Type S Trunk Bracing
Does anyone know if the Type S braces between the back seats and the trunk are somewhat easily removeable? Would be good to have that option, in case there was a need for transporting something a little bulkier. From time to time, I'd want to be able to put my bike in there, but I doubt it would fit between the X shaped braces.
Looks like it is possible to bolt onto non-type S Model, so it should be possible to take off, getting to lower bolts might be a Pain....
https://www.reddit.com/r/Acura/comme...brace/hc7cir1/
Part NO for 2021 that's apparently stronger than 2022: 74550-TGZ-A00
2022 (2x required vs 1x for 2021): 74550-TGZ-A01
Removing the brace for any length of time most likely voids the warranty. If this is a deal-breaker, I suggest looking at a different car.
Not really, Law states that the dealer has to show that the removal/alteration of a part caused the failure. If you remove the brace and then your headlamp stops working a week later, the dealer can't say it was due to the bracing. If you remove the bracing and then end up with trunk rattles where the braces were, then they can decline the repair stating alterations.
I understand why Guy is considering removal of the brace, and it makes sense for him to pose the question. But perhaps many of the responders are missing the most obvious point. Acura most likely has designed and installed the brace as part of the structural integrity of the car. Given the constant drive to save/eliminate weight and excess costs by all manufacturers its a very good bet that if the brace wasn't needed then it wouldn't be there. Hopefully, Guy will be able to find a better solution (roof or trunk rack for example) that gives him the utility that he wants.
MarcoTLX (08-20-2024)
AZ Community Team
This is from Acuras press release:
”Specific areas of reinforcement start in the front, with additional structural braces linking the shock towers, and triangulating to the firewall to create a stiffer “box” for the engine and transmission. In the rear, steel reinforcements behind the rear seats create an “A-Brace”, stiffening the rear bulkhead and significantly improving rear tire contact patch under aggressive cornering. Additional structural enhancements include an extra mid-floor crossmember and stiffer rear wheel arches. Total curb weight for the TLX Type S is 4,221 pounds, or 4,200 pounds with the available lightweight wheels”.
The following 3 users liked this post by KrylonBlue:
6G TLX-S
Since the Type-S is using a stiffened body than the regular non-Type-S, I suspect that if the rear seat A-Brace is bolted on and not welded on, then it is expected that the A-Brace can be removed temporary for extra trunk access.
With the temporary removal of the A-Brace, don't throw the Type-S into corners the same way as if the A-Brace is still there, because there will be body flex that will compromise handling performance of the car.
KrylonBlue (05-05-2022)
That fugly brace is one of several reasons I did not buy a TLX-S. If something like this has to be added for sufficient structural rigidity/integrity, the car wasn't designed right in the first place.
pyrodan007 (05-06-2022)
the brace is there for handling purposes to tighten up the rear. You want to stick a bike in there, buy a subaru
you didn't buy the car, one reason being a trunk brace that helps stabalize the rear on an AWD car? top kek
The following 2 users liked this post by FckFiat:
Hondamobilemechanic (05-13-2022),
KrylonBlue (05-07-2022)
A similar story to yours, I once almost didn’t buy a car because it came with all-season tires. Then I realized I could replace them.
The following 6 users liked this post by richii0207:
bilirubin (05-06-2022),
F23A4 (06-10-2023),
FckFiat (05-12-2022),
KrylonBlue (05-07-2022),
and 1 others liked this post.
AZ Community Team
The following 3 users liked this post by Legend2TL:
AZ Community Team
Removing the brace does not void the warranty, it's purely a augmentation structural piece to enhance the rigidity of the chassis, it's increased the load performance of the chassis but removing it is not a safety or warranty concern.
Thanks, that's good to know. Are the bolts accessible or a PITA? Just want to know if it looks easy to remove...if it was absolutely necessary.
AZ Community Team
I have never seen one in person but it appears from pics and schematics that the fasteners are covered up by the plastic covers in the corners and top center of bracing. Once those covers are off the fasteners I believe are assessable.
This TLX Type S brace looks like an afterthought.
robnalex (05-08-2022)
6G TLX-S
The Type-S rear seat A-Brace may not look nice cosmetically, but hey, it gets the job done and does it really well.
Oh, Honey- it would take a lot more than an unobstructed pass-through for a lot more people than "one guy on the internet" to buy a TLX-S. But thanks anyway, dear.
