Cannot install Gear Shift Assembly
Old Sep 25, 2024 | 07:30 AM
TLX TYPE-S IN UKRAINE's Avatar
Hey guys, your advice here would save my life.
I've bought an Acura TLX Type S with a missing pannel and a missing Gear Shifter
I've bought missing details but I have a problem with installation. The part I have looks like:
After installation I still have spare wires my car does not work properly
I feel like I'm missing a part here, please advise if you know something
Old Sep 25, 2024 | 07:31 AM
I've also checked official doc but could not find appropriate part:
https://www.acurapartsnow.com/v-2021...-shift-control
Old Sep 25, 2024 | 07:41 AM
Not sure, though, those connectors (yellow arrows) look like they may be 'navigation' related?
Did you get up deep, under the dash in that area, to look for any 'navi' components that may need connections?
Otherwise,
Also, what is the exact 'trim' description of your TLX?
Old Sep 25, 2024 | 07:55 AM
Otherwise,
The exact trim is Acura TLX Type S 2023 10 speed automatic. I will check deeper it they can be connected somewhere else, thanks
Old Sep 25, 2024 | 08:08 AM
I've found illustration of how to remove the center panel: https://acura.bernardiparts.com/Imag...II14301-27.pdf
Looks like I'm missing this square part but I have no idea what it's name/number
Old Sep 25, 2024 | 08:13 AM
1) It appears you have the correct part number for your model 54000-TGV-A82, so that's a good thing.
2) The only other notable item is that the select switch assembly has (REWRITABLE) in the part description; therefore, perhaps a computer scan tool is needed to program it to your car to 'sync' it in with the ECU et al?
Old Sep 25, 2024 | 08:36 AM
Looks like #4 below, no? Maybe #5?
Old Sep 25, 2024 | 09:07 AM
Amazing, thank you man!!!
Could you please share the resource you've used for search? I fill like I will still have extra wires after installing this part, guess I need to find a schema with potential other details there
Old Sep 25, 2024 | 09:14 AM
I believe I have three more wires to allocate somewhere
Old Sep 25, 2024 | 09:21 AM
Acura Parts | DreamShop (honda.com)
Craig Baize
May 18, 2020 03:04 PM
moochie169
Mar 10, 2016 04:07 PM
hawkeye62
Jun 12, 2012 01:06 AM
unctarheel003
May 16, 2010 09:30 AM
danb
Mar 30, 2004 02:19 PM
