Power steering pump whine
Old 04-07-2018, 07:12 PM
bbsitum's Avatar
In August 2017 I did replace that line that go from power steering pump to steering rack. After that I have whining from power steering pump area. So I replaced first one even it had good power. Second I brought from junkyard, look old and was noisy and weak power. Third one, from junkyard look almost new and do not make so much noise but whining is still there especially in cold weather. I can live with it but why not fix if is possible. Noise exist when car in in park and than more when I turn wheels. I guess is not rack as I have noise when is car in P too. Do it worth change O rings like in G3 Acuras? https://acurazine.com/forums/3g-tl-p...ne-fix-754586/ . Strange that I have same problem with all 3 pumps with less or more noise.
Old 04-08-2018, 09:19 AM
Chojun's Avatar
It's possible that you damaged the o-ring on your high pressure hose when you installed it (especially if it's been installed multiple times).
I'd also check to be sure the belt is tensioned properly.
A buzz is characteristic of air in the system.
A whine may be a bad pump bearing or too-tight belt. A scream is a bad or too-loose belt.
bbsitum (04-08-2018)
Old 04-13-2018, 12:13 PM
bbsitum's Avatar
Well it is good chance that is O ring at power steering hose.
at 2:00. It should not be O ring at hose that go to canister as I replaced 3 pumps and same problem and that O ring is part of pump. So it is good chance that I replaced first pump for nothing. In August I replaced power steering hose https://www.carparts.com/details/Acura/TL/Replacement/Power_Steering_Hose/2003/REPA289902.html?TID=gglpla&origin=pla&gclid=Cj0KCQ jwqsHWBRDsARIsALPWMEMDa8n09Wt62sHiP2mF3kUj2m4qvTfA-BJWOvUsx2efUePIt5lW-r8aAtCiEALw_wcB&gclsrc=aw.ds
Of course old O ring is at hose and I didn't replace it. Hose is from junkyard. Right away I had wining noise after that replacement. I blamed power steering pump and replaced it for one that is really bad, I had to use much more force to turn wheel. Then I brought 3th from junkyard that look like new but car has same noise. I guess is that O ring but will have to go to buy it from dealer. It seem that O ring wining is common problems at Hondas/Acuras https://acurazine.com/forums/3g-tl-p...g-pump-848211/. Would do better to investigate before blame PSP.
Old 04-13-2018, 12:18 PM
Received 8,584 Likes on 6,630 Posts
Yeah a quick search of this site could have told you that
https://www.google.com/search?q=site...firefox-b-1-ab
Old 04-13-2018, 12:20 PM
bbsitum's Avatar
Well it is multiple treads about it in G3, we do not have much in G2 about it. I hope this tread will help someone. At last to think about O rings too. There is big thread about it in G3 https://acurazine.com/forums/3g-tl-p...ne-fix-754586/ . I blame my higher intelligence this morning at sauerkraut that I eat 3 days in row. I guess Germans have such good engineering because they live at sauerkraut for generations.
Old 05-08-2018, 07:29 PM
bbsitum's Avatar
Replaced both power steering pump o rings and wine is still there. I will check hoses too. I have air bubbles in reservoir but they are not small and foaming then usually two big bubbles that cower entire surface of reservoir. https://acurazine.com/forums/3g-tl-p...ervoir-797346/ Guy had same situation and of course didn't bother to post back.
Old 05-08-2018, 07:58 PM
bbsitum's Avatar
So I went through a dose treads about same issue. Nobody ever post how he solve problem. What is wrong with this f planet.
Old 05-09-2018, 09:45 AM
fog80's Avatar
Interesting I have the same issue in my 2g TLS when its freezing outside.
Old 05-16-2018, 08:51 AM
bbsitum's Avatar
Well replaced intake hose (reservoir to pump) with better one from junkyard. Then replaced rubber o-ring at power steering pressure switch. Same whining. Will do again upper O ring at pump because I replaced it before with some non original (little bigger). But chance that will it fix problem are same like win power ball. So I guess will have to live with it. Most likely now is that is something wrong with power hose, some very small hole or so that allow air in. But no way I would replace it at random.
