Vibration and engine movement
Old May 15, 2020 | 07:49 AM
TLXionian's Avatar
hey guys, long time lurker new poster here. I having issues with cobsistent vibration on the highway. With my 2019 2.4L Aspec that I have had for a year now. I'm aware of the low idle speed (650ish rpm) when fans are turned off and vibrations that 4 cylinders have. This is something else. I feel less vibration at idle and more when I'm at cruising speed from steering wheel gas pedal, shifter. The tire balancing and alignments is not the issue. Took it to a dealer and ofc they say it's normal and the tech who took it on the highway said the car is one of the smoothest he drove. I took a video of the engine movement when I press brake and gas at the same time when the car is in D. Is this amount of movement normal ?
https://youtu.be/mUEbULniHak
This vibration just started to happen and is definitely not in my mind. Lol
Thanks for your inputs !!
Old May 17, 2020 | 08:27 AM
TSXV6Guy's Avatar
The movement of the engine as per the video is normal. Since it's a 4 cylinder, I presume it's not the dreaded TLX highway vibration per say.
With vibrations, I would always start with wheel balancing... Even if the dealer says it's "good", there are multiple causes of wheel imbalance.
It could be as simple as out-of-calibration balancer (many are out of calibration...) Also, you may have lost a weight.
Also, it could be flat-spotting of the tires (may go away once you drive for 10 minutes on the highway).
You can try switching tires front / rear to check if there is a change of vibration pattern, and even find a good tire shop that has a road force machine and try that.
jmm3807
ILX
Mar 18, 2017 09:57 PM
nyblue
4G TL Problems & Fixes
21
Mar 30, 2014 02:52 PM
JTS97Z28
Sep 24, 2009 01:04 PM
hershey1000
Jan 1, 2007 07:14 PM
cheese
1G TSX Problems & Fixes
17
Nov 21, 2006 02:34 PM
