Mid cycle refresh (2024?) wish list
What would you like to see?
1. PHEV power train. Or at least hybrid/mild hybrid. With our smallish fuel tank I really want better range, especially if I swing for AWD next time. And unnoticeable stop/start. That said I don’t see this happening.
2. More sound deadening AND active noise cancelling.
3. LEAVE MY TRACK PAD ALONE but just fix the bugs. And give me a charger that supports my iPhone 12.
4. Google enabled GPS. If I have this I don’t need CarPlay. But make that wireless too since it’s apparently not coming this year.
5. Better thigh support. I have the extendable support and can hardly feel it.
6. More aggressive adaptive cruise. And I want the lawyers to bug me less during lane centering.
7. This will never happen but I drive a lot in central WI and am terrified of smashing into deer so night vision would be nice.
Valid points OP and I’d say I agree with nearly everything you mentioned.
1. Touchscreen for the infotainment. No reason they can't marry it with the touchpad for those who refuse to give it up.
2. Better wheels for the A-Spec. Current ones look pretty ugly.
3. Wireless CP/AA. What's the point of having a wireless charger if you still have to plug in to use CP/AA?
4. More power would be nice to make up for its weight. If they're worried about it encroaching on the Type S, then just don't advertise the power gain and underrate the numbers like everyone else does.
5. Make the seatbacks thinner in order to open up a bit more rear legroom in the back. The current seatbacks are comically thick and that encroaches on backseat space.
6. Shave the stupid hump off the middle seat it's actually usable for anyone taller than 5'2.
MarcoTLX (11-17-2022)
I've worked with these EV companies who want to know how to clean the air when the car/battery catches fire. Lots of nasty stuff when it burns! Currently there is no regulation but I can tell you from the list of chemicals that I don't want to be near one of these burning cars (and yes, it's worse than cars that run on hydrocarbons)!
oldsnwbrdr (11-17-2022)
-Thinner seat backs, get rid of the pockets and save half an inch
-improved rear brakes on type S. I know the rears are not doing nearly as much as the fronts but if they contributed a bit more it should put less stress on the fronts.
-i agree with the aspec wheel change idea
-Canadian type S specs for the US.
-i dont necessarily think it needs it, but a larger screen would be an easy upgrade, there is space for it and its already in the MDX parts bin, i would be shocked if this didnt happen.
-improved carplay connectivity is a must
-rear usb ports
- front radar better integrated
- would anyone complain if they cranked the type S turbo up to 17 psi?
-liquid carbon metallic colour option for type S and Aspec
- dont mess up the appearence too much, im sure updated bumper skins will be a part of it but the thing is gorgeous as is, dont wreck it just to be different
-rear usb ports
EVs are nice when the battery is fresh. Not so much when you have to find a landfill and then the earth has locales where these batteries start leaching the nasties into water and the ecology.
ELIN (11-18-2022)
Realistic changes they should actually make
- wireless carplay
- fix wireless charger
- fix puddle lights
- add ELS signature edition from the MDX as an option (and include / option in Type-S)
Unrealistic changes they should make but wont because they're honda
- more power from the type-s motor
- larger brakes for the type-s
- better shift logic in manual mode (stay in manual mode)
- LEDs on rear doors, looks cheap to leave them out.
- usb charging and/or power ports in rear
- wireless carplay
- fix puddle lights
ELIN (11-18-2022)
I like how you broke down your lists!
My comments next to yours in bold below:
- wireless carplay It made it to the RDX MMC. Can't see why it won't show up on the TLX
- fix wireless charger Harder fix for MagSafe phones as I can't imagine it would be that cheap to satisfy iPhone users
- fix puddle lights This may fall to the list below unless longer term owners can confirm the latest fix is permanent
- add ELS signature edition from the MDX as an option (and include / option in Type-S) The smaller TLX interior is not quite as cavernous as the MDX's. I think current 3D ELS system is just fine.
Unrealistic changes they should make but wont because they're honda Largely agree with this list. Purely economics-driven.