Old 05-16-2018, 01:18 PM
Chojun's Avatar
When the engine is running, do you notice any small bubbles getting into the reservoir? Are there any leaks in the rack or the rack valve body (at the steering column), or any other P/S lines?
Old 09-17-2018, 06:34 PM
bbsitum's Avatar
Did bring vacuum pump to do vacuum bleeding. https://www.walmart.com/ip/2-In-1-Brake-Bleeder-Vacuum-Pump-Gauge-Test-Kit/754723265?wmlspartner=wlpa&selectedSellerId=529&ad id=22222222227086785069&wmlspartner=wmtlabs&wl0=&w l1=g&wl2=c&wl3=200896202135&wl4=pla-324875424146&wl5=9019674&wl6=&wl7=&wl8=&wl9=pla&wl 10=112354406&wl11=online&wl12=754723265&wl13=&veh= sem It didn't help. At last I know problem is not in air in lines. Probably will bring 4. pump. Of course I had to do special fitting for power steering reservoir from rubber stopper and barbed brass fitting. No I never saw bubbles in reservoir. So you guys can know if not bubbles in reservoir it is not air in lines.
Old 09-17-2018, 06:57 PM
bbsitum's Avatar
This is what I did.
. My vacuum pressure hold excellent. So it is handy tool that can say to you if is air come in system.
Old 12-17-2018, 12:46 AM
bbsitum's Avatar
Well my pump is good enough now. What happened, I guess, is that pump get rid of air in line through time. It is probably why nobody post back. It get good enough over time and people simple forget about it.
Old 03-20-2021, 11:52 AM
bbsitum's Avatar
This problem is solved with new pressure hose. Old one didn't have enough of pipe diameter hence was whining. As Whitetiger 5 said to me. So there is NOT problem with air in lines than to small diameter of line. Sunsong make zero whining form first moment when installed.
whitetiger5 (03-20-2021)
Old 03-22-2021, 12:34 PM
bbsitum's Avatar
After a few days Sunsong definitely make zero whining and that after I didn't do any sort of bleeding. It make completely different driving experience for me. I do not know who build first one as I did brought it from junkyard but imagine clowns didn't even check if theirs pressure hose actually work properly at Acura tl 2g. What a horse sh company.
Old 03-22-2021, 12:59 PM
whitetiger5's Avatar
Old 03-25-2021, 09:08 AM
bbsitum's Avatar
https://acurazine.com/forums/second-...-whine-968753/ It is not power steering pump than hose to thin, as Whitetiger said. It can be that that pump is whining but it is because hose is to tough for it. About bolt. Center punch and drills with left swing for bolt out. If is damage to threads done just do new threads. Routine job.
whitetiger5 (03-25-2021)
Old 03-25-2021, 11:48 AM
They should hope it's NOT the hose making the whine...if it's noticeably whining more than likely that inlet o ring.
The hose whine is hard to notice over time (usually you notice it only after you change the hose) and when turning the wheels..
@bbsitum hoping that still describes what you noticed with those aftermarket hoses you tried.
Old 03-25-2021, 12:00 PM
bbsitum's Avatar
No first hose was very noisy. I agree that can be o rings in his case but if is not air bubbles in reservoir it is big chance it is hose. That said I would try o rings to first no matter what.
Old 03-28-2021, 08:06 AM
bbsitum's Avatar
#17 obviously I wanted to post in another tread and somehow missed it.
MLopez
1G TSX Problems & Fixes
12-31-2013 09:09 AM
nighthawk203
01-03-2013 09:07 AM
TL260PLS
02-14-2011 05:58 PM
StYLeZz101
12-17-2006 11:44 PM
Quick Reply: Power steering pump whine
