I installed some blue footwell LEDs today (work in progress)
Old 10-05-2014, 12:00 PM
jayb082's Avatar
Since the TLX doesn't come with footwell LEDs, I figured I'd try to install some myself. I bought 2 blue LED strips on eBay (for about $10). The installation was very easy. I was able to power them using the "Parking Light" fuse - #27 and grounded to a nearby metal bolt. By using the parking light fuse, the LEDs turn on with the headlights, when it gets dark. Today I finished the driver's side since that was the easy part. I will do the passenger's side another day (too hot outside). I will splice the wires I used for the passenger side and run them through the bottom of the center stack (I confirmed today this will be easy to do).
Here are some pictures:
WIRING
BEFORE
AFTER
Old 10-05-2014, 02:39 PM
tlxsteve's Avatar
Very nice. It would be nice to see it at night.
You're right. It too hot outside. We need an air-conditioned garage.
I live close by in Sunrise.
Old 10-05-2014, 03:07 PM
jayb082's Avatar
I l1ve close by in Sunrise.
thanks! yea I'll take some night time pictures later. I'll hopefully finish the passenger side sometime this week.
Old 10-05-2014, 08:32 PM
jayb082's Avatar
Here's a much better night shot...
The following 2 users liked this post by jayb082:
Tonyware (10-15-2014), Warrior 6 (11-29-2014)
Old 10-05-2014, 08:57 PM
jayb082's Avatar
they're pretty bright as you can see... Maybe a little too bright. I think I'll cut off 3 LEDs (strip can be cut after every 3 LEDs).
Stew4HD (10-06-2014)
Old 10-05-2014, 09:40 PM
tlxsteve's Avatar
Neat, but yeah a bit bright.
Old 10-06-2014, 08:16 AM
a77
a77's Avatar
Being so bright makes it easier to tell where your feet are, or indeed if you have not left them at home. My TSX has these lights, though they are very dim. I never really understood the point, apart from it being a feature (feeture?) cheaper cars didn't have. Maybe the light should be red - might make your feet fell warmer.. And give the interior that submarine feel.. I sold a Fit once with optional multi-colored LEDs. I think some Fords have this still.
Nice job though!
Old 10-06-2014, 10:06 AM
jayb082's Avatar
Nice job though!
Lol...yea I had a TSX with the dim ones as well, and I installed similar LED strips, which is what inspired me to do the TLX since I was so used to having them. Definitely going to cut a few LEDs off...these are really bright!! Other than that, they look great! Thanks for the feedback.
Old 10-06-2014, 02:39 PM
Alexboculon's Avatar
.... Maybe the light should be red - might make your feet fell warmer.. And give the interior that submarine feel..
Actually, they should be red. Red is the only color that our eyes can easily perceive that does not detract from our night vision by looking at it. That is why tactical flashlights are often red, and why BMW interiors and gauges are all an orange-red color (including BMW's ambient night-time interior lighting).
Acura uses white dials and blue ambient lighting because it seems more techy/futuristic, but the reality is that red makes more sense. It's not a huge deal since we are talking about very dim lights, but you definitely don't want to have bright blue interior lights at night, for safety reasons.
Given the choice between a color designed to actually work better vs a color that just happens to look cool, I'd personally choose what works better every time --but I couldn't afford a new 3-series so here I am.
Old 10-06-2014, 04:10 PM
yaya112's Avatar
Would you please post a link to where you got the LEDs? I really like the matching blue.
Thanks in advance!
Old 10-06-2014, 05:47 PM
jayb082's Avatar
Thanks in advance!
http://pages.ebay.com/link/?nav=item.view&id=200819040219&alt=web
tlxsteve (10-06-2014), yaya112 (10-06-2014)
Old 10-06-2014, 08:08 PM
tlxsteve's Avatar
Curious, How many LEDs will you have in your final cut?
Old 10-07-2014, 07:25 AM
jayb082's Avatar
There's actually 15 LEDs in the 9 inch strip I got...no wonder its so bright! I'll cut 3 and see how that does but will probably end up cutting off 6 in the end.
tlxsteve (10-07-2014)
Old 10-08-2014, 09:49 PM
MedX172's Avatar
Very true! Also the only interior lighting that's safe to use in aircraft at night as well. Even a short burst of standard lighting adversely affects your night flight vision.
Old 10-11-2014, 09:41 PM
jayb082's Avatar
So I made a mistake and cut the led strip while it was plugged in... Then it shut off and now my taillights, license plate lights, door handle LEDs and other "night time" LEDs don't work. I assume I blew a fuse but the question is which one... I checked the parking light fuse I had the led wired to and it looks fine . I even swapped for a new one with no luck. Any one know which fuse controls all this or is it something else?
Old 10-12-2014, 05:36 AM
vbx
vbx's Avatar
Not my cup of tea. But good luck getting that thing fixed.
I would install something more useful like a dashcam.
Old 10-12-2014, 10:29 AM
jayb082's Avatar
OK I found the fuse that covers the night time lights it's called "small". It was blown... Changed it now it's fine. However my DRLs are not working. Headlights and high beams work but not DRLs. Checked all the DRL fuses they're fine. I'm assuming there's another that controls them both like the night time lights... Hmmm...
Old 10-12-2014, 10:50 AM
jayb082's Avatar
nevermind... Parking break was on that's why DRL weren't turning on. Quick check in the manual pointed that out. Glad I ordered the paper manual... So much more convenient! Problem fixed.... Just a simple blown fuse as I expected
Old 10-12-2014, 11:23 AM
tlxsteve's Avatar
Wow! What a scare and learning experience you are having.
