2002 tls sub
Old May 6, 2005 | 12:19 PM
DzTL-S's Avatar
2002 tls sub
what size is the bose sub?and if i add a different sub to save trunk space?
Old May 6, 2005 | 02:18 PM
dark inspire's Avatar
El Presidente
welcome! the stock sub is about 9". Do you want to add another sub? Most people have had the best luck with buying and aftemarket sub and putting it in the trunk. What are you looking for? Sound Quality, or Volume?
Old May 6, 2005 | 03:51 PM
DzTL-S's Avatar
no just something with a little more kick maybe try to fit a 10 in that spot and a amp i dont want to put a box in the trunk.weight down the car will that be hard to make the 10 fit?
Old May 6, 2005 | 04:04 PM
El Presidente
well it is possible, but you have to keep in mind hte torison bar for the trunklid, that comes in the way.
Old May 6, 2005 | 04:22 PM
DzTL-S's Avatar
you are right. guess I will need to see what other options there is .will look at trunk today
THANKS
Old May 6, 2005 | 07:44 PM
ou sig's Avatar
Boomer SOONER
you can put a single 10, box and amp and it wont weigh much at all - but will be very worth it for the better sound.
Old May 6, 2005 | 07:48 PM
elduderino's Avatar
VP Electricity
A sub in a box will give you better sound - absolutely.
But you can also go with an 8" by Vifa or Peerless in the OEM location, and an amp that has a subsonic filter to take out ultra-low sub-bass that an 8" freeair just won't play.
Probably cost you about $300 for parts. I'd use a DLS amp that's about 200W mono in that situation since it has a tunable subsonic filter.
TypeS860
Jan 10, 2026 11:11 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
steve
Sep 30, 2015 09:23 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
