TSX: '09 with Tech: XM to Sirius?
Old Aug 26, 2009 | 01:09 PM
juacura's Avatar
3rd Gear
Hello all,
I have a 2009 Acura TSX with the Tech Package. I would like to convert the built in XM system to be a Sirius system. Anyone know the best way I can do this?
Want to switch to Sirius b/c I have a life-time account and don't want to buy a XM account on top of that. I called both XM and Sirius and got no help. Basically they said that the companies are technically merged, but the accounts are entirely separate.
Best scenario I can imagine is some way to swap out the brains of the tech package so I can use the factory display and antenna...possible?
Thanks!
Old Aug 26, 2009 | 02:32 PM
RPJ28's Avatar
DEI makes a piece that works for Honda/Acura. It doesn't list the 09 TSX or even the 08 but I would probably still try it. I've done Ipod adapters that didn't list the 08+ Accord (same wiring as 09 TSX) and it still worked. I haven't pulled the stock TSX unit out yet so I don't know if the XM plug is still the same.. I've done this conversion on a new civic before and it worked pretty good except you did need the seperate antenna. I would probably buy it from somewhere that has a decent retun policy in case it doesnt work......
http://www.logjamelectronics.com/directhonsc1.html
Old Aug 26, 2009 | 03:29 PM
juacura's Avatar
3rd Gear
I found a site for the HON SC1 that says it's not compatible with the Acura Tech Package....is that true?
Thanks for the help!
Old Aug 26, 2009 | 07:14 PM
RPJ28's Avatar
It could be true, but I wouldn't really know unless I had the radio removed to see if the plugs are the same. And even then, I would just have to test it to make sure everything stays functional. I wouldn't be suprised either way if it worked or didn't worked to be honest...
Old Oct 23, 2009 | 07:07 PM
kaboytes's Avatar
I bought the HON-SC1 and SC-C1 and the wire harness did not fit the back of the radio. I have a 2009 TSX Tech Pkg. If you find something that works, please let me know.
Thanks!
Old Oct 26, 2009 | 10:01 AM
juacura's Avatar
3rd Gear
I found a shop that looked at the components and said they can make the change for about $450. I got some details at the time, but forget the specifics on the exact plan.
I'm thinking about having this done soon, so I'll check on what the details and post again.
Old Jan 6, 2010 | 03:55 PM
n2another's Avatar
3rd Gear
I bought the HON SC1 kit but can't find the XM tuner on the 09....anyone know where its located. I don't have the Tech package.
Old Jan 8, 2010 | 12:46 PM
Crouching's Avatar
MmmBAAAA
XM and Sirius are the same and have the same exact channels now
Old Jan 8, 2010 | 02:30 PM
mercman's Avatar
It is behind the right rear seat side bolster.
Jeff
koju01
ILX Audio, Bluetooth, Electronics & Navigation
Dec 14, 2015 02:17 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
