CL: 01 CL-P amp wiring help
Old Feb 27, 2013 | 01:37 PM
sssje60's Avatar
6th Gear
Question 01 CL-P amp wiring help
So im trying to add a amp to my 01 CL-P.
Where is a good place to pass the power wire through the firewall?
I do not have a after market deck, I have the factory nav unit.
Which fuse can i splice to hook up the remote line? i see a fuse box on the passenger side dash. Can i use he radio power fuse?
Old Mar 4, 2013 | 02:02 PM
3510 plus mine's Avatar
5th Gear
Look on the drivers side above the pedals. U will need to remove a piece of the
Padding. It's pre cut. There's a rubber grommet, remove it, make proper size hole and run wire thru there.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
