2021 Acura TLX Test Drive Impressions
Old 10-03-2020, 11:49 PM
  #121
Honda430's Avatar
Originally Posted by fiatlux
Do you mean downshift? Why would the transmission upshift when you're calling for more power?
Moving fron second to third is upshifting I believe. Maybe its throttle lag. What happens is that you're in second and you want go faster. Well there can be delay because I believe the throttle is not telling the engine immeadiately that you want to go faster. Now that I spelled it out for me let's call it thottle lag.
RedOctober (10-04-2020)
Old 10-03-2020, 11:51 PM
  #122
Honda430's Avatar
Originally Posted by Carnage719
Correct. By no means is it perfect, but it was good enough that I chose my 2018 A-Spec over an Audi A5 Sportback. However, Honda430 swears the 2018-20 ZF9 is trash from his ownership experience.
I thought it did too much shifting, but goodness was it better than the 2015 which was borderline dangerous to drive.
Old 10-03-2020, 11:56 PM
  #123
mapleloaf's Avatar
One other thing I noticed that I hadn't noticed on my first test drive. The car always defaults back to normal mode when you restart the car. In the 1G, if you have it in Sport it stays in Sport the next time it starts up. Kind of annoying to have to change drive modes every time, but I guess other cars are the same. Wonder why they changed it from the 1G.
Just to clarify, the 1G doesn't default back to the last setting used if changed while driving, but rather the mode you select in the settings menu. I suspect that's what you meant to say.
Neoforever (10-04-2020)
Old 10-04-2020, 12:00 AM
  #124
Honda430's Avatar
I went for another test drive to see if the lag is present in a second car. Surprisingly, it was a lot better in this one (also a SH-AWD Advance). It was still noticeable and took longer to get moving than I would like, but it was considerably better than the first car. Whereas in the first one, it was a deal-breaker no matter how good the rest of the car was or how cheap it was, I could live with this one without wanting to send the car off a cliff every other day. I mentioned this to the salesperson, so we tried out two other cars. One drove just like the one I had just driven (mild amount of lag), but the other one was just like the first one I drove with a ton of lag. Both SH-AWD models. Even he noticed it too, but brushed it off by explaining that it'll probably go away once the car is broken in and the transmission ECU (think he meant TCU) learns my driving habits. I have my doubts...
This is shaping up like the ZF9 issue all over again, where some owners had stupendously bad transmissions, while others had moderately bad ones.
Autostop is not engaged in sport. I'm thinking not letting the car remain in sport once the engine in turned off may have been some requirement dictated by EPA. Regardless it's not that big of a deal since you just flck the mode knob to put it back in sport or press the button to have it default to your individual setting.
Old 10-04-2020, 12:04 AM
  #125
Honda430's Avatar
Accept for sports +.
Old 10-04-2020, 02:03 AM
  #126
ESHBG's Avatar
Originally Posted by SRB-TL
Acura dealers think this car is something special. It's not. Pretty soon we'll see 2 week production halt so the dealers can move the overflowing lots.
I'm wondering if they did/will even produce enough for this to be an issue.
Old 10-04-2020, 07:37 AM
  #127
loki's Avatar
Originally Posted by Honda430
There’s very little turbo lag. I believe what he’s referring to is actually transmission lag. You can’t feather the throttle when driving that car or the RDX. You need to apply firm steady pressure. If you don’t it takes the transmission a bit to decide you want to upshift and you get the lag.
No, I'm referring to turbo lag. I've had turbo cars for 20 years, I know them very well. I'm talking about when I smash the pedal off the line, it reminds me of 1983 MB where you crawl, crawl for about a second or two and then it takes off. Which also sucks (acceleration). Trans lag is also quite noticable but the turbo lag was so bad I didn't even pay attention to trans. Pedal shifter inputs are very delayed too. Fake engine noise is there even when radio is loud. But all that aside, turbo lag, turbo lag, turbo lag. It's awful. It's almost full two seconds before you feel that you are overcoming it. This car not only it has no business being touted as a sports car but legitimately could be unsafe if you're trying to get out of someone's or something's way. With that much turbo lag and transmission delay, you're bound to run into unsafe situation.
The following 3 users liked this post by loki:
04WDPSeDaN (10-04-2020), pyrodan007 (10-04-2020), RedOctober (10-04-2020)
Old 10-04-2020, 07:39 AM
  #128
loki's Avatar
Except there is no sport+ (or sports+ ) mode. Shows how much time you spent with the car you dropped $50k+ on.
Get many blonde smiles yet?
Old 10-04-2020, 08:33 AM
  #129
fiatlux's Avatar
Received 3,436 Likes on 1,884 Posts
No, mine stays in sport mode even if I select it while driving.
