2015 TLX V6 transmission chirp/scrape noise
See YouTube video link below. I hear this noise when accelerating moderately from just under 25 mph, about 60 percent of the time.
Noise can be heard about 10 seconds in, and then again right before the end of the video.
Does anyone else have a V6 that does this?
It sounds like a beep or a scrape. About 8 or so seconds from the beginning and then again right before the end.
Check out TSB 17-027 - Warranty Extension: TLX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer in the 2015 TSB thread.
Check the coolant in the radiator and reserve tank for ATF contamination, although not all cases of cross-contamination are visible and the ATF warmer will require inspection.
https://acurazine.com/forums/fifth-g...letins-914607/
Update:
they are ordering a new, made in 2017 replacement transmission. The first replacement transmission was a rebuilt unit, and they felt it probably didn’t have all the kinks worked out. So, this will be my second new transmission in 16,000 miles.
One4AL (08-02-2019)
Oh wow. So the noise you were hearing was on a re-built tranny? I didn't know that. Good luck. Most people seem to have had good luck with a new transmission, so hopefully you do, too. I'm still running around on the original garbage transmission that came with my 2015 hoping the damn thing tears itself apart. lol.
I have just started experiencing the exact same noise as in your video at the exact same speeds and RPM. 33k miles on a 2015 TLX V6 with SH-AWD. I noted I needed to add coolant to the recovery tank recently when normally not much if any as been needed.
My transmission will be diagnosed next week but I suspect based on the TSB above that there may be cross contamination as well.
I plan on it. My Acura has always been good to work with and they know I am fully aware of the TSB's published on this issue. As in the video the speed and RPM match my experience and that was in the description to my dealer when I called. Thank you for posting.
Ok well step one was checking and replacing the transmission cooler. The original built in 11/2014 passed pressure tests and no cross contamination was found in the Anti-Freeze or Transmission oil. Confirmed with tech when I drove them of the existence of the sound and used the video as an example of te exact symptom. Next step is the Dealer tech will open a tech support ticket with Acura (forwarding the video clip) to see if they can positively identify the issue. I advised them in the video case a new transmission was the cure but we shall see. Initial impressions were something pressure related within the transmission. I could speculate all day on that. At least my dealer is taking the position that they want to follow-up to find the cause and not just ignore it as "don't worry above it". My concerns were are we trending toward a component failure within the transmission or is it something else?
Page 2 of your TSB is crystal clear. It doesn’t get any easier to read than a flow chart. Your coolant and warmer passed. Step 2 is either replace the transmission or, if you had it overheat, replace the engine and transmission. There should be no more diagnostics or disassembly or discussions. You had the problem and caught it on video, thank goodness, or your dealer might give you a hard time about being unable to replicate it.
See, this happened when I went in for the 2-3 hard shift TSB. Thing jerked me around like a Tilt-a-Whirl. Left it with the dealer. Called after an hour saying it felt fine to them. I said try it in stop and go traffic. Called after an hour saying it felt fine to them. I said c’mon guys, how about keep it overnight and try it with cold fluids. Called next morning saying they can’t get snapshots. I said my car does not shift normally and to let the ACC accelerate for you. Called and said oh yeah that is bad and we already ordered your replacement. I know other owners aren’t as lucky as me and still live with the original ZF9 thanks to their dealers.
These TSBs exist to help dealers diagnose common problems described by multiple owners. There should be no beating around the bush. If you experience either the 2-3 hard shift or the 3-4 chirping problem, dealer should go straight to the repair: replace transmission per the TSB. It’s that simple.
Transmission replaced with a 1/2019 build and world of difference. First, the experience of replacement was painless with my dealer. They needed to go drive it get a data snap shot when chirping. It did and Acura said replacement on the way. In the interim I was given a 2019 TLX FWD Advance (mine is a 2015 AWD Advance). The 2019 was smooth as anything compared to my 2015. Never really knew how big a difference until I drove the 2019. My new transmission shifts just as smooth. The first few minutes it acted odd shifting but it was learning and it quickly smoothed out to what I consider a normal shifting pattern. (I drive in Sport mode). Tested all IDS settings and all works as advertised. Even though in my case no transmission/Coolant mixed I still elected to flush the calling system as a precaution.
someguy11 (09-03-2019)
Hey Guys, so I'm taking my Aspec in tomorrow. I have whining and chrips from my transmission between 3-4k rpm while shifting and I noticed harsh up and downshifting and on top of the transmission where the fill plug is located it is dirty with fluid that has leaked. Only have 22k miles on it and I thought the 18’s didn’t have any tranny issue but guess I was wrong lol
Will do. Did they pressure test your atf warmer? I’ve taken the car to a transmission shop so hopefully they do the proper tests on the vehicle
so they replaced your transmission without signs of coolant/transmission fluid contamination? the dealership I took it to said they can’t do anything unless they see contamination which to my understanding could be very hard to see with the naked eye. Just need some insight on what my next move should be. I have it at a transmission shop for them to do the proper tests on the car right now but I’m suspecting the dealership will still try to deny any responsibility unless they physically see the contamination.
I'm hoping acura steps up, the transmision shoudl not go up at 72k miles.
Did the acura step up and cover the new transmission? I'm going through the same thing, the transmission on my 2015 TLX 72k miles has gone up. There was no signs of collant/transmission fluid contamination so acura is pushing back on the extended warranty. My vehicle has the chirping noise and poor shift quallity. I'm also just outside the 70k mile powertrain warranty.
Jim2301 (01-24-2024)
I just had the chirp happen to me, at 112k miles. Thought at first it was belt squeal but then noticed it kept happening at a specific rpm and speed. I put it in sport+ to manually shift and was able to confirm it was only between 3-4 shift. Then I looked at my coolant reservoir and it was dark brown.
I recently had my water pump changed and so I know my coolant was crystal (blue) clear. I will be making an appointment ASAP.
Thanks for the reference to the TSB, it seems pretty straightforward. Temp on the coolant has seemed normal so I think I’m only in line for a new transmission and radiator, not a new engine. I am supposed to be inspected for the recall on the crankshaft. Maybe they’ll just do it all in one go.
