Brakes constantly squeak
Hey guys anyone have a constant brake squeak in morning and after finishing a 8-10 hour work shift. Mine squeaks everything morning and everytime I leave from work. It does go away after several minutes but come on have 91 civic si where brakes never squeak and also had 2017 subaru wrx where brakes rarely squeaked as well. It's embarrassing 😳 to be honest.
Trish M (12-15-2021)
6G TLX-S
21 Aspec
I’m at the dealership right now due to this issue. My service advisor told she had her brakes,rotors and pads replaced with 200 miles on the vehicle. I’ll update everyone when they get done with the inspection.
of course they couldn’t replicate the issue so I have to bring it back for an overnight so they can test it first thing in the morning. Apparently there’s no sign of wear even it sounds terrible when it’s cold.
The dealership stated they were told by Corporate not to attempt to fix the issue. There is an open investigation to root cause. Not sure if that’s bs or not so far this dealership hasn’t given me a reason not to trust them.
Sarah_Kelly (03-13-2023)
At least I wasn't crazy lol. Just hut 12k miles and now have a service light for b6 service which comes up to a rear diff oil change. Just want to make sure that's accurate
That is correct. It's a slow process too. They can replace the pads/rotors now but it's just going to come back then you'll be even more unhappy.
Throwing my hat into the brake squeal ring.
I have not spoken with corporate directly this is all through the dealership.
Now the question is; can I live with that response and listen to the squeal every morning or every time I drive my car and it's cold out. **Edit: The squeal clears quickly and is usually not present after 1/4 to 1/2 mile, the colder out the longer it's present.
ELIN (02-23-2022)
happens when i brake for the first time in cold weather.
The following 2 users liked this post by EE4Life:
Sarah_Kelly (03-13-2023),
ValB175 (02-15-2022)
Tsb doesnt apply to type S but i have the same issue. Its a small annoyance but certainly worth a fix once they have them for my car too. Interesting to note that once you remove them they are garbage.
Going to my dealer on Monday
Lets see if they replace the Pads
Already showed them the TSB
Besides the occasional squeak, after a Car wash, the brakes BANG, for like 15 minutes
Kind of weird; having it checked out tomorrow
New Pads were ordered, as per the TSB, from Acura
Will be installed on Friday
Keep you posted
Keep you posted
Had a similar issue on the previous MDX so lubrication could be the common link.
According to my Acura in-house Technician, he swears, the banging sound is normal
Went for the Front Brakes replacement :TSB
All GREAT; including FREE Wiper blades, & Car wash
Go Acura!
Go Acura!
Acura21Tlx (03-10-2022)
Having a slightly different brake squeal issue, wondering if anyone else has had this.
When I park the car and get out I can hear a loud brake squeal with no foot on the pedal. Doesn't matter if I set the parking brake or not. Drive time or temperature do not seem to matter and it makes the noise about 80% of the time.
This is on a 2022 A spec.
But I do have something when I set the parking brake and get out of the car( and only when I set the parking brake). I'm larger, around 250lbs. When I get out the weight shifting does cause it. The fact that I only hear it when parking brake engaged and only from the rear wheels should help narrow it down.
Yes, but they will put old pads back on and it will be back to making noise and they won't put more money into it. I'd advise you have a new set on hand. They won't install aftermarket as part of the TSB also. So you'll have new rotors and old pads until you change them yourself.
As stated on March 10/2022
Brought in my 2021; (at that time)TLX/ASPEC
Have since upgraded to a 2023
The dealership REPLACED the pads for FREE
Show your dealer the TSB, & they should do the same
