TL: 02 typeS amp for speakers?
is there a stock amp for the stock speakers or is that just for the stock subwoofer. how many watts is the amp for the speakers. what is the best speakers i can get that do not need a new amp if i have a headunit that pushes 50watts per speaker.
is there room to fit 7 inch speakers? http://www.amazon.com/Rockford-Fosga...5&sr=8-1-fkmr1
There is no stock amp for the speakers, only the sub amp behind the rear seat on the passenger side. As for the speakers they will fit, but I don't think the speakers you had the link to would really sound any better. The highs will sound better since they have actual tweeters, but over all I would expect the fosgates to fall behind.
Most speakers will be fine running off power from a after market h/u that are priced around $100 or less. Once you go above that is when you start getting into speakers that are made to be amplified TYPICALLY, this is not always true but a simple way to look at it.
there should be an amp for speakers to, i had an 01 CL, it didn't have a sub, but all of my speakers ran through a factory amp that was located in the trunk on the passenger side behind the carpeting....
fostgates
i have this headunit http://www.bornrich.org/entry/pionee...od-connection/
Just because the RMS is higher doesn't mean they are going to sound better. I'm not saying that the Bose speakers are great I just don't think I would spend the money to get speakers that won't be noticeably better. I could be wrong since I don't have any experience with these speakers. Based off of other speakers in this price range I wouldn't expect much from them.
B A N N E D
as far as the stock amp for the midranges and such, everything is inside the radio itself, only the sub itself uses that amp behind the rear seat (and a builtin headunit amp is never going to supply enough power to those 40 rms speakers to ever push them beyond there capactity, you need an external amp for that)
and 7" speaker LMFAO, you can fit anything in there if you trim enough metal away (i still had to trim with my 6" ones
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
Pegon95
09-15-2015 01:54 PM
