9AT Hard Shift 1-2 and 2-3
#1441
I have a question, for those of us with new tranny's have you ever driven a 2016 model and compared the differences? Both shift smooth but how about shift points and acceleration and highway performance? Does the 2016 have a different program than we do? After my tranny was changed and I put on the lw crank pulley the car flys now. I think for some of us that have new tranny's and smooth shifting ones a new program will need to come out to change the behavior. The 9 speed kind of Act like the 6 speed in my 3.7. Probably the same programming was used but modified.
#1442
I finally had the latest transmission software patch applied to my car during my last service several weeks ago. My tranny was shifting fine, but it was part of the service action regarding shifts into neutral. I am really happy I got the software update.
My transmission would occasionally muff the 2-3 shift, and my attention would be drawn to the transmission. Since the latest update, the shifts have been perfect, and I am never drawn to the shifting. A/T's should just do their job without being noticed, and mine is. The biggest improvement was in downshifts on the highway. That delay used to be my biggest complaint.
The following 2 users liked this post by Mr Hyde:
moy_tls08 (03-02-2016),
Rocket_man (02-27-2016)
#1444
I've been posting the petition link on Acura Canada's Facebook page and they keep removing lol....
https://www.change.org/p/jon-ikeda-t...-transmissions
#1445
I am on the same boat with 9 speed transmission. The transmission is lagging on acceleration and 1-2 tranmission is hesitating. Took to dealership and was told tranmission is acting normal. Called ACR and they denied any defective tranmission.
#1446
Why did the dealer look at my car, having the same symptoms, for 2 days and then after contact with ACR, the dealer and district rep approve replacement, while others get stonewalled for months.
Anyone know or want to venture a guess?
#1448
Summer is Coming
TSB 16-012 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds, and Other Listed Symptoms
2015–16 TLX V6 2WD with 9-speed A/T 19UUB2…FA021489 and later
2015–16 TLX V6 AWD with 9-speed A/T 19UUB3…FA007728 and later
I'm in this range too and debating if it is worth the risk. I mostly suffer from shift lag.
#1449
Old Man Yelling at Clouds
I just got my Consumer Reports magazine with the 2015 car data in it. No surprises in here but I feel a bit more validated.
2015 Acura TLX overall review: Reliability rated "worse" (lowest score), Satisfaction above average. From the narrative, "The V6 is a gem, with plenty of power, but it's nine-speed automatic shifts roughly...First year reliability has been much below average."
It had the lowest overall score in the Luxury Compact segment largely driven by it's "worse" score for predicted reliability.
When it broke out the scores for individual trouble spots, the car actually got "better" (the highest mark) for everything but transmission (which was below average).
I'll guess a lot of the data may be driven by what people are bringing their car in for, so no surprise the transmission tops the list. Shame because the rest of the scores are very strong.
Interesting side note - when you read the comments of the MDX and Pilot who share this transmission, they said:
MDX: "...transmission is not always smooth or responsive."
Pilot: "Touring and Elite trims get a nine-speed that doesn't shift smoothly and is stuck with an unintuitive electronic shifter."
Also I thought the Jeep Cherokee also had this? This was the comment:
"The nine-speed automatic is not very responsive or refined."
#1450
I bet Honda is desperate to get the 10-speed into production. This was a limited drive back in Nov but promising:
Technology Preview: We Drive Honda's 10-Speed Automatic Transmission
It wasn't too long ago that a six-speed automatic transmission was state of the art. Then we got seven-speed, eight-speed, and nine-speed units. One of the nine-speeds, designed by noted transmission manufacturer ZF, has given multi-speed transmissions a bad reputation. Paired with four-cylinder and V-6 transverse-mounted engines in Fiat Chrysler Automobiles [NYSE:FCAU], Jaguar Land Rover, and Honda/Acura vehicles, it dithers instead of downshifting, sometimes clunks into gears, and barely ever reaches the top gear.
Given those shortcomings, it may not be wise for any automaker to build a transmission with more gears. And yet Ford Motor Company [NYSE:F] and General Motors Company [NYSE:GM] are teaming up to build a 10-speed, and Honda is developing one of its own. The plan is to use the 10-speed with the V-6 engines in large Honda and Acura vehicles, possibly in 2018 models. Honda says it will improve fuel economy by 6.0 percent over the current six-speed.
Prior to the Tokyo Motor Show in late October, I got the chance to sample Honda's forthcoming 10-speed at the company's R&D Center in Tochigi, Japan.