Adept Acura Enthusiast
My list is as follows
- 2024 TLXs should be offered with the A-Spec Advance Package and Type-S Advance Package (Seeing as it is offered on the 2022/2023 MDX and RDX)
- Bump the HP levels slightly for the 2.0T I4 and the 3.0T V6
- Digital gauge cluster needs to be standard, if not standard then restricted to the Advance, A-Spec Advance, and Type-S Advance packages. (Which allows for those who still like the analogs to still be able to purchase a TLX with analogs at the cost of not having all the features of the advance package)
Acura just admit you failed with the infotainment system and just redesign it. There’s a reason every competitor switched to touchscreen.
wireless CarPlay is a must for MMC
new wheel and bumper design. The exterior is perfect… just a minor update will be perfect.
hp is fine. Just update software. I’m sure the type s would open up with a simple tune.
more colors for the ambient lighting
more paint options
advance and an aspec model similar to the MDX
more paint options
more paint options
more paint options
I’ve called wrong people numerous times on the touchscreen of my Tesla whereas not once in my Type S. FWIW the touchpad is safer than a touchscreen, especially given the current screen placement.
If it was touchscreen or touchpad, I’ll choose touchpad every time. Maybe they can move the screen closer, add a digitizer, and rewrite the entire software to please the touchscreen lovers by utilizing touchscreen AND touchpad. But touchpad > touchscreen for driving.
And frankly, I use CarPlay 99% of the time I use the infotainment system, so optimizing for CarPlay is way more important than optimizing for the native experience.
djhtsx (11-19-2022)
6G TLX-S
(1) Much reduced curb weight.
(2) Much higher engine output.
Pguan (01-26-2023)
Touchpad + CarPlay is infuriating to use. It's arguably worse because you still have to look at the screen to see where the cursor is, and you have to take your eyes off the road for longer because it takes longer to do anything with it.
Using CarPlay in the Type S feels safer while driving than the CTR. The only good thing about the touchscreen is having to navigate through maps. People are so used to having touchscreen that anything else seems foreign and unpopular. We’re set on our old usual ways.
Integra Type-S may be the way to go honestly. Sure, it won't have SH-AWD, but for the people who hate the TTI (I personally like it), the ITS will use the same touchscreen as its Honda Civic cousin. Hopefully, the ITS gets more aggressive looks (wider fenders and tweaked front/rear fascia ... no ridiculous wing) and the K20C4 (Accord 2.0T). No way it gets the C1 (CTR), but it would be nice to have a manual or at the very least the beefed up 10AT from the TLX-S (pipe dream). If they were to do that, the ITS will be at the top of my list.
From watching a bunch of YT videos, the new CTR, though much mature looking, goes the opposite way with its suspension, going overly stiff for track boyzz to gloat over while 95% of them will never go within 100mi of an actual track/road course. I imagine the ITS will be much more compliant for street use, though they sadly didn't do much in the way of isolating road noise over the Civic.
Plus, the hatckback design of the Integra allows it to be pretty practical and has more rear legroom to put rear-facing car seats.
Just a few things for me, personally:
- Some weight loss
- A bit more power from the 2.0T
- A more responsive and snappier transmission - I've said it elsewhere around here, but the ZF 8-speed used so much in other luxury cars sets the bar really high for automatics. That should be the target to be met, if not exceeded.
Pguan (01-26-2023)
Air Vice Marshal
If Acura wants to do something with the Performance Manufacturing Center, how about a true performance TLX-S instead of play with paint.
Carbon fiber fenders, hood, door skins and decklid to save weight and a performance boost for the V-6 would be a good start.
AZ Community Team
Received 1,619 Likes
Agreed! I think it's a great opportunity for Acura to boost these PMC models with more power and features rather than carbon side mirrors. I personally think it's a waste of resources and opportunity. they have the talent, resources and already a good vehicle lineup. Make them the best
mike03a3 (11-22-2022)
contourrob
06-16-2019 09:12 AM
23109VC
08-30-2010 11:42 AM
