2400 watts!
2400 watts!
for my subs im gonna be running something like 2400 watts, and i am doing a self install.
I was going to drop on 1/0 gauge wires, does this require any special wiring, or will it fit in the same spaces as a 4 gauge wire?
also, should i get a completely seperate second battery with isolator, or just replace my stock battery with an optima?
final thing: can store bought boxes handle the audiobahn awq series version 8 flame subs, or are they too powerful. If i were to make my own box, how can i pull off the astroboy look?
East Coast Boost.!
That is a lot of power, be prepared for rattle. I have 1000 watts and i don't even turn it up all the way. One ime i did and i could feel the car struggling to stay in one piece. Good luck with that.
Originally posted by brianlin87
thas a very impressive setup, i hope you plan on dynomatting ur whole car rather than allowing it to sound like ur car is falling apart...
Only Broke CL member
i am gonna be running 2200 watts for subs and 800 for speakers and i have to dynamat my whole car hey you live in pv right well tell me when u are doing ur system i install
Re: 2400 watts!
3/4 inch MDF if you are going to build a box.
Honkey
I have 1/0 guage wiring going in my car. I have one optima up front under the hood, with another optima in the trunk with an isolator. I'm running just shy of 3000watts, so we're in the same ballpark. I have the 1/o going to a distribution block in the rear that breaks off into 4 guage for the amps. I have yet to get everything up and running, but from what I'm told, my setup should work out okay. My only concern is I may have to upgrade my alternator. Good Luck.
-Aaron
PS, if you want an install like astroboy's, you better start saving...$20,000 will get you started.
-Aaron
pistacio
09-26-2015 09:45 AM
Medinak12
09-23-2015 07:11 PM
Bass Mechanic
05-01-2002 12:22 PM
