My Build Thread - bordering on more BS! 56K Beware
Old 10-16-2011, 02:34 PM
  #1761
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,173 Likes on 4,822 Posts
Lower control arms were OEM. The sway bar bushings were OEM. The end links were MOOG. The radius rod bushings were Energy Suspension and the axles are GSP.
civicdrivr is online now
Old 10-20-2011, 05:04 PM
  #1762
Received 1,750 Likes on 1,404 Posts
civicdrivr, if sometime in the future you find yourself in the vicinity of your spare LCA's, could you measure the length of the inner and outer OEM sleaves on the bushings?
Those numbers would help advance the discussion, on the thread below, as to the feasability of the ES bushing sets that may be compatable with the CL-S6.
https://acurazine.com/forums/2g-cl-2001-2003-50/front-lower-arm-bushing-compatability-possibility-830344/
Set# Bushing "A" Supplied Sleeve
16-3106 2294 15.10.224.39 (.750”O.D. X .480”I.D. X 2.225”)
16-3110 2306 15.10.302.39 (.750”O.D. X .480”I.D. X 2.040”)
Set # Bushing "A" Supplied Sleeve Size
16-8102 2272 15.10.245.39 .750” x .480” x 1.960”
16-8106 2295 15.10.302.39 .750” x .480” x 2.040”
Thanks!
zeta is offline
Old 10-20-2011, 06:44 PM
  #1763
civicdrivr's Avatar
I was planning on it
They should still be at Pauls. I forgot a box of parts, including my new side mount that doesnt fit.
Old 10-20-2011, 07:01 PM
  #1764
BANNED
NVA-AV6's Avatar
Box, what box, I don't see any box............
NVA-AV6 is offline
Old 10-21-2011, 05:30 PM
  #1765
civicdrivr's Avatar
It was a relatively small box. I tossed the old front and rear mount and the new side mount into it. I forgot to grab it when I left and remember when I was an hour away. I think I texted you about it and the battery
Old 10-22-2011, 05:59 AM
  #1766
BANNED
NVA-AV6's Avatar
Yes, jst being a smart azz morg,
NVA-AV6 is offline
Old 10-22-2011, 04:17 PM
  #1767
civicdrivr's Avatar
You scared me there for a minute.
Old 11-10-2011, 10:03 AM
  #1768
civicdrivr's Avatar
Small update:
- The CR-Kais are gone. I sold them to a member on here, but theyre not going onto an Acura. Im currently on the winter tires. In 50*+ weather they are just too soft and suck in the corners. Im probably tossing the 19s back on the car this weekend.
- I had a bit of a scare with the new tranny. I saw moisture on the diff housing and tried to track down where the leak was coming from. Couldnt see anywhere on the housing that it could have come from. Turns out my FPR gauge is leaking fluid
- Speaking of the transmission, Ive got about 2,300 miles on it so far and its shifting great. I placed an order for some more GM Syncromesh, so once that comes in Ill swap out the fluid. Currently there is Pennzoil Syncromesh, but I want the friction modified stuff.
- Headlight plans changed once again. What I really want to do is above my skillset and way too time consuming to get the way I want it. So Im going with the backup plans. I want them done this weekend. Im off tomorrow and I plan on being in the garage all day getting them done. I just need to pick up some paint after work. Its looking like the last big meet of the year is this Sunday, so I want to freshen things up a bit.
And yes, I still plan on doing a Build Thread V3.0, I just havent had the time to compile all the informative posts and lay it all out in an easy to follow timeline.
Old 11-12-2011, 02:36 AM
  #1769
Baller of Uni
CLassy02's Avatar
Can't wait to see what changes over the weekend dude.
CLassy02 is offline
Old 11-12-2011, 07:05 AM
  #1770
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,790 Likes on 1,244 Posts
Can't wait for My Build Thread At the intersection of Info & BS!
e30cabrio is offline
Old 11-12-2011, 08:42 AM
  #1771
MD03CL-S's Avatar
^^ so true
MD03CL-S is offline
Old 11-12-2011, 04:36 PM
  #1772
civicdrivr's Avatar
Its coming....
The lights are coming along. The shrouds are built, everything is trimmed, and the projectors are modded [slightly]. Im just battling the weather right now. Last night I tried painting the reflectors and shrouds but it was 29* outside and about 40* in my garage, so the paint wasnt setting correctly. I sprayed them today outside since it was in the 50s but it was windy as hell and kept finding specs of dirt/dust in the paint
I pulled them into the garage and sprayed them there. And proceeded to kill off some brain cells from the fumes Right now Im letting the paint set for about 2-3 hours (and come down from this chemical high) so I can tape off the shrouds and lay down the other color.
It sounds like Im close to completion, but thats far from the truth. There are a few other things I need to do too, and they are time consuming
Old 11-12-2011, 04:40 PM
  #1773
e30cabrio's Avatar
Does the woman in your avi have the virus in your sig?
Old 11-12-2011, 04:50 PM
  #1774
civicdrivr's Avatar
Yes.
Its a brilliant virus.
Old 11-13-2011, 02:07 AM
  #1775
03 acura cl type s
rush's Avatar
Dibs on headlights
rush is offline
Old 11-14-2011, 09:39 PM
  #1776
civicdrivr's Avatar
Fuck it. The paint is pissing me off. Im going to take a few hours before work in the morning to try to get it nice and smooth. Heres a teaser:
Once I get the paint issue straightened out, Im going to remount the projectors and shrouds onto the buckets and let them air out for a week while Im on the west coast. Once I get back Ill get the lights all sealed up and back on the car. Ill also have a few more mods to show you guys
Old 11-14-2011, 09:56 PM
  #1777
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
Ooooo la la
CLtotheTL32 is offline
Old 11-15-2011, 10:16 AM
  #1778
Rejckt's Avatar
Small update:
Rejckt is offline
Old 11-15-2011, 10:26 AM
  #1779
StreetKA's Avatar
Is it RX7 ? Nice !
StreetKA is offline
Old 11-15-2011, 11:41 AM
  #1780
civicdrivr's Avatar
Old 11-16-2011, 03:46 AM
  #1781
03 acura cl type s
rush's Avatar
rush is offline
Old 12-03-2011, 01:04 PM
  #1782
civicdrivr's Avatar
Mods, you can lock this up.
Old 12-03-2011, 01:05 PM
  #1783
e30cabrio's Avatar
Porque???
Old 12-03-2011, 01:11 PM
  #1784
civicdrivr's Avatar
I think you spelled pork wrong.
Old 12-03-2011, 01:12 PM
  #1785
e30cabrio's Avatar
It's why in Spanish.
Old 12-03-2011, 01:19 PM
  #1786
StreetKA's Avatar
No, i think e30 just called you pork.
StreetKA is offline
Old 12-03-2011, 01:21 PM
  #1787
civicdrivr's Avatar
Old 12-03-2011, 02:10 PM
  #1788
e30cabrio's Avatar
Nope thats
Attached Thumbnails My Build Thread - bordering on more BS! 56K Beware-premium-polska-kielbasa-sausage-16-oz_medium.jpg
Old 12-03-2011, 08:48 PM
  #1789
Baller of Uni
CLassy02's Avatar
Lol @ Morgans avatar.
CLassy02 is offline
Old 12-03-2011, 08:53 PM
  #1790
civicdrivr's Avatar
Old 12-03-2011, 09:45 PM
  #1791
StreetKA's Avatar
lol Stephan !!
StreetKA is offline
MrHeeltoe
20
02-23-2023 01:54 PM
xsilverhawkx
10-05-2015 11:00 AM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: My Build Thread - bordering on more BS! 56K Beware
