2002 tls sub
welcome! the stock sub is about 9". Do you want to add another sub? Most people have had the best luck with buying and aftemarket sub and putting it in the trunk. What are you looking for? Sound Quality, or Volume?
Originally Posted by DzTL-S
no just something with a little more kick maybe try to fit a 10 in that spot and a amp i dont want to put a box in the trunk.weight down the car will that be hard to make the 10 fit?
A sub in a box will give you better sound - absolutely.
But you can also go with an 8" by Vifa or Peerless in the OEM location, and an amp that has a subsonic filter to take out ultra-low sub-bass that an 8" freeair just won't play.
Probably cost you about $300 for parts. I'd use a DLS amp that's about 200W mono in that situation since it has a tunable subsonic filter.
xsilverhawkx
09-28-2015 06:51 PM
