1/0 AWG Power Wire
1/0 AWG Power Wire
Is anyone running 1/0 AWG Power wire from battery to the Trunk? If so, where did you go thru the firewall and was is difficult to route the wire thru the side of the car, like under the door pillars, etc? Should I just get the 4 gauge? Planning on running 3 alpine amps.
2000 Watts??!!? I had checked the wire gauge table vs length and wattage and I thought it had to be something lower.
http://users.bestweb.net/~tomh/Car/C...0Capacity.html
In the firewall there is something just above the gas pedal, you should see it. yield2k helped me find it
http://streetwires.com/products/wireGauge.cfm
1/0 gauge
I'm running 1/0 gauge and have 1400watts rms.. They had to drill a hole through the firewall. It seems to be fine under the interior once you get that rope in there.
My Memphis Belle will put out 1,400 watts in the current config. Although, I never push it that hard. I have 4 awg from the battery straight into the amp. I never have any problems with it.
Maybe drill the hole bigger for the gromet above the gas peddle? Hopefully I can get a drill in there. This sucks b/c I don't think I can return this wire.
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
