TL: 2nd Gen Aftermarket Sound Issues
I have an '03 Type S. I just installed a new head unit which is working fine. The sub is not working, but after searching the forum I did see one post mentioning an adapter needed. Can anyone confirm that? Also, I replaced the rear speakers with aftermarket components as well, but they do not sound as good as the stock ones which is suprising. Is this because of the whole Bose/preamp set up? Is there a workaround vs having to rewire the car to bypass the bose speaker setup? Please help!
Is your sub on its own pre-out?
https://acurazine.com/forums/showthr...bose+subwoofer
You will have to splice two wires and wire them up to rca's.
sorry to bring up an old post. But i replaced the stock HU with a kenwood DDX719. The sub doesn't work but i know the workaround thanks to this forum. But the speakers also sound like crap with distortion at high volumes. They also seem to have lost power and are not as loud as they were with the stock HU even when turned up all the way. Any one know why? i don't want to replace all of the speakers and add an aftermaket sub only to find that the sound quality is still crappy. please help
The stock Bose speakers are 100% pure cheap crappy garbage. That's why they put in the EQ to massage the sound and make it bright before sending it to the speakers.
Do yourself a favor and get new speakers for all 4 doors. Even cheap ones from Walmart will sound better than the Bose.
I did the opposite of you. I kept the stock head unit and changed all speakers & subwoofer, installed a 4-channel amp and a sub amp. It's a stealth system with the stock HU, has incredible sound, but it won't attract thieves.
I didn't want to overspend, but I still wanted a quality system with good bang for the buck, and room to grow in the future.
I ripped out the stock audio system except for the head unit.
This is what I got:
Hertz ECX 165 6.5" for front doors, Hertz ESK 165L 6.5" component kit for rear doors....and they are powered by 4ch amp Autotek m2000.4.
Hertz HX300 12" sub powered by Hifonics ZRX2000.1D mono amp. I bought a nice carpeted 3/4" thick mdf sub box from Sonicelectronix for $20 (can't beat that!!!)
Hifonics mx-3 sub enhancer/controller.
I also installed an Autotek equalizer where the stock CD holder was. Easy fit after a few simple cuts with the exacto knife. And it doesn't even look out of place.
The system really kicks. And I have enough amp power to expand the system in the future.
In fact, I am thinking of ways to add two 6.5" mid-bass woofers on the rear deck, and possibly a center rear speaker where the stock sub was.
![](http://i71.photobucket.com/albums/i142/victus1/IMG_2511.jpg)
This is what I got:
This is what I got:
I was thinking of just replacing the speakers and allowing them to run on the oem amp...I know the speakers are 2 ohms so I will make sure that the new ones are the same but will my sound quality improve? And will they be able to keep up with the jl12w6 sub I just got? Don't want to put the speakers in to find that they still sound like crap......thoughts?
You won't be happy because the stock head unit will not have enough power to drive your new speakers. And if you keep the stock EQ (hidden behind the HU) it will make your speakers sound like crap because it cuts and massages frequencies to compensate for the crap oem speakers.
I dunno what to tell ya.....try it, if you don't like it, then you can always get a good 4ch amp with 4 x 75W for around $120 to drive your new speakers. Then you can upgrade your sub later on when you have more funds.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
trinikidcl
09-04-2015 12:56 AM
