brake fluid
Old Sep 9, 2019 | 09:37 AM
noclue02's Avatar
brake fluid
Hi guys,
Just curious on if it is alright to add any Dot 3 brake fluid to the current fluid I have? My brake pads are wearing down, but not to the point I need it to replace yet. The brake fluid tank is low, wonder if I can just get any and add to it until I get my brake pads replace? Dot 3 brake fluid is the same as any right?
Old Sep 9, 2019 | 10:03 AM
losiglow's Avatar
Yes. Brake fluid is grouped according to specs it has to meet, regardless of brand. Kind of like oil with API rating. Just pick up some Autozone or Walmart DOT3.
You can also add DOT4 instead. It has a higher boiling point and is compatible with DOT3. Or if you want to go fancy, DOT 5.1, but that's probably not necessary. Just don't do DOT 5. That's not compatible with 3, 4 or 5.1.
Old Sep 9, 2019 | 12:13 PM
noclue02's Avatar
Thank you =) just want to double check.
fujiteam
1G TSX Problems & Fixes
May 27, 2011 02:28 PM
TSX 3Pedal
56
Nov 17, 2006 10:41 AM
bim6180
May 18, 2006 10:43 AM
Got_3.2?
Jan 28, 2005 12:36 PM
RaptorCLS
Sep 26, 2004 04:57 PM
