Dropped/lowered/slammed 2G TSX - Pictures, Details, Reviews
Old 03-24-2017, 09:51 AM
  #281
97CL_NC1102's Avatar
Originally Posted by xtcnrice
Nice, you get a 2G TSX? I'd assume so since you're in this subforum . If so, well, 18x9.5 +35 on 245s will have poke, guaranteed. If you're planning on at least moderately lowering the car (1 or 2 finger gap left), you may rub with natural camber. I'm on 18x9 +30 on 235/40s in the front, and there's maybe a little under 1cm of poke, and although it's rare I do rub once in a really long while. Should be very similar with your desired specs. But if you can pull it off, it will be a very nice meaty setup . I wanna go 245s too but I'm afraid I'll need probably -2.5 degrees of camber up front or so to do it.
Yes, I bought a 2010 6 speed blk/blk. It will be lowered but im thinking 245/255 might be a little too much. Im not looking to tuck tire but 1 or 2 fingers will be fine for me. I ran a 234/45 on my legacy gt wheels in the same specs and it was a baby stretch but I still had a lot of tire surface contact. Im curious about how much poke it'll have though. I'd be ok with running up to -2.5 degrees with a fender roll and slight pull. I've been basing everything off Christian Loza's TE37 setup on his TSX. He's running 18x9.5 +40
xtcnrice (03-24-2017)
Old 03-25-2017, 07:43 PM
  #282
SlickxAc's Avatar
Cristian is actually Running the same specs as me with 18x9.5+22 currently.
97CL_NC1102 (03-26-2017)
Old 03-25-2017, 09:48 PM
  #283
Well damn, now I feel better about my decision haha. More than likely Im gonna go with the same wheels I had on my 2000 RS. I had the Konig Hypergram's in 17x8. The 18's are so much better and look better with more lip and theyre BBK friendly for later down the road. They're also very light weight. My 17's were 16-17 lbs
by https://www.flickr.com/photos/119797947@N06/, on Flickr
Old 03-25-2017, 10:25 PM
  #284
SlickxAc's Avatar
I love my TE37 SL's they weigh like 18lbs and more then BBK friendly lol
Old 04-08-2017, 02:46 PM
  #285
EuroRspec's Avatar
Looking for some advice.
My goal is to lower my wagon with Koni Yellow shocks by adjusting the perch. Not really looking to lower my car as it's my daily and family vehicle. However, I want to improve the handling and look. Track look.
I'm currently looking at a set of 18x9 +25 wheels and want to run a 245 or 255 tire with camber kits up frot to get some negative camber. How much will these wheels poke out? I would like to see some meat, but not look like a lowrider or someone who doesn't know what their doing.
If all else fails I will go with a +35 but I will need to change the wheel style since the wheels I like do not come in that offset. Thanks for your help.
Old 04-10-2017, 01:27 AM
  #286
julius071's Avatar
Search is your best friend.
Old 04-10-2017, 09:25 AM
  #287
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
At risk of sounding like a broken record to many, I'm running 18x9 +30 up front on 235/40R18 Michelin PSS. Wheels poke for sure, and I'm lowered with natural camber. Not slammed by any means... but I've had a couple of rubbing "one-offs" with this setup. 1 finger-gap setup I guess. How much poke? Maybe about 1cm or so. I can take a better look this weekend when I put my wheels back on (still on winter mode ).
I did recently install Ingalls front upper bjs though. My alignment is likely way out of spec now... but I didn't care much for an alignment since I was on my winter setup which I don't care much about. Still need to do a little height adjustment so I've put it off. But I put in the front upper bjs to hopefully get a tad more negative camber. Thinking -2.x degrees. The top of the wheel should "tuck in" just fine after an alignment.
With 255s, you'll very likely need a front kit.
The following 2 users liked this post by xtcnrice:
EuroRspec (04-12-2017), julius071 (04-10-2017)
Old 04-10-2017, 12:22 PM
  #288
julius071's Avatar
How was the installation on the upper ball joints? Hopefully to tackle my front and rear upper control arms soon after I find a quick placement for my height sensors
Old 04-10-2017, 12:58 PM
  #289
xtcnrice's Avatar
A pain in the ass lol. Should be easier for you if you have complete UCAs to replace.
julius071 (03-03-2018)
Old 04-11-2017, 03:44 PM
  #290
BROlando's Avatar
Received 1,167 Likes on 877 Posts
18x9 +25 is not a bolt on fitment.
It will require fender work.
18x8.5 +35 to 40 with 245's is bolt-on. If you decide to cancel out rear camber, you will want to do it with a LCA kit...not a upper ball joint kit.
I have 18x8.5 +35's on 245/40 MPSS.
The following 2 users liked this post by BROlando:
EuroRspec (04-12-2017), Teo_cleanNlean (02-22-2019)
Old 04-11-2017, 11:06 PM
  #291
jtsxcu2's Avatar
https://i.ytimg.com/vi/by3mBUF35eQ/maxresdefault.jpg I'm looking to purchase a set of vossen cv7s but I'm debating whether I should go 19x8.5 or 20x9 as those are the only specs they come in. Really leaning towards 20x9... would 20x9 be a good idea? anybody on here has any feedback, It will be my daily driver just for the spring/summer ? I'm running stock everything and not planning on doing anything to suspension anytime soon
Old 04-11-2017, 11:48 PM
  #292
SlickxAc's Avatar
Honestly I wouldn't even consider wheels if you are not planning to do suspension anytime soon.
julius071 (04-12-2017)
Old 04-12-2017, 10:36 AM
  #293
julius071's Avatar
What I learn from reading from these forums is suspension first then wheels.