Old 10-04-2020, 08:37 AM
  #130
fiatlux's Avatar
I’m confused, if you’re in 2nd gear and want to go faster, why would it upshift to 3rd gear? It should either stay in 2nd or downshift to 1st. Unless your car is broken, it should never immediately upshift when you want to accelerate. The higher the gear, the less torque multiplication you get.
The following 2 users liked this post by fiatlux:
Neoforever (10-04-2020), pyrodan007 (10-04-2020)
Old 10-04-2020, 09:02 AM
  #131
Carnage719's Avatar
Is this a Canadian requirement? When I purchased my 2018, I only set my driving mode from the IDS switch on the center console, never in the vehicle settings. My setting is always on Sport every time I start it, but if I set it to Econ, Normal, or Sport+ (from the IDS switch), that's what it is the next time I start it.
Old 10-04-2020, 09:20 AM
  #132
Honda430's Avatar
i was referring to the TLX-1. There is no sports + in the TLX-2. No blondes, but I was en Hollywood last night where some type of Iranian street festival was taking place. Tons of high end vehicles. I didn’t feel out of place. I thought that looks wise the car held its own
Old 10-04-2020, 09:24 AM
  #133
Honda430's Avatar
I was confused. I believe the issue is with the drive by wire sensors that interpret peddle input. They seem to communicate best with the engine when you provide firm pressure on the peddle.
Old 10-04-2020, 09:26 AM
  #134
fiatlux's Avatar
I’m not sure how much firmer you can get than putting the pedal all the way to the floor, unless you’re saying that you need to be more smooth with the accelerator for the car to respond quicker?
In any case, I don’t think it’s a pedal response issue. If you put the car first into the appropriate gear and mat the pedal, the car responds immediately. It’s almost 100% a transmission issue because the lag comes from how long it takes to downshift, and then a subsequent delay in power before it really takes off.
Old 10-04-2020, 09:27 AM
  #135
Honda430's Avatar
Exactly, smooth input provokes a quicker response. Also I suspect there’s some nanny logic built into the programming so that if you press down hard on the peddle abruptly it’s going to delay just in case your foot had slipped off the break and onto the accelerator.
Old 10-04-2020, 09:30 AM
  #136
fiatlux's Avatar
Seems like a poor design choice then. In every other car, the immediacy of power is directly related to how quickly and how deeply you bury the accelerator. In no other car would you expect the car to respond and accelerate slower because you were too fast on the throttle.
pyrodan007 (10-04-2020), Tesla1856 (10-04-2020)
Old 10-04-2020, 09:33 AM
  #137
Honda430's Avatar
It might be, but that’s the way it seems to work. RDX has the same tendency.
Old 10-04-2020, 09:35 AM
  #138
fiatlux's Avatar
I know. Acura engineers already said they limit torque in the lower gears to protect the driveline. It wouldn’t be a stretch to assume the same issue exists in the TLX, and that the slow downshifting is also to protect the driveline.
Old 10-04-2020, 09:50 AM
  #139
Beaverking's Avatar
whats the chances this is prominent in type s vs being fixed because of the extra power?
Old 10-04-2020, 09:57 AM
  #140
AZ Community Team
Legend2TL's Avatar
Received 4,237 Likes on 2,617 Posts
DO you have a URL or Acura PR that states that?
Old 10-04-2020, 10:21 AM
  #141
Taz69's Avatar
This 10 speed transmission has been in the Accord for years. The Accord has no lag. Also I have not seen any transmission failures yet. So it can be programed to downshift and work just great. The Accord 2.0T also has very very little turbo lag. So if you driving an Acura product and it has those tendencies it was programed in there. I know my wifes 2018 Santa Fe Sport limited (2.0T) Has this exact lag you are taking about. Slow down for a car and jump on the gas it has a delay. Turn sharp right or left from a stop it has delay. When I asked a mechanic why the Optima 2.0T did not act this way he said on the SUV they program something called torque limit power on demand. It pulls back power and if I drove with a scan tool I would see the pedal and engine inputs would be way different. Its a nanny and its there to keep you from spinning your front tires in a big top heavy SUV with FWD. To me its a danger my wife barely notices it. I tried a pedal commander and it did nothing for the delay. My mom drives a Ford edge titanium 2.0T and it has no lag. So every car make is different. These turbo 2.0T engine make so much tq down low that (like the Accord) if you are not careful with the throttle and panic and jump on the gas pulling out in traffic it will smoke the tires. Biggest complaint of the Accord is that it spins the tires real easy and you can look kind of dumb if you are not carful on the throttle.
Old 10-04-2020, 10:43 AM
  #142
Azine Jabroni
kurtatx's Avatar
Received 2,159 Likes on 1,387 Posts
Originally Posted by steve_97060
wrong, my 2019 drives great.