The car I drove was an Acura RLX, which was paired with a 310-horsepower 3.5-liter V-6 and a development version of the 10-speed. The test drive consisted of two laps around the facility's high-speed oval, which means I spent just a few minutes in the car. However, I was able to assess how this transmission acts in its current stage of development.
Both when accelerating from a stop and when fluctuating speeds, the transmission executed smooth shifts without delay. There was none of the shift shock that you get with the ZF nine-speed. I also eased along at about 70 mph to see if it would be able to get into 10th gear. That happened without a problem, and it was quite a weird sight to see 10th gear indicated in the instrument cluster between the speedometer and tachometer.
The oval permitted speeds up to 111 mph, and while I got up to that speed, I also slowed down to 70 then punched it to see how the transmission would react in a simulated passing procedure. Honda says the transmission can downshift up to four gears at a time, but during this test the transmission downshifted from 10th all the way to 4th. It probably occurred in two steps: 10th to 6th, then 6th to 4th, but it happened quickly enough that any driver would be happy with that performance on the highway.
My time with the 10-speed was too limited to render a verdict, and low-speed city driving would expose any problems it might have with indecision. However, based on this short drive, this transmission looks like a winner.
#1451
#1452
Picked up my V6 SH-AWD today after nearly 3 weeks at the dealer getting the transmission replaced and other items addressed. It's an early 9/14 build that I bought in Nov 2015, with 300 miles on it. I had the transmissions issues.
After driving it tonight, it feels like a completely different vehicle. The throttle response is instant and precise. The shifts are smooth and precise. I noticed that the tech noted he performed TSB 16-012, even though my VIN is not in the range, which tells me there is 100% a difference in hardware prior to a certain point. Downshifts are also very smooth and precise.
If anyone wants to know, the part number noted for the new transmission and torque converter is "06200-5L9-A59RM warranty A/T kit"
For anyone struggling trying to get theirs replaced, one thing I noticed is that the tech noted that after he rode with me, he contacted Acura's tech line and they did some step by step troubleshooting and did the relearn and also found some trouble codes. The tech line recommended replacement, and the district rep drove the vehicle and approved the replacement. Be sure to push the tech to contact the tech line and go through their debug process. It may take longer, but I think it's key to an approval and replacement.
HTH
HTH
#1453
It came in the actual magazine and I have a subscription - I believe consumer reports does not put a lot of that data on line. You might be able to buy it off the magazine stand - it's the April 16 issue (2016 Annual Auto Issue). Red Toyota Prius on the cover.
#1454
Congrats on getting the new transmission. Out of all the posts on this thread, your 2 previous posts seem to show how to get them to take action: Get the district rep involved, mention the lemon law, be calm and persistent. It's pretty clear the dealers are not going to voluntarily replace the transmission until you go over their head and up the chain.
#1455
#1456
Except for one thing - many of us have already been through the routine. The dealer tells you that it's "Acura" and that they can't do anything, and to call the ACR/corporate. Call ACR/corporate and they say "well, the dealership said they can't do anything, so we have to side with their judgement". So now you're on a merry-go-round. Some get told there is no fix and that all transmissions are the same, yet the people getting replacements and the 2016's don't seem to have the shifting problem. Some are lucky, some aren't with replacements. There is no "going over their heads". I'm sure they're working together to an extent. I've had the rep supposedly sit and ride in my car and say "it's normal" and nothing further can be done.
I can't tell you the specific data point or reason why I was able to get a replacement and others don't, but my guess is it's a combination of VIN (build date before a certain point) and getting the tech to verify the error codes with the tech line. Once he had the fault codes, and the tech line said it needed replacement, it all seemed to fall into place quickly.
I also think my specific language and discussions with the dealer and ACR also helped to set the tone, but who knows.
#1457
It's not luck. It's not random happenstance.
#1458
I'm not convinced that any special behavior on behalf of the owner make a lot of difference. I don't think threatening lemon-law actions or things like that mean a lot to them. Most people who threaten that likely don't follow up anyway and Acrua knows it. I think owners have to be insistent enough to bring the car back 2-3 times and not take the initial "no's" for an answer and get ACR involved. But I think once you get ACR and a field rep involved, you either have the codes they are looking for or you don't. I don't see that Acura is making any moves to make us happy just because we complain often and loudly. If that were the case I'd have a new transmission.
#1459
My own opinion on the entire topic is I think owners need to be persistent to have a shot at a fix. Persistence does not = fix. Persistence + car data that meets some unspecified criteria from Acura = fix.
