Headlight Problem Warning Sign
Hello, first time poster here. So, I have a 2016 Acura TLX SH-AWD Tech pack, and recently it's turned on the "Headlight Problem" warning sign. I been looking around for possible solutions, as I wanted to isolate any fault that my car may have before I replaced the entire headlight. It is my understanding that newer headlights don't really go out like that, unless there's some underlying issue.
- It is the driver side headlight (for reference)
- The high beam and turning signal work
- For some reason after driving it for an extended period of time the headlight will turn on and the "Headlight Problem" sign will go away, but as soon as I turn the car off the sign comes back up, and the headlight turns off
- I have already tried disconnecting the battery
- I read somewhere that it might be the lowbeam fuse but it seems like that might not apply here as my other headlight works perfectly fine.