Yeah, but it would be a hell of a lot better with a ZF8
Acura strives to compete with the big boys, but won't pony up for the big boy auto. It's really unfortunate.
Old 10-04-2020, 10:45 AM
  #143
Carnage719's Avatar
That's different than "all ZF9s are bad."
Old 10-04-2020, 10:49 AM
  #144
Tesla1856's Avatar
1. I thought you previously mentioned you were once interested in the 1G TLX. Did you ever test drove a 1G A-Spec?
2. The sound is not muted while using the audio system.
1. I test drove the 1G 2020 TLX-V6 Tech/SH-AWD . Very nice car. Quick and fast (none of this lag business).
The only problem I saw was:
a. Out-dated Infotainment (same as our old 2014-MDX )
b. It was black (so wrong color ... no more black cars for me)
2021 TLX was suppose to be all-around better.
2. Thanks for report. This issue is so bizarre.
Old 10-04-2020, 10:59 AM
  #145
mapleloaf's Avatar
That's odd. My car is set for Eco mode to start off my drives and I usually end in Normal or occasionally Sport mode. The next time I get in it's always in ECO. Same thing when I had it set for Normal as the default mode. I'll have to play with it today to check this out.
Old 10-04-2020, 11:00 AM
  #146
Carnage719's Avatar
The sound is not annoying or droning, you just know it's not your real exhaust note.
Old 10-04-2020, 11:05 AM
  #147
Carnage719's Avatar
I never set anything in the vehicle settings and only use the IDS switch on the center console. If you set Eco (or any other mode) in the vehicle settings as the default, that's probably why the car always starts in that mode.
Trying clearing what you have in vehicle settings and make the selection from the switch on the center console and see if that duplicates what we're saying.
Old 10-04-2020, 11:07 AM
  #148
mapleloaf's Avatar
Could be, but not sure why that would exist. I actually prefer the default mode as I like to start out the drive in Eco, particularly when it's residential driving, which I usually don't end with. Time to experiment today and report back.
Old 10-04-2020, 11:16 AM
  #149
Carnage719's Avatar
Ok, I figured it out. In vehicle settings, the four modes are listed that you can choose the car to start in...including "Last Used", which is how mine is set.
Old 10-04-2020, 11:33 AM
  #150
Tesla1856's Avatar
It's annoying to me, and I don't even own the car (yet).
It would be nice if someone knew:
a. Where it is coming from.
b. How it is being generated.
c. How to turn it off.
Old 10-04-2020, 11:52 AM
  #151
RedOctober's Avatar
....I was en Hollywood last night where some type of Iranian street festival was taking place. Tons of high end vehicles. I didn’t feel out of place. I thought that looks wise the car held its own
Why do you care what random people think about your car? I never buy car for other people to look at... This is strange argument...
Old 10-04-2020, 11:57 AM
  #152
Azine Jabroni
kurtatx's Avatar
If he didn't care about what the car looked like, he would have bought the Accord (a better, cheaper car)
Old 10-04-2020, 12:01 PM
  #153
alpha0's Avatar
I saw a thread on 1G forum about sprint booster helping with this delay, hope they can reprogram 2G also.
Old 10-04-2020, 12:03 PM
  #154
fiatlux's Avatar
It was in a post here on AZ, someone had talked to one of the Acura engineers at an event for the RDX. Don't remember which thread it was in, probably in the 3G RDX forum.
Old 10-04-2020, 12:10 PM
  #155
Honda430's Avatar
Isn't that what car styling is all about? I think a large portion of the car buying public wants to drive something that attracts attention. At least that tends to be the case here in Los Angeles.
Old 10-04-2020, 12:12 PM
  #156
Azine Jabroni
kurtatx's Avatar
Yup. I think that's how they're sold.
Once you own it, though, who cares what the car looks like?
  #157
Honda430's Avatar
From the pictues here I think you drive a Model 3. In my opinion there are few cars on the road that are uglier both inside and out. For me it would be Model S or nothing.
Old 10-04-2020, 12:13 PM
  #158
Carnage719's Avatar
I'm saying the V6 sound isn't annoying, I actually like it seeing that the V6 is otherwise so quiet. I have no experience with the sound being piped in on the 2.0T
Old 10-04-2020, 12:16 PM
  #159
fiatlux's Avatar
LA is it's own special kind of place. I used to live in Brentwood, and the amount of vanity going on there is unparalleled.
Old 10-04-2020, 12:20 PM
  #160
Carnage719's Avatar
Unless someone's taking his picture at the GAS pump, it's spoofing EVs.
Quick Reply: 2021 Acura TLX Test Drive Impressions
