21 TLX Base with Ktuner
Old Jun 9, 2024 | 06:56 AM
SVandST's Avatar
8th Gear
I have a base, non-awd, 21 and flashed the Phearable Stage 3 tune with a Ktuner. What a difference! Running Sunoco 93 octane my k control numbers are typically in the .20-.30 range so no issues with knock. Using the TunerView app I did a 0-60 run and got 5.73 seconds and that was not even at full throttle. My tires slipped when I took off so I backed off the throttle a bit. I bet I would be in the 5.5 range if I just gave it 100% throttle and kept it there. This was also without any brake torque at the start - just stopped with the engine idling then mashing the throttle.
I bought the car in March with only 15,000 miles. Really enjoying it so far.
Old Jun 9, 2024 | 01:25 PM
GhostTL09's Avatar
Good to hear its working out for you. Do you have a picture of the TLX. Have you done any other modding. The base is a good platform.
Old Jun 9, 2024 | 03:40 PM
F23A4's Avatar
I have a similar setup in my 21 A-Spec FWD, plus PRL I/C and intake. Launching it definitely requires some diligence and better rubber than the stock Turanzas. (The DWS-06s improve traction and handling dramatically.)
I'm just going to upgrade to Type S Brembos once I return from Europe, after which I'll probably get the RV6 DP. Still mulling over whether or not I should get the Functionwerk cutback.
Old Jun 9, 2024 | 04:06 PM
SVandST's Avatar
8th Gear
no other mods.
Old Jun 10, 2024 | 02:41 PM
Twism86's Avatar
Awesome! Just did the same tune on my RDX but my K.con lives in the 0.40s. Sometimes I see 0.32 but never any lower.
timpeters123
5G TLX Performance Parts & Modifications
Jan 31, 2022 09:19 AM
Mdspice
Jun 27, 2021 02:35 PM
sockr1
Dec 11, 2013 09:51 AM
rsx2rdx
3G RLX (2013+)
Mar 8, 2013 12:20 PM
Zapata
Oct 23, 2003 03:22 PM