How many LEDs did you finally go with and can you post a pic?
Old 10-12-2014, 11:30 AM
jayb082's Avatar
Lol yea. The fuse part I expected but the DRL part had me worried. Luckily just a simple oversight on the parking brake. I cut 3 off... Still have 12... going to check it out when it's dark and go from there. Based on the original brightness I'll probably cut 3 more. I'll post pics once I'm happy with the result.
tlxsteve (10-12-2014), Warrior 6 (11-29-2014)
Old 10-15-2014, 05:09 PM
'20 TLX SH-AWD A-Spec
Tonyware's Avatar
"We built this for ourselves but you can have one too... now guess where we put the fuse box !"
(why the heck did they put the fuse box that low?)
Old 10-16-2014, 12:07 PM
jayb082's Avatar
I ended up sticking with 9 LEDs (I cut 6 off) and I'm happy with the result. It's not as bright...but pictures from my phone don't show the difference, I'll try my DSLR camera when I get a chance. Hopefully this weekend I'll have time to do the passenger side.
Old 10-16-2014, 12:20 PM
tlxsteve's Avatar
Very good. I am curious to see how it looks now.
Old 10-16-2014, 11:56 PM
MedX172's Avatar
It's strange, I wonder why Acura hasn't offered the illuminated foot well option kit for the TLX? I was able to get it in my 2013 Accord Touring.
Old 10-18-2014, 11:03 AM
jayb082's Avatar
mission accomplished!
I finally had time to finish this project today... I connected the passenger side using the same connections... Not hard at all. I just had to move the LED strip a bit since the underside of the dash is more curved on the passenger side... So the LEDs wouldn't be visible when sitting in the rear seats. I'm very happy with the results... Especially since is was relatively easy to do. Here's the final result...
BookemDanole (10-19-2014), NJToyMan (11-20-2014)
Old 10-18-2014, 05:50 PM
tlxsteve's Avatar
WoW. That looks great.
I've been looking forward to your results and pictures.
Personally, I like what I see. How much do you charge for installation?
Sunrise from Weston:
Straight line distance 10.02 mi
Driving distance 15.18 mi
Old 10-18-2014, 07:04 PM
jayb082's Avatar
Thanks!! I'll send you a PM
tlxsteve (10-18-2014)
Old 11-05-2014, 07:48 PM
6th Gear
nonger's Avatar
I plan on installing footwells this weekend. I have a couple of questions. Did you run both the passenger and driver footwell to the same fuse? And I plan on using an add a fuse. Do I just need to use the parking light fuse from the box or do I need to add a different one for the the lights also?
Old 11-05-2014, 07:51 PM
jayb082's Avatar
yes I connected both to the same fuse... The parking light fuse. No need to add another fuse... LEDs are very low power. No issues at all with the way I did it. :-)
Old 11-05-2014, 09:15 PM
6th Gear
nonger's Avatar
Okay thanks. Did you try wiring it so that they would turn on and off with the dome lights? I'm wondering if I could just use the "small" fuse that runs the nighttime lights. Or will I actually have to run wires from the actual dome light to get this affect?
Old 11-06-2014, 07:20 AM
jayb082's Avatar
by connecting to the parking light fuse like I did, they only turn on at night, same as the "small" lights. The small fuse is under the hood. The parking light fuse is way more convenient under the dash.
Old 11-06-2014, 10:34 AM
6th Gear
nonger's Avatar
Ah yeah you're right. I'll just wire a switch into the circuit then.
Old 11-20-2014, 01:29 PM
jayb082's Avatar
Update - After a couple weeks of driving with the LEDs at night, I realized they were still too bright (with 9). I cut off 3 more so now I'm down to 6 and it's PERFECT! Nice blue glow...not too bright and not too dark, just right
NJToyMan (11-20-2014), tlxsteve (11-20-2014)
Old 12-02-2016, 12:12 PM
know610's Avatar
Would you know if 2017 TLX base has the same location of fuse #27 for parking light? Thanks
Old 12-02-2016, 02:22 PM
know610's Avatar
Also, would you recommend fuse tap instead of warping wire to fuse? Or where can I fuse info on fuse label for 2017 TLX base?
Old 08-17-2018, 11:21 AM
natkhat's Avatar
This looks good. I am interested to do similar mod for my 2018 TLX A-SPEC.
Would you share how you transferred the cable from passenger side to driver side?
Old 08-21-2018, 01:08 PM
Temp_A-Spec's Avatar
I think I didnt a write on this as I did red ones on my A-Spec TLX but I tied directly into the light atrip[ on the glove box so the glove box override switch controls them as well as the Dimmer on the cluster. Works as if it was OEM this method and I just used a pair of VLEDS footwell strips as they draw the least and had the highest brightness and color.
Old 09-20-2018, 12:04 PM
natkhat's Avatar
How did you tied each strip, driver and passenger, to glove box switch? do you have a picture or provide some type of a guide?
Thanks in advance.
Old 09-20-2018, 12:51 PM
I just wired the driver side led strip the passenger strip and then ran both wires up the glove box switch and tapped into there. This was I can control them with the switch or the dimmer button on the dash. Worked out great
Old 09-20-2018, 08:44 PM
natkhat's Avatar
This will help. Thank you.
I have 1 more question: you have connected both drive and passenger side LED strip together. So how did you transfer LED strip wire from driver side to passenger side? I just can't find a way to transfer driver side LED strip wire to passenger side so it comes out underneath glove box.
if you can assist with this, it would be great.
Thank you.
Quick Reply: I installed some blue footwell LEDs today (work in progress)
