Braking System Problem and other errors pop-up....dealer wants $4,000 to fix!!
Hello, this is on a 2015 TLX V6...When I turn on the car I get these errors on the dash. Has anyone seen this? Dealer wants $4,000 to fix!!!
1. Braking system problem
2. Brake hold system problem
3. Vehicle stability assist Problem
4. Hill start assist problem
5. Lane keep assist problem
6. Power steering system problem
Some Guy Who Loves Cars
Omg I hope it’s less than 4years since the date of manufacture of your TLX and you’re currently under 50,000miles. That needs to go to the dealership. Probably a transmission or speed sensor problem. I think there is a TSB for that. Search the TSB log for those symptoms.
go to a shop that has the Honda diagnostic system (HDS) or buy a copy with the double board and cables from ebay and read the codes. Normally a bad wheel speed sensor, low battery or being low on brake fluid can cause these issues. When is the last time you replaced the brake fluid?
I think you’re on to something about it being something else...how can both actuators go bad at the same
time? I’ll try another dealership maybe and see what they say!
It wasn’t a TSB. I recall these symptoms from several past threads. Check these out. I’d be very curious to see what $4000 fix your dealer had in mind if it’s actually $170 fo a few faulty sensors...
https://repairpal.com/estimator/acur...placement-cost
https://www.rockauto.com/en/catalog/...ed+sensor,1912
https://acurazine.com/forums/5g-tlx-...ailure-931335/
https://acurazine.com/forums/5g-tlx-...raffic-977984/
Don’t assume it fixed itself or won’t keep happening again and again.
When my battery was dying/dead, my car would throw all these errors on the dashboard too. Maybe check the voltage of the battery to see if it's >12.5V at rest.
As crazy as it sounds when my car was experiencing a similar issue it ended up being that I had my Sunpass (toll road device) under the rear view mirror. Once I moved it to the far upper left of the windshield all of the warning messages stopped.
Thanks for the tip! We have a sticker where I live but I’ve had that sticker installed for three years.
Update: Took it to another dealer and he said the issue is rare but they've seen it for 2015 TLX since they were the first model. Also said if the message is not popping up that means the parts are working fine. We will wait until the messages come up more often or all the time since the second dealership said its possible you never see it again.
Thanks for the links! Dealer planned on replacing the rear actuators....$1600 a piece + taxes + install is $4,200. In a few of the comments, folks did mention they had their actuators replaced but luckily for them - they were under warranty. I'll take it to another dealer and see what they say.
BTW, if you take it in, you may want to print these 2 out as a suggestion for what to look for (they should know). Also note neither of these may apply to you, but they should at least do an inspection for them :
http://www.urvi.net/forumfiles/SB/B15-041.PDF
http://www.urvi.net/forumfiles/SB/B15-050.PDF
Note in the first link, it specifically says that the error code they should be looking for may not be present when you bring it in. Like I said, in some situations, the errors go away -- that doesn't mean the problem isn't present.
Rocket_man (06-25-2021)
OldZaskar
3G MDX (2014-2020)
06-26-2019 05:41 PM
gadgetinspector
09-16-2007 06:08 AM
