08 PM
glassjaw's Avatar
gotcha. thanks for the help!
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
