TLX Not Starting After Filling up Gas
Hello, I have been having trouble with my car starting after filling up the gas tank. I only use premium 91 gas in it, and always put the nozzle on auto-fill and never top off the car and usually fill up when I have about 1/5 a tank left. The car tires to crank but will not start, and it takes a few tries of cranking it to finally turn on. This only happens at the gas pump right after I am done filling it, and never happens any other time I start my car. Car is a 2015 Acura TLX V6 Base with 40,000 miles. This problem only started happening in the last few hundred miles. I am planning on taking it into the dealer this week, but a little worried they might have a hard time diagnosing it. Sometimes it will start on the 2nd try, sometimes takes 3-4 tries
Hopefully they can resolve the issue. I'm at 42000 miles and actually had trouble starting it just a week ago. My first attempt didn't work for some reason, but second was no issue. I had thought maybe I didn't push the start button down enough, but honestly can't remember what had happened now.
Did you have trouble after filling up gas also? I thought I was not depressing the brake enough at first so it wasn't starting, but I started to really pay attention since it kept happening at the gas station and that was not it. It tries to crank so I know the battery and starter are okay (it also starts fine every single time outside of the gas station). I took it to the dealer yesterday with about half a tank left, and they took a look at the video I made of it happening. They made an appointment for next week and told me to bring it back with the gas tank close to empty. The car already had the fuel pump replaced ~10,000 miles ago since it was making a chirping sound
Haven't experienced it again and hopefully don't. Hopefully don't have to replace my battery soon.
I took my car in to the dealership this past week with an empty gas tank. I went with the tech to the gas station, and with my luck it started just fine. However, there have been a couple times after that the car has not started on the first try at other locations besides the gas station. The dealership tested the battery and it came back okay. They are going to replace the starter on the car, they ordered it and will do the install next this coming week. I'll keep you posted if that fixes my issue
As previously mentioned the likely cause is the battery. A 2015 TLX battery could actually be 4 years old in your car or more at this point in time. With all the electrical devices especially auto idle stop, puts a tremendous strain on the battery. The smallest weakness in the battery (even if cranking appears normal) will often cause the vehicle not to start. Why does it happen when filling up? Possibly due to being shut off for 3 or 4 minutes, engine heat soaked making starting more difficult. It would probably also happen if you ran into a convenience store for the same amount of time. My suggestion would be: Clean the battery posts and put battery on a slow charge for 24 hours or more. Then immediately drive to the gas station to fill up and see what happens. NOTE: Make sure you use a charger specific for AGM batteries. Most likely it's time to replace the battery.
I don’t believe it was an AGM battery I replaced it with. I have a V6 Base model and it does not have idle start/stop so I don’t think that is necessary for my car. I got an Interstate battery from Costco, the flooded lead-acid type. The specs on it where better then the original battery in the car. Correct me if I’m wrong, but I’m pretty sure the battery is different between the base model and if you have one with auto start/stop
TLX V6 AWD comes with an AGM battery and a cooling fan and some battery management sensors etc. This is primarily for the auto engine start stop "feature" that many of us turn off as soon as we start the car.
Check voltage at battery. If is below 12,0V recharge it. If do not start again check negative to body of starter voltage drop, and positive to B+. Voltage drop in this case is possible test without car running how much I remember. One is sure, without testing you all are just guessing. Test that all would take me less than 5 min.. How you folks do not understand if you work at car multimeter is a must as is code reader.
