Thanks for the pictorial... but it leaves the questions as to whether the pictured configuration is immutable!
Also... Should I understand that the V6 has an intermediate stage where 4 cylinders are operative --- but just on "new" productions?
If you read the press release link provided (and I hope you did - it doesn't leave much in the way of questions unanswered - why the exclamation point?) Acura was pretty specific -- while VCM is active, the rear bank is disabled and the front bank left enabled: "During startup, aggressive acceleration, or steep ascents — any time high power output is required — the engine operates on all six cylinders. During moderate-speed cruising and at low or moderate engine loads, the system operates just the front bank of three cylinders.".
Unless their press release intentionally left out info on the possibility of altering which cylinders are disabled, I'd say it's pretty clear cut -- it's the rear bank that's disabled (therefore it's immutable). Given the detail in the release, I doubt Acura left it out.
ps. the graphic I provided shows a 4-cylinder mode -- the TLX does not incorporate this functionality. It's either all 6 cylinders, or the 3 front cylinders. I only provided it to show the the 6 vs the 3 mode; I should have been more specific. I made an assumption it was already known.
