Double Din Unit on 2011 TSX W/Tech
I want to install a double din head unit in my tech packaged TSX. I know I will lose the display for the temperature (I will take care of that later). Will the non-tech double din install kit work, or will I have to make something? I can change the original screen with something that will work with the new head unit, so I am not worried about that. Thanks!
Great post on ELS bypassing and other words that I don't understand https://acurazine.com/forums/2g-tsx-...preamp-819501/
Are you going for better SQ or just want the modern toys? Phantom Audio can redo your stock amp to make it sound better so it still retains stock functionality. I haven't heard it personally but have spoken with him and he knows his shit.
I planned on molding a cradle into cavity where my stock screen is and magnetically attach for easy removal. and sticking an android tablet or ipad in there. but it's hot af and im lazy.
Good luck!
Today I finished installing a Kenwood head unit. It was more work that I planned on, but everything works. The stock GPS antenna plugs in to the head unit, that was the only part that was easy! I have my temperature display in the glove box now. I still need to make that look good, but I am very happy with the way the system sounds now. I am finally happy with the car
Does the factory rear view camera still work on the OEM screen?
Did you remove the DVD player and replace it with the non-tech pocket?
Any other concerns?
I did take the GPS antenna connection out from the factory radio to use on my Kenwood, and plugged in an aftermarket GPS antenna into my factory radio. That way I have great GPS signal. I used an aftermarket antenna on the factory radio because when you disconnect the radio it will display the lost GPS signal screen until it can find itself again. So I can pull out the antenna that is tucked in behind the radio, get a signal, then tuck it back and out of sight.
You will need an antenna adapter that isn't very common. I will try to find what it looks like. It is not the typical Honda style. I didn't have it, so I soldered an adapter in place. I was too far into the project to wait for one to arrive.
I used a Maestro adapter for the steering wheel controls, it works perfectly.
If you have any questions, feel free to ask! I was really thinking of getting rid of the car because the factory radio was so bad, but now I am very happy. I have good sound
you back from vacation yet? I need to do mine! I’m so tired of this old headunit. Please explain in detail which headunit, harness and what frame for the headunit you used as the ones online say they aren’t compatiable with navigation.
Looking to do this swap to my Wagon
Evening fellas. Anyone else do this? I'm looking for all and any directions that I can get.
1. Radio harness(s)
2. Antenna plugs / adapters
3. Anything else I might need.
1. Radio harness(s)
I have a European Honda Accord (the same as TSX 2nd gen normally)
I have found this in Aliexpress it was delivered with all the necessary (harness, ...)
I'm exploring all my options. So fare this looks to be the nicest.
What i've done : https://www.youtube.com/watch?v=OupxW4meruo
Is this the radio setup
https://m.tr.aliexpress.com/item/400...7%237562%23475
This one i the new one i've ordered.
My actually one is : https://tr.aliexpress.com/item/32919...archweb201603_
€ 130,80 51% Off | Android Car DVD For Honda Spirior / Accord ( 2009-2013) Car Radio Multimedia Video Player Navigation GPS Android 10.0 Double DIn
https://a.aliexpress.com/_mqPbwVF
How would thus work? Anyone tryed ?
its interesting that it has sone kind of support for center speaker that i have in dash, doesnt say anything about subwoofer , if this supports all of oem speakers tgan i think is a good buy ?
noraz123
05-15-2020 01:29 PM
Jeremiah Blair
12-25-2012 06:34 PM