AZ Community Team
The following 5 users liked this post by Legend2TL:
bilirubin (05-08-2022),
djhtsx (05-08-2022),
Edward'TLS (05-08-2022),
Jim2301 (05-08-2022),
richii0207 (05-08-2022)
I'm guessing the engineers wanted as stiff a structure as they could design/engineer so they took a stiff chassis and made it stiffer. The K and V bracing are some of the most efficient geometric force/load structure there are in mechanical engineering. Acura/Honda are not the first to use it, many other cars have added it to their structural designs to stiffen up a chassis. K or V bracing are used all over modern unibodies, sometimes added exclusively to certain models.
I understand bracing even though I am not a trained engineer. I did have 5 months schooling on armored vehicle recovery & repair in the US Army. Was section head with a pair of M-88's & crews to manage. I have also built cages & roll bars to NHRA standards.
I built this car from a 1981 280ZX T-Top. When you cut the roof off a closed car it has all the rigidity of a banana skin. It has a fabricated second frame including upper body work support. Car survived 3 kids going through high school & university, one on her first job. Car was donated to Make A Wish about 6 years ago when I needed garage room to built the car Nexx gets all upset over. The trunk lid is the T-Top rear hatch with the glass removed & sheeted over. A cowel was built behind the seats to connect the two sides & is tube supported. Top is a modified TR-8 frame with custom fabric.
It seems we agree that they added the brace to stiffen the unibody. Part I don't care for it they did not directly reinforce the unibody structure itself but added something JC Whitney would sell. Guess they were trapped into it by having to build to a price. Its a good inexpensive solution. But think how much nicer the whole lineup would be with the upgraded unibody. Marketing could say we stiffened the car by 70% instead of 50%. But based on a lot of the comments made here about how great the brace is I guess in this case they know their customers.
It is best if the extra support is a square structure. Then at least the opening, no matter how small, can still be used.
But if a square brace doesn't cut it, what Acura should have done is to bolt the back seat shut to cover the /\ brace on the Type-S. What good is a backseat opening that can be seen through but cannot be used.
Just give the Type-S a non-fold-down back seat with a ski bag pass through, just as it has always been for the 4G TL.
Again, this thread was started as a question if it was removable. Not if we liked its cosmetics. Back on topic as a service to the OP so he’s not wasting time reading through all these irrelevant posts to find his answer.
Therein lies the problem..... engineers.
What's wrong with engineers? I think Acura's budget is too focused on marketing versus actually engineering. Why is it then that sportbacks don't need this extra bracing? Curious if the Integra Type-S will also have a brace.
If it can be removed then it's not a core structural component since it would never pass safety standards. It'd be wielded in. Type-S' extra weight is in the front anyways, regular TLX is just fine without. And if no one is on the track, it's definitely not a core component.
This is also not just a random comment. I see poorly engineered things on a daily basis in my field and its beyond frustrating.
Cost vs time vs quality, quality is the one usually left behind because of accounting
Back on topic, next off topic post gets a week vacation. Be civil with each other. If you don't have anything constructive to add, don't post.
The following 2 users liked this post by csmeance:
KrylonBlue (05-13-2022),
Legend2TL (05-13-2022)
I'm not sure if that's a blind rivet head or socket cap or lag bolt as the resolution of the picture above is unfocused to discern. But looks like you can take the front cosmetic cover off then get access to the 2 PLS bolts. Hopefully there's enough clearance you can simply swing them out of the way without the flanges obstructing the rotation.
The 2021 TLX is an improvement over the legacy design that was formerly bolt on, versus the current monocoque ring structure, with added cross brace for improved torsional stiffness. No different from the front sway bars on the shock towers in the engine bay to mitigate body roll. For instance I was helping a buddy service his older M4, and we had to remove the three point front sway bar just to get access to drain the oil catch can. Honda/Acura engineers could also use something as a shear web, very thin like on the back of the bookshelf to give torsional rigidity, effectively closing out of the opening, the difficulty though is making it quick detach structurally, fastened gusset plates, or becomes a quick detach hatch. To improve on weight could be made out of carbon fiber as well. But as someone eluded to earlier, typically you're operating within budgetary constraints with respect to material selection, COTS with supply chain issues and all. They, Honda could use captive fasteners designs, COTS, like Aloca or Avibanks for instance, they already use some plastic ones on some cover panels, like the one to get access to the brake fluid reservoir.
The following 6 users liked this post by praecisiovectura:
csmeance (05-31-2023),
ELIN (05-17-2022),
FckFiat (05-16-2022),
Legend2TL (05-17-2022),
richii0207 (05-16-2022),
great post
6G TLX-S
Even though the TLX Type-S doesn't excel in straight line acceleration performance, but all these extra braces and reinforcements make the TLX-S a superb handling machine.
No doubt. My question: does it handle remarkably better than say a 200lb lighter A-Spec SH-AWD running a set of Continental Extremecontact DWS06 Plus rubber (instead of the touring oriented Turanzas)?
