Difference Between Lane Departure Warning and Road Departure Mitigation?
Anyone now the difference between LDW and RDM??
They seem to use the same control on the lower left to turn both features on or off.
I get the lane departure warning if I get close to the side of a lane.. When does one work versus the other? RDM is supposed to vibrate and possibly brake.
Can soneone expkaint he actuak difference of these 2 which go on together.
Thank you
Mike
Thank you
Mike
Dashed Traffic Lines on Nav
Does anyone know what the DASHED traffic lines on the Nav Maap are?
The solid ones I see and then in some places they are dashed... there is nothing in the manual about this...
Mike
Mike
The red and green (and possibly yellow) lines on the map, indicate traffic flow conditions. A solid line indicates a recent update, while a dashed line represents an older update that may no longer be accurate.
MikeRadio (12-27-2015)
If you do a search on this forum you will find all your answers, but here is a short explanation:
Only Advance/Elite have RDM and it is a superset of LWD (one set of controls)
LDW: may only warn when a line is crossed without using the turn signal
RDM: may will shake the steering and may apply braking, if set for Normal or Wide (see p113, p129, and p378)
Dashed lines are only displayed if you have AcuraLink Real-Time Traffic subscription. They indicate that AcuraLink has not been able to determine traffic conditions on that road.
AcurAdmirer
I wondered about those dashed lines years ago, and the best I could determine, they were kind of like "breadcrumbs", indicating routes taken previously.
There are two types of dashed lines. If I remember correctly the ones with the subscription service are in green and show for any roads that are displayed even if a route has not been set. It is quite distinctive from the lines without the subscription service.
My subscription has expired so I cannot take a photo.
Color-coded interstates, expressways and busy side streets indicate traffic flow levels.
Helpful icons identify traffic incidents and traffic conditions affected by construction and weather.
The system can list traffic-impacting collisions and construction zones in your surrounding area.
If an alternate route is at least two minutes or 10% quicker, Traffic Rerouting™57 will suggest it."
I just bought a TLX and called and was told that 3 years of the "standard" AcuraLink service (which includes traffic info) was included with purchase of the vehicle. A 90 trial of the "premium" and other higher level subscriptions were available but required me to provide a CC number which I was unwilling to do. There was no CC required for the included "standard" 3 year subscription.
Back to Lane Departure Warning....
MANY times I can change lanes without signal or get close to the side of the road line without getting a warning at all. I'm going over 45 MPH but nothing.
The camera works because the lane keeping assist does show the lines are being seen if I turn it in. But LDW does not work very often with it off.
Is this the case for others?
Mike.
Mike.
Torch & Pitchfork Posse
LDW is an audible alert when crossing lane markers.
LKAS will add torque to the steering wheel to assist keeping the car in the lane.
RDM is a combination of the 2 above PLUS it will shake the wheel to alert the driver and may add braking to lessen a crash from departing the road.
The key for all 3 to function is that the car must recognize or 'see' the lane markers with the camera. In the MID you see lane markers when the system(s) are turned on. When the lane marks are hollow, the car does NOT recognize the lane markings. When the lane marks are solid, the camera is detecting the lane markers.
As you noted, it works above 45mph, but it is disabled in rain (when the wipers turn on - manually or auto), and other conditions. You do not need all 3 engaged and can 'layer' the amount of Acura Watch you choose.
Curious3GTL (01-24-2016)
DJMikeT
12-28-2015 10:35 PM
dizzie23
12-23-2015 11:24 AM
peekay81
Texas
12-22-2015 08:40 PM
RU_JELLY
12-20-2015 07:03 PM