Old 04-12-2017, 09:22 PM
  #294
EuroRspec's Avatar
Thanks for your insight! Mind posing a picture?
Old 04-13-2017, 02:27 PM
  #295
BROlando's Avatar
I'm quite happy with my home made flat face centre caps for my Enkeis.
Old 04-14-2017, 10:25 AM
  #296
julius071's Avatar
Looks legit!
Old 04-14-2017, 09:57 PM
  #297
xtcnrice's Avatar
The plan was for me to do an oil change and swap the wheels at the same time today. But... this happened
View this post on Instagram
These aluminum nuts are so maleable. One of them stripped and prevented me from taking the 15mm spacer off on the front passenger side. Will have to deal with this first
Old 04-17-2017, 10:30 AM
  #298
julius071's Avatar
Sorry to hear. How were you removing that bolt impact wrench?
Old 04-17-2017, 12:54 PM
  #299
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Hulk Strength.
XTC MAD! XTC MANGLE NUT!!!
xtcnrice (04-18-2017)
Old 04-17-2017, 03:47 PM
  #300
BROlando's Avatar
Looks legit!
thanks!
Old 04-18-2017, 07:30 AM
  #301
xtcnrice's Avatar
By hand with a standard socket wrench. Didn't ever put an impact gun on these nuts and they still strip. This one is toasted for sure, but the other ones are very close to giving as well. They are scarred all around. I got it taken off with a nut remover/extractor socket, some hammering, and a little more swearing .
Old 04-19-2017, 10:25 AM
  #302
julius071's Avatar
Will be making sure to add anti-seize to avoid your mishap.
Old 07-03-2017, 01:57 PM
  #303
radiokilla's Avatar
Got some new goodies for the wagon :P
xtcnrice (07-04-2017)
Old 07-04-2017, 01:31 AM
  #304
9th Gear
vinola's Avatar
So darn nice!
Originally Posted by radiokilla
got some new goodies for the wagon :p
Old 07-06-2017, 10:28 AM
  #305
BROlando's Avatar
^My goodness. That's definitely the best looking TSX wagon I've seen anywhere.
Old 07-07-2017, 09:56 AM
  #306
julius071's Avatar
Very nice! Any side shots?
Old 07-08-2017, 02:08 PM
  #307
EuroRspec's Avatar
What are your wheel specs?
Old 07-17-2017, 11:06 AM
  #308
radiokilla's Avatar
Thank you! It's a work in progress!
I don't have any at the moment, but ill take some and post em up later!
18x9.5+30
Old 07-19-2017, 11:27 AM
  #309
Sheefo2k's Avatar
18x9.5+30
Well done, your wagon looks great.
Could you post your tire specs? Brand and size, please.
radiokilla (07-19-2017)
Old 07-19-2017, 11:38 AM
  #310
radiokilla's Avatar
235/40/18 Nankang NS20 all around
Sheefo2k (07-19-2017)
Old 07-19-2017, 11:57 AM
  #311
Sheefo2k's Avatar
Thank you, couple more questions.
What are you lowered on? Any fender work? and finally, is your alignment corrected and within stock spec?
Old 07-19-2017, 01:10 PM
  #312
radiokilla's Avatar
BC Racing Coilovers/Megan Upper control arms, Rolled Fenders, Custom alignment not stock specs.
Old 08-28-2017, 09:39 PM
  #313
EuroRspec's Avatar
How much camber are you running all around?
Old 08-29-2017, 05:50 PM
  #314
radiokilla's Avatar
-4 all around
Old 08-06-2018, 01:55 PM
  #315
davidk72008's Avatar
What are these wheels?! I saw the sizes, but no name. Best looking wheels I have seen on a wagon yet, and I am looking for some for my wife's new one
Old 08-17-2018, 04:18 PM
  #316
Eri_k20's Avatar
not 100% but they look like Enkei RC-T5's
Old 08-17-2018, 11:50 PM
  #317
EuroRspec's Avatar
Here is a set
https://sfbay.craigslist.org/nby/wto...666052771.html
Old 12-16-2018, 06:56 AM
  #318
Matt Lumpkins's Avatar
Originally Posted by Adam Rutledge
09 TSX w/ tech pkg in Premium White pearl.
1. Have H&R sport lowering springs
2. Drop is about 1.25"
3. Camber adjustments Front left -0.3 Front right -0.7 Rear left -2.5, rear right -2.7 .
4. No fenders mods
5. Honda Factory Performance Wheels 19"
6. Hancook Ventus Evo V12 summer tires (245/40)
These springs have OEM quality ride and there is no rubbing. Would highly recommend.
Attachment 48334
Attachment 48335
Attachment 48336
Attachment 48337
Attachment 48338
Yo that looks sick AF!!!!!!!!!
Old 12-16-2018, 04:06 PM
  #319
8th Gear
I Deliver Tofu's Avatar
2009 TSX Tech package 6 speed manual
134k miles
Koni yellows with H&R springs.
2017 TLX wheels with 225/50/18 tires, little too big for the car so it's raised just a bit. (Wearing these out to get some 235/45/18, got em for a good deal haha)
Old 12-16-2018, 07:48 PM
  #320
^those wheels look gorgeous, and great job getting the acura emblem moved over to em!
stalloutboy
04-25-2016 10:28 PM
mugen_kid
11-13-2015 10:38 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
JnC
09-11-2015 06:06 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: Dropped/lowered/slammed 2G TSX - Pictures, Details, Reviews