So really my only point here is for the owners out there who've found this thread and have an issue and are looking for advice on what to do. IMO, they should not convince themselves that just pressing the issue by itself will produce results (and lets face it, a lot of people think that, myself included ). Apparently, something about the car also has to cooperate. At least, that's what it appears to be based on the replies.
#1460
Just to clarify, you are talking about this software update???...
As I said before, my attention is never even drawn to the transmission anymore, and I just enjoy the drive.
finebead (03-12-2016),
Rocket_man (03-06-2016)
#1461
Styl1n
#1462
CTSV,TL, Audi Q7 & A5SB
I had this update done Wednesday and drove it Thursday and today and man what a difference. Good power from dead stop and when coasting and Need to go it actually downshifts and go instead of staying In gear and just going like a cvt. When slowing down and need to switch lanes to pass someone's it actually goesssss lol Before it would wait a while then move. I think as they keep releasing updates the tranny well the ones with later build and replacements will get better.
#1463
Styl1n
yup I did and the shifts are super smooth can't even tell but any updates that is released I will always get them it only improves things and this car and it needs a lot of improvement on the shifting and response time. Even though my car shifts really smooth I still think some other TLX drive more aggressively than mine, even after idle relearns and ECU reset. Driving the car hard after doesn’t give it the fast response of the other cars I drove. I have never had so many issues with a car to just operate like a V6 and this is why I made a choice to leave Acura after my lease is up.
#1464
#1465
I discovered something "interesting". Decided to take my car in for another re-learn and used the dealer's on-line service scheduler (since his phone was perpetually busy.)
On the part where you indicate the reason for service there was a check box for "Transmission concerns". Once that is checked there are check boxes for "Transmission shifts hard when cold" and "Transmission shifts hard when hot" Guess that Acura has at least acknowledged there are some issues!
#1466
Styl1n
My vin didn't fall in the range but since I got a new tranny they did it, they should do it for yours, it horrible how many time we have to go to the dealers imagine how the car fax service section will look
#1468
Ok. Thanks. I'll print it off and take it in. Especially if you say you saw an improvement. Mine throws a rough 1-2 shift every once in a while, maybe just when cold
#1469
Styl1n
Cool I emailed the service advisor as well about mine and they did it. After your tranny was replaced did you have slow upshifts? Or sluggishness sometimes I notice mine is like that.
#1470
Sometimes it hangs a little before it shifts, but I remember my 12 tl did the same thing. I'd definately like to see it less reluctant to downshift when I step on it. Sometimes it acts like a cvt
#1471
Styl1n
Exactly like how mine is just like a cvt, when you take yours in for the update ask them for a v6 loaner and see if there is a difference
#1472
#1473
Summer is Coming
hmmm.... so if they were willing to put this software into a replacement TLX transmission... then I wonder if the TLX's in this VIN range have the same transmission as the replacement units? Otherwise why would the same software work in both units?
#1474
Good point..
#1475
Styl1n
#1476
Styl1n
I think depending on your build date its different transmissions, that why different TLX's drive more aggressive than some. I had some late build models that shifted rough but response was great then I had an early build model that had no rough shifting but was lagging in performance. I don't know what to say anymore I'm going get the dealer to buy this car back and get out of it. its crap knows that your TLX can perform much better and your kinda stuck with it.
#1477
Summer is Coming
But... I think this so called learning transmission needs to ditch the learning thing. It is just trying too hard. Don't need my transmission to think it knows how I want it to shift. I want to know how IT shifts.
Sorry you are so unhappy with the TLX. For me it is a great car for the price, but the transmission is a let down. I hope I can get the new transmission software this week if I can get away from the office.
#1478
Styl1n
It seems they made a change in the transmission around May 2015. My car is after that. Then I suspect the 2016's may only have new software and the recent TSB is bringing the later 2015 transmissions up to the same software as the 2016's. But this is just my guess.
and yes they need to disable this learning thing maybe ktuner or hondata can accomplish this.
#1479
Styl1n
yeah mine was an early build, I have owned 9 different Acura's (RDX was the best ) and the TLX V6 has a a lot of potential but its a let down on the tranny and the shifting program, even the head tech told me they made a mistake on this car and when he gets into a car he want to drive and feel the drive and when you step on the gas it just goes.
#1480
Yes we have a tsb that does pretty well to address it. We never had a bad 2-3 like you guys though.
