2017 ILX Oil Leak
Old 09-08-2018, 03:02 PM
Mia DuBose Pettway's Avatar
2017 ILX Oil Leak
Have anybody had an oil leak.... Was told it's caused by somebody driving over something or over a hole damaging the oil filter?
Old 09-10-2018, 11:09 AM
davidlstewart's Avatar
I currently have one and my dealer can't trace the source was thought to be oil then trans I work at an acura dealer and am looking everytime with them and we can't trace it back somewhere pretty weird.
Old 09-10-2018, 11:11 AM
Received 16,260 Likes on 11,971 Posts
well, what is it exactly????
if it is indeed physical damage, then the driver is at fault...
if it's something else, then it could be any sort of seals failing, an incompetent mechanic, etc. etc...
someone will need to verify what exactly is damaged.
Old 09-10-2018, 12:26 PM
visi_d's Avatar
https://acurazine.com/forums/ilx-pro...l-leak-972853/
Old 09-10-2018, 12:31 PM
How can it be the drivers fault if the cover protects the oil filter. I can't imagine the filter to be openly exposed. Its unclear of what's the physical damage, but the car is a 2017 with @ 20k and certified. This happened within 4 days of ownership.......no damage noticable undercarriage as the tow driver couldn't see where because of splash cover intact.
Old 09-10-2018, 12:34 PM
I'm not accusing you!
I'm just going off what your post said...your dealership said it looked like physical damage. and UNTIL you can get someone to verify what is leaking, we're just going by he said she said.
Old 09-10-2018, 01:53 PM
visi_d's Avatar
Yea, your post is not very specific of your oil leak problem. Hard to give you any advice based on what youre telling us. Is it a severe leak? Small leak? Something happened to cause it. Physical damage to cause an oil leak would be very visible and easy to spot. The ILX is a pretty well built car in my opinion and you dont hear much of leaks randomly accruing unless its something very random problem caused by human error.
Old 09-19-2018, 10:31 PM
skarface's Avatar
2014 ILX with oil leaks. First oil pan resealed with hondabond. Then 6000 miles later they say intake cover is leaking and needs to be resealed. Another mechanic mentioned multiple leaks may be from a bad PCV valve.
GOOSEej
11-01-2018 11:17 PM
visi_d
ILX Problems & Fixes
08-30-2018 09:34 AM
cruiserchuck
09-11-2016 05:28 PM
ck123
ILX
01-06-2015 10:36 AM
fabrizzio71
1G CL Problems & Fixes
12-16-2012 04:50 PM
Quick Reply: 2017 ILX Oil Leak
