interior temp gauge for AUTO setting
Old Feb 23, 2015 | 03:23 PM
miner's Avatar
I think my interior temp gauge needs to be adjusted. I have to set auto temp on 82° to get any heat flowing and then once temp is reached it will begin to flow cooler air. On my RLX if I set temp at 76° then it remains there comfortably - no excessive air flow to cool cabin down once it has reached programed temp. I really think Acure missed the target on the auto temp settings with this model - I have the V6 Adv. Has anyone else experienced this failure and is there a fix for it?
Old Feb 23, 2015 | 03:57 PM
Quandry's Avatar
Isn't this the same issue as the previous thread that you posted to here?
https://acurazine.com/forums/problem.../#post15254633
Old Feb 24, 2015 | 08:48 AM
bdwpac81's Avatar
Yes, I and others here have experienced the same problem. You should be able to find my previous threads on this forum. Despite evaluations by the dealer, I have been told that there is nothing wrong with the vehicle. Sometimes, I have to set it to 80 degrees just to get an actual temperature of around 70 degrees inside the cabin. One day, it was around 20 degrees as I pulled into the dealership garage and cold air was actually blowing from the windshield area vent. How they call this normal is beyond me. I've tried to overlook it since I'm stuck with this car for another few years and want to make the best of the situation. Please call Client Relations and advise them of your experience.
Old Feb 24, 2015 | 09:32 AM
CheeseyPoofs McNut's Avatar
If you leave it on auto you get heat coming from the bottom and the defroster running on top which pumps cold-ish air out the windshield vents - this tends to feel feel cooler than I like.
I turn mine off auto and set the vents for upper and lower and she warms up quite nicely.
Old Feb 24, 2015 | 11:03 AM
bdwpac81's Avatar
Thank you for the advice! I'll give it a try!
Old Feb 24, 2015 | 11:25 AM
CPR's Avatar
CPR
Make sure you have your fan speed set to Auto; when I 1st got the car, I thought the temp needed adjusting, until, I clicked on the fan speed on the Nav. screen, & changed the setting to Auto; works great now at 72*, synched; even in our NYC winter cold
Old Feb 24, 2015 | 12:13 PM
miner's Avatar
Yep, sure was....
Old Feb 25, 2015 | 08:03 AM
crownr0yal's Avatar
I'm currently in a loaner RLX. The RLX at 74 feels like my TLX at 80. It's so weird.
Old Mar 6, 2015 | 07:35 PM
Rocketsfan's Avatar
This is what I do. I have a shortcut set for my preferred temp of 70 degrees with "bi-level" mode where the air blows from top and bottom. Things warm up just fine. I also have it set to recirculate the air with this shortcut.
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
braveheart
Sep 7, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
