9AT Hard Shift 1-2 and 2-3
#1001
Old Man Yelling at Clouds
Just going back to the suggestion rgpolson made about using sport+ to illustrate the problem - I tried it several times yesterday and wow does that work. I never use sport+ mode so if others are like me, enter that mode and make the 2-3 shift happen between 2500 and 3000 rpm. What I got was a huge hesitation (maybe a full second) between commanding the shift and when it happened, and the "bump" was much larger than what I get in the automatic modes. In sport+, the 1-2 shift isn't very good either.
If I can't drive my tech around myself, I'm going to be sure to leave them those specific instructions. In my car, it magnifies the issue by 5x at least.
#1002
here's the link about DCT, in case any of you haven't seen it,
Dual-clutch transmissions stuck in neutral: Why American buyers are rejecting a once-promising technology | Autoweek
If the ZF 9 speed shifts felt like mine when driving a stick I would be OK, but they feel like shifts made the first time I taught my wife to drive a stick.
Abrupt shifts are only part of the problem. The hesitation in a rolling start scenario of down-shifts at highway speed are at least as concerning if not more so.
#1003
#1004
Update/FYI: Got a call yesterday from Kyle Green, ACR, in California; a follow-up, to my earlier complaints, concerns, etc.
Anyway, told him that the majority of the tranny 9 speed problem has disappeared, thanks to the new tech at my dealer
Also told him, that if Acura decides to replace the tranny, with a new version, I won't be upset, & would like to be informed, before the general public.
Right now the car is 75-90% better, & the tranny jolt, has all but evaporated
Lets hope it stays that way
9SpeedTran (12-10-2015)
#1005
#1006
So I started following this as 2 months ago I got a 9/15 build SH-AWD Advance and at first was wondering what all the issues were. Mine still is not bad, but damn this is the worst tranny I have ever owned. Lags with torque converter lockup, laggy 1-2 and 2-3 apshifts and sometime to slams into lower gears on downshifts. If they do a Type-S with this tranny it will be a wasted car. Honestly between the tranny and how pitiful AcuraLink is I don't see myself staying after just returning when this lease is up.
#1007
#1008
I'm puzzled by all the different scenarios that people are having issues. I also have a 8/15 build date like CaliAtenza and I dont have the rough shift. However, the hesitation presents itself at all the wrong times. I'm dealing until my first oil change. Case still opened with NHTSA...
#1009
ACR called my dealership - I have a 12/15 appointment to drive a tech around and bang his head against the headrest over and over again. We'll see what comes of it.
Hey on a possibly unrelated note (and I'll take the conversation to another thread if it's not transmission related), has anyone else experienced a large, sudden drop in MPG? My last two tanks (which spans 500 miles) are a clean 4-5 MPG lower all of a sudden. I'm aware of "winter gas" - I track my mileage with every car and while I do see drops in winter it's 1-2, not 4-5. I did get a noticeable drop of 1-2 MPG after the idle relearn too. Anyone else?
#1010
#1011
#1012
I question wheter that can have the 10 speed ready that soon, I suspect FMC at best before the 10 speed shots up. Not maybe use the 7 speed form the RLX, not sure how that is doing.
#1013
For those claiming that their shifting is smooth, which i know can be subjective, how does your car react when paddle shifting from 2nd to 3rd in sport+ mode? Is it a quick transition or is there still delay and kick?
#1014
#1015
Summer is Coming
#1016
On-line opinions vary, but the consensus is winter gas only makes a 2% difference. You might see a 2 mpg change in a car getting 45 mpg. Ours should be more like 1, which would be very difficult to even detect given other variables have more impact. I'm not buying its the gas - I've tracked MPG for a long time across three different cars. I have a pretty good idea what changes to expect in winter. I'm more suspicious my VCM isn't working. Also, I got a measurable drop after the idle relearn, which happened late summer so gas was a constant. That's why I'm bringing it up here.
#1017
Styl1n
I think any transmission built after 3/15 are good after the updates with acceleration and no lag, I told acr to compare my car to a new build and let me know the difference and if they find a difference they will investigate why and correct the issue. Going in next week Friday for this
#1018
#1019
I'd agree. Why I'm suspicious is it's not cold right now. In fact, my mileage was +4 better when was in the 20's than now when it's in the 40's.
#1021
Got my car back after a week at the dealer with dealer techs working with Acura techline on different updates and procedures (apparently post 15-040 v4). I think they actually made it worse in some scenarios, slightly better in others. Especially when cold the car hesitates for about a count of 2 and then slams into 3rd. Dealer's master-tech was not convinced they had made it better, but Acura wanted me to drive it. Dealer said next step is engaging ACR. I know that will be great fun.
I spent about 20 minutes driving a 2016 again. While not perfect I would say the worst shifts on the 2016 are equivalent to the best shifts on my 2015.
Also found this at Motortrend (2016 SUV of the year contenders):
Land Rover Discovery Sport
We Don’t Like: The turbo lag, confused transmission, cheap interior.
