[TSX] Securing amp rack Q
Old Mar 5, 2006 | 06:32 PM
Spoon's Avatar
Anyone have a good idea/actual method for securing an amp rack in the area of the trunk above the gas tank?
Old Mar 6, 2006 | 08:24 AM
defjukie's Avatar
I'm interested in doing this too
Old Mar 6, 2006 | 12:04 PM
zazen721's Avatar
where'd my wheels go?!
bumpity bump bump... i cannot stand having my amp attached to my backseat...
Old Mar 7, 2006 | 10:22 AM
Spoon's Avatar
No good ideas?
Old Mar 7, 2006 | 10:28 AM
jpswanberg's Avatar
mdf on the floor, attach amp(s) above or through the floor.
Old Mar 7, 2006 | 10:57 AM
defjukie's Avatar
I think he means on the wall of the trunk. So that the minimum amount of trunk space is wasted.
If you put something on the floor, it's gonna be in the way constantly.
Old Mar 7, 2006 | 12:50 PM
Spoon's Avatar
Yeah, the only problem with that is the gas tank is directly under the floor. That was why I was asking, I'm curious as to where/how specifically people have attached it - i.e. where to drill without hitting something critical.
Old Mar 7, 2006 | 02:29 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I'm assuming that your back seats fold down, which mine don't. What I'm doing is mounting MDF behind my carpet in between the carpet and seats and screwing the mdf into the seat bracket and the amps into the mdf through the carpet. If your seats don't fold down, that would be an option. If your seats fold down, maybe you want to mount under the trunk floor back behind the spare and away from the gas tank Then the only thing you might have to do is get a fan to remove heat from under there. Just a thought.
Old Mar 7, 2006 | 03:20 PM
Spoon's Avatar
If I'm reading you right, by "back behind the spare" you mean between the spare tire well and the back seats? If so, that's where the gas tank is located. Thanks for the reply though.
Someone with a TSX must have put a amp or two in this location and mounted it securely...
Old Mar 7, 2006 | 05:44 PM
zazen721's Avatar
i know some amps fit under the passenger seat... not mine.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
