TLX Type-S: Idle Stop & Cylinder Deactivation
Does anyone with a 2021 TLX-S have any feedback on the Idle Stop & Cylinder Deactivation experience with this new model?
I was looking to replace an older TL with a new TLX-S but was concerned with paying all the extra money for the additional power that is going to be constantly managed by these econo-features.
This is the first car I've had with this feature and its works well. Its on by default in comfort and normal, but its not on when your in sport or sport+
You do have the option to turn it off with a button if you're in comfort or normal. When your calmly driving in the city in normal mode, the slight hesitation when you take off at a light is fairly seemless.
I personally keep it in Sport mode for city driving about 80% of the time, so its not on then which gives you a bit better throttle response off the line, plus all the other sport benefits (sport+ is way too harsh for regular city driving in terms of high revs)
justnspace (08-21-2021)
What about Cylinder Deactivation where half the cylinders shut down at constant cruise speed but reactivate as soon as you bump the throttle?
6G TLX-S
My idle-stop function has never activated from day 1. When the car first starts up, It says something like A/C setting prevent it from operating.
I'm not rushing to figure out what is going on, because I never want the idle-stop function at all.
The following 2 users liked this post by Edward'TLS:
FNHP4ME (11-24-2021),
norsairius (11-23-2021)
AZ Community Team
If your air conditioning is set to LOW the car won't activate the idle stop feature as the car will consistently push the highest output of cold air. This is why it's telling you the A/C is preventing the idle stop from activating.
6G TLX-S
Yes, the A/C was set to LO when the car was in the dealership. But I have adjusted the temperature setting to 19'C before I drove off the dealership.
Currently, there is a diagonal line strikes through the idle-stop symbol on the instrument display, which means that idle-stop is suspended.
AZ Community Team
I just drove home my new car a couple days ago, and is still trying to learn all the endless high tech features and functions.
Car Crazy for Sure!
the system, and I turn it off right away. Easy enough...right? Also, in Individual Mode, you can set it there to not come on. Can do all this same stuff with my '22 MDX. I set up my "Individual Mode" and
when I want to all you do is push in the center of the Mode Selector button and it activates that Ind. Mode and goes to all the settings you programmed in.
Cylinder deactivation has been around for many yrs and I've had many Acuras with it. No big deal. Now it's so smooth you never know when it happens...but, know that it only happens when you are
on a constant speed, level drive/cruise. It's NOT constantly deactivating and activating. They have made it much better from when it first was implemented....but, just drive the car and enjoy it as you would
as if it didn't have it. I never give it a thought and it never truly reminds me at all that it did happen. Which is rare.
6G TLX-S
"Idle-stop is suspended" update :
Today after having driving the car for some meaningful distance, the Idle-stop function suddenly starts to work.
I think this is to do with the battery being low in charge. The battery may not be at full charge out of the factory, and since I have been doing short distance driving for the past few days, the battery never really get a decent charge up. With a weak battery, Idle-stop won't function.
Today, the long distance driving allows the battery to charge up nicely, and so Idle-stop comes back working, just as the design intended.
Legend2TL (08-24-2021)
AZ Community Team
^ wow that's alot of inputs and parameters for the S/W developers to take into account for the ECU firmware
I mean what's your primary concern with it? I don't know for a fact but I'd put money on it anyways that cylinder deactivation would never happen in sport/sport+ as the revs are going to be high and it's obviously not in a cruise configuration. In comfort and normal I'm sure it activates under similar cruise conditions like all other Honda V6's with the feature. Definitely don't think it's anything to worry about.
My concern is three-fold. First I understand that cylinder deactivation is particularly tricky with the balance of a 6 cylinder engines and requires special hydraulic engine dampers to quell vibration upon relight. Second, being that the car is tubo charged and already has some turbo lag, shutting down 1/2 the exhaust available for rapid spool up would only seem to add to the lag. Third, it's the thought of paying all that extra money for the additional power and having the car deactivate it on on its own. That is why I wanted feedback from someone who drives one every day under varying input circumstances to get their real world feedback.
Unscientific but I highly doubt the situation would be different for the TLX-S. In Comfort/Normal the cylinders should be relit faster than the transmission downshifts, in sport/sport+ I'm sure it would never kick in at all. If it was a problem surely some owners would be talking about it by now.
if you guys hate the auto stop start that much.. install this thing. https://www.idlestopper.com/product/...rue&cst=custom you're welcome
The following 3 users liked this post by Nexx:
AZ Community Team
I don't understand why my Type S won't start up in sport but the 2019 TLX ASPEC would... dumb decision
The following 3 users liked this post by KrylonBlue:
JDM_DOHC_SiR (09-11-2021)
Yes I installed it in my wife’s 2021 TLX. It always starts in individual mode now. After starting the car within 3 seconds or so it automatically switches to individual mode.
Good to see they improved the system, if battery charge is low, idle stop will not activate instead of dying on restart. That has been the only failure on my 15' V6. Now if it actually works & won't prematurely drain the battery like it does with G1 TLX, that's still to be determined.
I'm sorry, but cylinder deactivation and idle start/stop on a "performance" car is an oxymoron. The laundry list of suggestions how to overcome it, from drive modes to fiddling with AC settings is tragicomic. I don't care what anyone says, neither one of these are there for you and your MPG. They cause vibrations and super annoying situations at stop lights. The best part of this is when you stop in your driveway, the car shuts off. You put it in park to leave the car, the car turns on and then you shut it off again to exit...LOL. Or the instant moment you stop at a light, it turns green and you have to get moving, the car went through a shut off/on cycle to save 0.5 seconds of gas. Total chicanery. The one and only reason why this exists is so OEMs can get rebates and kickbacks from EPA for reducing emissions. That. Is. It. You, the end users are an afterthought.
BOWA41 (11-23-2021)
theorginalFrank
08-03-2016 08:45 AM
fsttyms1
26
08-16-2004 12:21 PM
