Side mirror lights
Side mirror lights
Not a big issue but when I used to unlock/walk next to my car the lights on the side mirrors would come on. Now they don’t turn on at all. Any idea on how to toggle this feature.
They are probably honestly broken and need to be replaced. Happened to mine too. They put new lights in and so far they are working.
RENARELLO (04-16-2021)
yeah... I don’t doubt it... lol 😂 I’ll look into it during my next service check. But thanks.
also, wondering if we can make it brighter! Lol
probably every time i park if I remember too. But usually just the street side. 🤔 🤔
not that I’m aware of sadly. I wish they stayed on while reversing to give the camera light when it’s dark out for the mirror cameras.
nycez (03-24-2021)
Received 2,599 Likes
that's exactly what happened to mine. They both just randomly stopped working one night. I don't think it is software because I had the welcome lights installed and they would still go on and are essentially linked together.
Yes, it is in vehicle settings . There is also a button that can be pushed to fold them at any point.
Mine work great, as advertised!
The following 2 users liked this post by ELIN:
BEAR-AvHistory (03-25-2021),
Mikey319 (03-25-2021)
yeah both lights its weird.
yeah I got ASpec model. So the folding mirrors is a manual labor for me hehe. But too ironic that both light just stopped working.
Probably won't be long before a TSB about this shows up.
Hopefully we all knew what we were getting into buying into the first MY of a new gen.
Mikey319 (04-07-2021)
You’ve run out your trial subscription for active side mirror lights.
=P
=P
I have had my Puddle Lights on the mirrors on my 2018 TLX ASpec Elite replaced on 3 occasions, under warranty, in just under three years, which is the only issue I have had with the car. This most recent time, the service tech noted that the light is seated in such a way that water collects around the base of the bulb and likely shorts it out. To address this apparent design flaw, they put some grease in that area to protect the bulb. I am a frequent car washer, so there is likely a correlation between light issues and washing, given this issue. I will now avoid spraying the front of the mirror directly to also help prevent a reoccurence. The bulbs are LEDS and shouldn't be the problem.
Driver door puddle light under mirror on Type S no longer works. 6 days of ownership.
The following 2 users liked this post by jpsi2002:
Furnace (07-25-2021),
Ghostof TypeS Past (07-22-2021)
Ghostof TypeS Past (07-24-2021)
TLX A Spec AWD
I too recently got my TLX A SPEC in the middle of June, a few days later it was at the dealer because of these same lights. Two days out both sides were out again, took it back to the dealer and it will be four weeks this upcoming Monday with a loaner. Apparently lights/mirrors were ordered from Japan. Putting miles on the loaner!
Ghostof TypeS Past (07-25-2021)
The Service said it will be a few weeks at least, I had the service agent call parts, will be here Monday. Service manager said they’d have to replace the entire mirror.
I asked if I could buy the carbon fiber inesrts for the doors since they’re already taking the panel off, was told the panel will not be fully removed for this fix. Only top corner will be pulled back to make room for connecting the harness…
Has anyone gotten a permanent fix to this issue from the dealer yet?
If you do a search, I also made a post about the lights…specifically how do you actually replace them. No one really answered the question fully but I am guessing somehow the mirror glass comes off….My dealer ordered the lights….SIX WEEKS AGO….still on back order. But at this point, I’m going to wait because my guess is, if we are all having this problem, and many have posted that the “fix” only lasted a few days….then I’m going to wait and not be a test subject. My only gripe about the car, otherwise it’s perfect!
I know it’s only been a week and some change. Any updates for you? Currently my driver side puddle light is out (21 tlx)
The passenger side was flickering and the deriver side didn't work at all on my new ASpec. Brought into the dealer and they are ordering new lights. No happy with Acura service at all.
I know this is not the place but my rear passenger door didn't sit flush with the rear fender. Noticed this when I got the car home right after delivery. Service writer said it can't be fixed.
You couldn't even blame that on a first MY of a new gen problem. Fit and finish impacts any given year. This is one of the reasons I prefer not to take delivery of a car at night.
Received 6,470 Likes
Just had my driver's side puddle lights fixed and replaced under warranty at the dealership.
6G TLX-S
Will it help if your adjust the height of the rubber bumpers located at the inside of the door ?
So my driver side puddle light when out YA!!!!!
The culprit: High Pressure Washer
I suspected that using high pressure washer directly onto the mirror might be the cause of having water seeping into the some openings.
I never had any issues while washing my car with a regular garden hose nozzle.
So far my passenger side and my welcoming lights on the side skirt are working. When I call the dealer this week, I will bring it up to them
as to what causes the puddle light not working and I'll bring this up to my friend at Honda HQ who is the engineer there.
My driver side puddle light went out after the first car wash - the passenger side still works. I'm going to wait a bit before talking it in to see if the passenger side goes out as I suspect it will.
