20 pin connector question
Old Jan 25, 2005 | 11:08 AM
foolioness's Avatar
Professional SLACKER
Question 20 pin connector question
Are the 20 pin connector pin config the same on the radio and amp end?
Thanks group.
Old Jan 25, 2005 | 11:31 AM
elduderino's Avatar
VP Electricity
WHAT KIND OF CAR?
ON the TSX, the 20-pin is the Amp OP to the speaks, and the 14-pin is the Amp input from the HU - so, no.
Old Jan 25, 2005 | 12:57 PM
foolioness's Avatar
I noticed that there is one 20 pin connector on the HU and one on the amp.
Are the pin config the same on it? Sorry for the confusion.
slo007's Avatar
Master in Science
Funny. His sig doesn't list the car he has...
Old Jan 25, 2005 | 12:59 PM
slo007's Avatar
Master in Science
There's a chart somewhere in here that tells you what wire is what. What are you trying to accomplish?
Old Jan 25, 2005 | 02:02 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I don't think they are the same. I think he's trying to install the Parrot Bluetooth kit.
I'm thinking he is trying to splice into the speakers inputs going into the amp so that the kit can mute the car stereo.
Old Jan 25, 2005 | 02:57 PM
foolioness's Avatar
That is exactly what I'm trying to do. Thank you TSX536.
The pin diagram that I got from this forum is for the radio unit.
I tried to look all over the forum and online to get confirmation but no luck.
I don't wanna get electricuted while splicing and dicing this sucker.
Old Jan 25, 2005 | 03:08 PM
elduderino's Avatar
VP Electricity
With 12V?
There are amp wiring pinouts all over the place... check post #3 here:
https://acurazine.com/forums/showthr...ht=TSX+diagram
Old Jan 25, 2005 | 03:15 PM
foolioness's Avatar
Thank you el...... Really appreciate it.
Old Jan 25, 2005 | 04:37 PM
slo007's Avatar
Master in Science
Originally Posted by elduderino
With 12V?
That's the one I was talking about. Too lazy to search for it... I have a copy on my PC.
Old Mar 14, 2005 | 12:35 AM
xaznperswaesonx's Avatar
from that diagram .. whats the shielding wire for??? and the Driver's (-) and (+) makes up the front left channel RCA if an RCA is connected to it?
Old Mar 14, 2005 | 12:39 AM
elduderino's Avatar
VP Electricity
They wrapped an extra noise shield around all four of the signal pairs. According to the manual this shield is only grounded at the amp end (standard noise shield practice - make the ground the drain at the downstream).
In the installs I've done it doesn't matter if the extra shield is grounded or not. Theoretically it should be taken to chassis ground, but it doesn't hurt anything if it isn't, as far as I can tell. The times there have been noise grounding those wires did not help at all, and lifting the ground did not ADD noise.
Old Mar 14, 2005 | 12:43 AM
so let me get this straight ..
The two shielding wires aren't really useful
Driver's (-) and (+) makes up Front Left RCA
Passenger's (-) and (+) makes up Front Right RCA
Right Rear's (-) and (+) makes up Right Rear RCA
Left Rear's (-) and (+) makes up Left Rear RCA
B7-YEL/GRN-Audio Unit makes up the Remote Turn on wire
Is that right?
Old Mar 14, 2005 | 12:57 AM
elduderino's Avatar
VP Electricity
1) As the diagram clearly shows, there are four shielding wires, not two.
2) I was going to say that you don't need me to tell you what the diagram says...
honestly, if you use signal (+) for the center, use signal (-) for the RCA shield, and either ground or float the factory shield wires, you're fine. You can read the diagram as well as I can, you can figure out L and R and F and R as well as I can, read it, learn it, love it.
Let us know how it goes.
Old Mar 14, 2005 | 01:14 AM
oh ok .. haha for a moment there .. the way i read it .. i was like + for center .. where the center at on the diagram .. i swear .. communication can be such a pain sometimes ..
but hey .. thanks for the clarification eld
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
