StreetKa's CL Type S 03 6 speed Dyno
Old 12-15-2010, 02:24 PM
  #81
B A N N E D
friesm2000's Avatar
Originally Posted by CH46ESeaKnight
Looks like your standard run of the mill hollow cam shaft to me.
and then you put another shaft inside of that... that would say just control the exhaust lobes or something (you put slots in the outer one, so the exhaust lobes can reach the inner shaft, and then "pin" them in place)
as far as durability , no idea how long it would actually last, let alone the torsional ridgidity would not be so good (not so bad with the length of our shafts because it only has to go 3 cylinders, but something like an inline 6 gl with that lol)
Old 12-15-2010, 05:15 PM
  #82
B A N N E D
friesm2000's Avatar
actually forget my last post... already been done (but then again it is a proven concept )
http://www.youtube.com/watch?v=0uiDmcPEekc
Old 12-15-2010, 05:46 PM
  #83
CH46ESeaKnight's Avatar
^ That's pretty bad ass! See in the graph they are adjusting the overlap. I imagine that could be very benificial in a turbo set up! If you had some way of contraoling that you could have a pretty chopy idle when wanted. I'd love to have that kind of control!
Old 12-16-2010, 01:18 PM
  #84
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
Pfft, just get pneumatic valves
Old 01-04-2011, 04:29 PM
  #85
5th Gear
6spdonly's Avatar
Thanks for posting the dyno clip... Do you plan to dyno again?
Old 01-04-2011, 05:54 PM
  #86
StreetKA's Avatar
Probably once i get second motor im gonna PnP heads intake runners and TB also i need to finish my 4" intake then i think i dyno it again. We'll see.
Old 01-21-2011, 01:39 PM
  #87
5th Gear
6spdonly's Avatar
I need to throw mine on the dyno. Maybe this summer???
New setup should be nice. Good Luck and im sure you will want to dyno again after you finish her up.
Old 03-15-2011, 10:58 PM
  #88
AARONSredTYPE-S's Avatar
Originally Posted by StreetKA
so today i wanted to install p2r IM thermo spacer so i got around to do it and i saw this...
i was like OMFG thats alot of oil and i acutally did seafoam aprox month ago...
i cleaned the whole intake manifold took it apart (plenums as well) and used a porting kit matched and grined all the sharp edges and imprefections thats how it looks now
also i did coolant bypass mod as for thermo spacer it seems to be working very well... after a 30 min spirit drive it was pretty cool
the throtle response is crazy now... the car felt sluggish for last couple of weeks now its like day n night it sounds great car beg you to floor it vtec sounds incredible i missed it.
mine was way worse than yours. plus i wasnt able to polish anything, the scraping and cleaning alone took me 2 hours...
good job btw
Old 06-24-2011, 07:08 AM
  #89
StreetKA's Avatar
im going to a dyno july 10th with few things fixed and few new mods but def not done yet
Old 06-24-2011, 07:35 AM
  #90
CANT WAIT TO SEE YOUR NEW DYNO.
Mine will be up soon so i can see where im at as well.
Did you dyno in 4th or 5th? 5th is actually closer to the 1:1 ratio we need for best results
Old 06-24-2011, 07:58 AM
  #91
StreetKA's Avatar
it was in 4th i belive
Old 06-24-2011, 08:45 AM
  #92
i realized that i need more TQ than HP i dont beat my car on high rpms if i dont have to my goal to achieve is 240 TQ and 270-280WHP N/A
my goal is the same....gl
Old 07-10-2011, 12:55 PM
  #93
StreetKA's Avatar
Same dyno same tunner 85 deg instead of last 55, ported IM and runners installed. Car running ok but pulled 235whp which is 12 less than last time. I did like only 15-20 miles after install and it might be not enough for ecu to reset. Also i forgot to put horns on IM i think also thermo gasket didnt look ok(kinda melted). Gonna tweak these things and do 2.5" and wait for colder weather to go again on dyno.
I'm disapointed because i was working yesterday till 1am to see some gains but well what u gonna do. Hopefully i will get it to run the way its suppose to
Old 07-10-2011, 02:57 PM
  #94
civicdrivr's Avatar
You left the intake velocity stacks out? Thats why youre down on power. Also, just pull the #13 fuse in the pass side fuse box next time to reset the ECU without losing your radio presets. Then go beat the piss out of the car for a few miles to give it a decent recalibration.
StreetKA (07-10-2011)
Old 07-10-2011, 03:49 PM
  #95
wow man, really sorry about that..
if anything you would think you would stay around the same power, but maybe that heat is killing you too?
Try 96 down here...lol...gl next time man
Old 07-10-2011, 04:16 PM
  #96
StreetKA's Avatar
yeah i noticed it after i put everything back together and it was kinda late to take it apart again so no i didnt but tomorrow will try that again... how many miles should be fine for ECU ?
Old 07-10-2011, 04:25 PM
  #97
B A N N E D
friesm2000's Avatar
miles...... it could take 1000 miles at times, especially depending on the type of driving you do, and what sort of loads the engine would see on a regular basis
but even on a short test drive of only like 10 miles, most ecus will have learned the engine pretty well, and it's mainly fine tuning from there, but you would more then like be alright with 50-100 miles (with a couple of cold starts thrown in there too; ie: over a couple of days)
Old 07-10-2011, 06:26 PM
  #98
civicdrivr's Avatar
^ Yea, about 100 miles is good enough for the ECU to pull all the info it needs to relearn. Thats why I usually wait a week after installing mods to let the ECU recalibrate, even though I usually put 100 miles on the car in a day.
Old 07-10-2011, 09:14 PM
  #99
StreetKA's Avatar
any recommendation on hfc cat ? model ? magnaflow ? vibrant ? must be 2.5" in and out round ? oval ?
any universal should work ?
this one should be fine right ? $92
http://www.proimporttuners.com/index...roducts_id=513
Old 07-10-2011, 11:26 PM
  #100
civicdrivr's Avatar
The direct fit cats from Magnaflow wont be high flow. I dont remember what model I got. I do remember that its a spun cat, high flow, and universal.
Old 07-11-2011, 09:28 AM
  #101
reese8789's Avatar
wow I would be pissed. Is the manifold and runners port matched?
Old 07-11-2011, 10:52 AM
  #102
StreetKA's Avatar
Yes
Old 07-11-2011, 12:41 PM
  #103
StreetKA's Avatar
i took everything apart today and installed velocity stacks back on place and removed p2r thermo spacer because it looked suspicious melted and warped too much... again car felt fine it made me smile a lil bit but its not something i was expecting i will dyno car again after im done with exhaust, hfc is ordered resonator is here so it will be soon...
02-25-2020 09:57 AM
drone619
01-26-2016 07:09 PM
handsom-hustla
11-13-2015 05:04 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Quick Reply: StreetKa's CL Type S 03 6 speed Dyno
