Is the subwoofer on ELS completely underwhelming or is mine broken?
Not sure if you know this or found out already, but turn on DTS Neural and see if that helps. I don't know why the default of this option is set to OFF.
Also, in a couple posts back, I mentioned that my DJ friend said the center channel is over-powering the other channels. He recommended backing it down to -2.
Since the art of sound is a personal taste, I am sure you will find many different opinions. The opinion is also mixed about ANC, but I like leaving it off.
I will add, however, that XM and FM/AM are still "weak" generally in terms of sound. Some channels on XM sound pretty good, tho. And some FM stations as well. I think that's the nature of the beast given the transmission mediums.
Thanks for the suggestions tlxsteve. One of the first things I did after taking delivery was to turn on the DTS Neural setting. For my ears, that made a significant improvement. I also noticed the issue with the center channel (as indicated by your DJ friend) and I dropped it to -3 within the first day or so. I will continue to experiment and hopefully find some ways to make it even better!
I've used the settings you provided for a few days now. Overall, I like the sound with them. I'll keep 'em.
I came from the 4G TL and must say the ELS system rocks. Bass punch was sharp and distinctive. Mids and highs are crisp.
Jumped into the TLX and it feels like an entirely different system. Disappointed to say the least. I tried the ANC off and did improve some. But if it doesn't stay off then it's not an option. Don't need no annoying humming in my ear for 1 min everytime i start the car. I'll try the settings you guys are recommending. Hopefully it can bring back the enjoyment from my 4G TL.
You guys should test out deactivating or unplugging your ANC unit.
I am told by some turning it off in diag mode gets reset when the car is turned off.
But I have the ELS system in my ILX and noticed the system to be very underwhelming as well... though it is still much better than the average 7 speaker non ELS system.
Anyways, I unplugged the ANC unit behind the glove box and now have to turn my treble down because it seems to be too much and my rear view mirror now vibrates visually to the bass which I did not witness before.
Also, per acura, sound quality is better using the HD. However, while listening on a smartphone plugged in or via bluetooth you can change the equalizer far more drastically than your cars system. Turning my media player on my phone to bass+treble makes the bass really noticable in comparison to listening on HD where the sound is crisper but the bass isnt any deeper.
could you give us some instructions on how to do this? Would be much appreciated thanks
I find it interesting that one user has stated that even in his Non ELS his mirror vibrates then people WITH ELS say even with ANC off they CANT get the mirror to vibrate.
People need to get their stories straight.
Not possible for a base level stereo with lower watts can vibrate the mirror where as a better louder system can't... unless your mirrors are attached differently that just doesnt make sense. I figure the guy saying his NON ELS vibrates is mistaken.
All I can provide is the thread I used.
https://acurazine.com/forums/acura-i...estion-905459/
The 9th post has a video where the guy shows what to unplug where. I just used his instructions but I did it without taking the glove box out. After seeing where his plug was I shinned a flashlight back there and saw it. Then reached in blind and unplugged it.
There are a few potential factors required for a reasonable comparison:
- model TLX (base is 7 speaker, Tech+ is 10 speaker - but same bass)
- audio settings
- same audio track and format
There are some tracks that I have that put out tons of bass, and others that are weak. More clean bass is always welcomed, but I am happy overall with my system.
- audio settings
Hi,
To me, the system sounds much better with ANC off... finally. some reasonable bass. Unfortunately the setting does not stick after stopping/starting the car (if I go back into the menu I see that it is on again). From reading the posts it seems that some people think the setting is not being reset like I am experiencing. Is there some trick here that I am missing to permanently commit the change or is there some kind of software version variation between the cars?
Thanks,
Keith
Thanks,
Keith
There is speculation that it is turned on aging by going into the menu, and not by stopping/starting the car. If you cannot tell the difference in actual use then it is all in your head (or your hearing).
I'm pretty sure 99% of the differences of opinion in this thread are explained by differences in how people perceive the placebo effect. Bottom line, the 8" woofer is only moderately powerful, and that's just too bad. Tweaking settings helps a little, as does making sure you have a good audio source. Turning ANC off is, obviously, a trade-off, not a solution. Another similar trade-off would be removing all sound deadening insulation from the trunk --ya, that would likely increase the bass's punch, but it would also increase road noise. Not worth it, IMO.
The only way to "solve" the problem is to buy a real subwoofer.
New ELS System with 10" or 12" Sub for near future?
My suggestion to everyone is report your issues officially. I reported this ANC cancelling Bass issue to my dealer a few weeks ago. At that time, my report which they discussed with Acura corporate was the first official report on this problem. If we want them to fix it, then we have to take the time to report it even if that means being without the car for a few days while they collect data (this is what happened with mine). In the meantime, I am living with ANC off.
Keith
Keith
I have only test driven the TLX 3-4 times, so haven"t noticed a major difference between my TSX ELS, which was 410 watts and the TLX ELS which is 490. I certainly has the crisp clear sound as the TSX. Have you tried DVD-Audio formats in the TLX?
Unlike the typical Bass heavy systems like BOSE and others, the ELS is not designed to be a thumping bass type of sound…rather you hear the instruments as played and the lyrics as sung. My TSX system was significantly superior to the BOSE Centre Point systems found in Infiniti vehicles like the Q50 i have driven. I don't listen to bass heavy music though, so perhaps i am not the best judge. Try classical music and you should notice the quality. I'll have to try listening with the ANC off…but I find it hard to believe they didn't tune the system with the ANC on.
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
darksky
Sep 5, 2015 03:11 AM