"There’s a nine-speed automatic ZF transmission, but it never knows what gear it wants to be in or how to get to that gear smoothly."
Sounds very familiar. The ZF is just plain bad.
Land Rover Discovery Sport: 2016 Motor Trend SUV of the Year Contender
#1022
Styl1n
When did version 4 come out? And did you feel any difference in throttle and acceleration? How was it worst and better?
They just need to give us new tranny's and and updated software :-)
#1023
UPDATE:
After driving about 200 miles; hwy., & city, combined, this past weekend, some observations:
The REAL LAG seems to be when you accelerate SLOWLY, from a dead stop; (most noticeable)
When you PRESS the accelerator, the lag is somewhat insignificant, & after all the SW updates, after 4th gear, the car's a rocket launcher; great acceleration; almost like a turbo
CONCLUSION: LOVE driving my SH-AWD/TLX, on the highway; city driving, I think confuses the tranny; it's annoying, but not a deal breaker.
Hopefully, an upcoming SW update, will fix the lag permanently; until then, que sera sera
#1024
#1025
UPDATE:
#1026
UPDATE:
#1028
Hey 1Louder; check my post from 11/30th/1:44PM; there, you'll find the only explanation I'm aware of
Good luck!
I've learned through experience, that the dealer Tech, is the bridge to vehicle satisfaction
Good ones are REAL hard to find; like doctors, or any other pro's
Good luck!
#1029
I ended up sending an email to the GM of the dealership I brought the car from in hopes of getting a transmission swap, we'll see where this goes. I honestly don't think any further updates will solve the problem as it seems to be an issue with the transmission itself.
#1030
Styl1n
my car is going in Friday again for some door part replacement, ACR should be contacting the dealer to look at my car as well. i had a long trip this weekend about 300, the car could of performed better it doesn't know what gear it wants to be in and acceleration is crap this really needs to be resolved.
#1031
Taking in my car tomorrow to Cerritos Acura and hoping for a new tranny + a 2016 TLX loaner
Last week I sent an email to the Service Mgr, Service Adviser, my Sales Mgr, and then attached that email to my previous ACR email thread letting them know about the car's issues and touched on some things other owners posted in this thread. I even included the link for them lol.
EDIT: I should note that ACR DCM Tiffany called me once on Nov 25th and I haven't heard from her since. I even called and asked to speak with her but was told she was on the phone. ACR also replied back to my email with the attachment stating that Tiffany will contact me.. yeah right
Anyway I got a call from my the service adviser yesterday and he started off with "my boss forwarded me your email and told me to contact you right away". His attitude was much different from when I brought my car in back in Nov, where he pretty much told me there's nothing that can be done.
I'll report back when things are complete.. *fingers crossed*
#1032
Brought my car in this morning and took the tech for a drive. Shifting in Sport+ mode is the absolute way to go. It's consistent, easily repeatable and the lag followed by the hard shift is undeniable. They called today and said they drove a later build 2015 TLX and said mine was definitely "different" (mine is a January build).
So my car will be at the dealer for several days no doubt as they work with Acura and ACR. I also mentioned how "several people" I know got trannys replaced and were very happy.
#1033
![](https://cimg9.ibsrv.net/gimg/acurazine.com-vbulletin/406x276/oprah_you_get_a_car_d834482da1104008dc94fcfd828e82aeebf47e04.gif)
You get a new transmission! And you get a new transmission! Everyone gets a new transmission! LOL. I am happy that Acura is finally making things right. Hopefully you will be part of the new transmission club soon.
#1034
Oh I wish!
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
#1035
Styl1n
So my car will be at the dealer for several days no doubt as they work with Acura and ACR. I also mentioned how "several people" I know got trannys replaced and were very happy. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
#1036
Edmunds came down pretty hard (again) in their latest long term update.
Awkward Conversations - 2015 Acura TLX SH-AWD Long-Term Road Test
I also have a January 2015 build and it really is frustrating. My service advisor told me my car had the 34 tsb done before I leased it and that should've resolved any issues. He also said that the his computer would tell him whether to perform a further update and it did not.
I'm debating whether to go back and insist more is done.
The following 3 users liked this post by burn1010:
#1037
CTSV,TL, Audi Q7 & A5SB
The following 2 users liked this post by JT4:
9SpeedTran (12-16-2015),
Stew4HD (12-16-2015)
#1038
#1039
I would strongly recommend calling Acura Customer Relations (ACR) and opening a ticket. From what I can tell, this is the only way you can get past a dealership who gives you the "we've done everything the computer tells us to do" story (which is the story I got too). My ACR rep called the service manager at my dealership directly so they didn't have much of a choice but to see me again.
#1040
I dropped off my car this morning and unfortunately they gave me the 2.4 TLX.... for what it's worth, the 2.4, using paddle shifters, is so smooth and there isn't a jolt when shifting at all. Doesn't even feel like you are progressing through gears.
I am definitely going to print this out and take it to Acura when I go to pick-up my car regardless of the work or non-work they do to try to resolve the tranny issue.
