Mid-Atlantic Delaware, Maryland, Pennsylvania, Virginia, Washington DC & West Virginia
RDX wind noise
Old 08-19-2014, 10:40 PM
junie1251's Avatar
RDX wind noise
My 2013 RDX makes an almost unbearable loud wind noise at speeds over 60+ when the rear windows are rolled down. Has anyone else experienced this problem/found a solution??
Old 08-20-2014, 05:53 AM
3G TL/2G MDX Owner
TLtrigirl's Avatar
This happens in all modern cars, I forget what the phenomenon is called but it has something to do with the pressure variance inside compared to outside of the car along with how the car is shaped (aerodynamics) as the air is swirling around the interior of the car.
Your solution... crack your front windows and tilt your sunroof to mitigate some of it. You'd get better MPGs at highway speeds with the windows up anyway. Just sayin'
Old 09-02-2014, 07:04 AM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
It is called the "Helmholtz resonance". The same answer was posted in the RDX forum a few days ago.
TLtrigirl (09-03-2014)
Old 09-03-2014, 05:36 AM
3G TL/2G MDX Owner
TLtrigirl's Avatar
^^thanks ceb
Old 01-04-2018, 08:19 PM
macdonjh's Avatar
Helmoltz resonance, cool. Are you talking about that horrible throbbing you get when you open only one or two windows? If yes, then cracking a third window will stop it.
Old 01-13-2019, 12:35 PM
7th Gear
Emcmtony's Avatar
Not unique to RDX
The noise buffering is just a fact of life in most cars. You are forcing air in with no way for it to circulate so it causes vibration.
inmydream316
05-03-2019 07:28 AM
le^2
05-30-2018 10:50 AM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: RDX wind noise
