New TLX Competitor
I don't think I've seen actual dimensions but this was stated at the NY auto show.
".... For sports-sedan dynamic capabilities the 2015 TLX is 3.8-inches shorter in overall length than the 2014 TL while maintaining the same wheelbase and tandem (front-to-rear) passenger-seating distance. The TLX’s front and rear overhangs are also shorter by 3.8-inches in total compared to the outgoing TL. The TLX engineers worked diligently to make the TLX lighter, incorporating a wide range of high strength steel and lightweight materials in the design. As an example, the TLX two-wheel-drive with the 3.5-liter V-6 Technology Package model has a curb weight just under 3600 pounds, about 145 pounds lighter than the TL Technology Package model. ...."
I'm not sure they set out to make an enthusiast car. Sure there are a lot of enthusiasts on AZ that want it to be, but it looks like a luxury sport sedan to me. And I think they put more emphasis on luxury than sport. If they do release a Type-S in a few years, that would be the enthusiast car.
That's what I would expect anyway. Acura has gotten much better at ride/handling balance of late, so I expect great handling with a decent ride that will appeal to some luxury buyers.
Actually on the TOV interview they pretty much say the I4 is tuned to be more nimble like the TSX and the SH-AWD does NOT get a stiffer suspension than the FWD version. I am hoping that at least means a Type-S will come eventually.
1) The S60 is around the same size as the now outgoing TSX on interior volume. The trunk is a bit smaller, but not so bad as to be unusable.
2) No way to tell this yet since no one has had independent testing of the TLX. Too early to say for sure.
3) T6 does have an AWD option. It uses the older straight-6 motor at the moment.
People are interested in S60 T6 because it uses a new and powerful 2.0T engine. An AWD S60 with a 10 years old engine is not interesting at all.
Yeah, now that you mention it I remember that bit from the TOV interview. I also hope a dedicated performance variant is in the works, but in the meantime I hope the V6 models have the "medium sport" type of suspension tuning I described.
This is probably about right, but if Acura stays true to the outgoing TL SH-AWD and TSX, the I4 and AWD models will have a tighter base suspensions than the Europeans' base suspensions, and will fall somewhere between BMW's base and sport suspensions. (Actually, the 3 Series sport suspension isn't that tight anymore, and the AWD cars aren't even available with sport suspensions, so the I4 and AWD TLX variants might be very close handling-wise.) So, it might not be a hard core sport sedan, but will be sportier than the base versions of the competition. Perhaps the V6 FWD model will be soft, just like the 4G TL.
One thing I learned from my A6, is I got it without the sport suspension, but added 20 inch wheels which helped the ride a great deal. Hopefully the TLX will have enough of a following that there will be aftermarket parts to help. I am hoping RonJon does a grille which would make this look killer.
I used to have a 2004 S60R... it was an inline 5, turbo. rated at 300hp, 300 lb torque. mine had decent mods and was faster than a stock model. the turbo makes big torque at lower rpms, so it pulls much much harder in lower rpms.. it would easily pull away from our TLs.. even my old 2004 car, when it was stock, woudl blow away my TL...
BUT, that being said, it was not as reliable. also, it's a smaller car, as was said before. the S60 platform is a smaller car, more TSX/3 series in size.
if I was wanting a higher performing euro car, I'd skip the volvo entirely and get a 335i or try to get into an M3. you codlu probably find a nice deal on a CPO M3 wiht the V8 for $50k... i'd take that over a new S60 anyday.
And to be fair, Acura has been using the same basic engine architecture for well over a decade as well. It doesn't mean there weren't advances along the way.
From what I've researched, reliability isn't quite there with Volvo's. And since this thing is both turbo and supercharged that has me worried so I think the S60 is out for me.
The ONE feature I could really use on my 80 mile daily commute is Adaptive Cruise Control. I've seen it in action and its a pretty cool feature to have if you do a lot of highway miles. With that said, it is one feature that should be available on more fuel efficient models.
You CANNOT get ACC on the Honda Accord i4. You can ONLY get it on the Honda Accord Touring which is a V6 or the Accord Hybrid Touring. While the Hybrid is built for fuel efficiency the size of the trunk sucks because of the batteries. Also Accord Hybrid Touring hits $35,000. That's a lot for an Accord.
From what I see, the Acura TLX will have a base and Tech package. Looks like only the Advance package will come with ACC which only comes in V6.
Seriously, Honda what the F**K are you doing? You're forcing me to shop around to other brands.
The Mazda 6 has this feature. I really like the look of the Mazda 6 but the wheels and tires really turn me off on the higher trim Grand Touring models. You're stuck with crappy Dunlop OEM tires and tirerack.com only shows 19 tires available for 225/45-19 so replacing shitty OEM tires with another shitty tire doesn't jive with me. At least Accord and TLX will have plenty of options.
Ford Fusion would be next on my list that's visually appealing with ACC as an option. But I see a lot of complaints from owners that their stated EPA numbers are way off. Especially for their hybrid and turbo models.
Car shopping is so frustrating.
Honda is not alone here and it is frustrating that to get some "premium features" you must buy a larger engine, that makes no sense to me. Audi is the same way, the Prestige packages are only on the V6 cars. I know this is mostly a US thing since we seem to like bigger engines her, but I agree that the TLX I4 in Advance trim would be very appealing to many people. My A6 has ACC and I love it. Just did a 70 mile drive Saturday mostly on ACC set at 70MPH.
It's not just the trim that's the problem here. In order for you to get the ACC option not only do you have to get the less fuel efficient V6 but you also have to get the most expensive model V6 with Advance which drives the cost probably around $45k for the TLX
This is what I'm hoping for. The look of the TLX has grown on me and I'd be willing to give it a shot. However I've become increasingly frustrated with Honda Motor Co.
Yea BMW, Audi, and MB are out for me due to their maintenance costs. I drive too many miles to lease any of them as well. The new 2015 Subaru Legacy due out in a few months looks appealing, AWD with 36mpg but 0-60 at 9 seconds is anemic, that's Prius performance. It too has the Eyesight ACC system. I just dont get it with some manufacturers and their trim/option package selections.
This case of certain options not being available on lower trims is the case across all cars out there, this is not an isolated Acura issue. Audi for example does not allow the sport package at the premium level only at the P+ for example, Mazda CX5 you can only get stick in base trim, etc....etc...etc...
I personally would love to a la carte stuff, and I understand the frustration paying for features you give a crap about and Honda/Acura is certainly worse in this regards, but they do offer a lot more value by doing that, good for some bad for others.
So for me I complain that I want AWD, but nooooo you have to get the top of the line model, I do not want a v6, do not need the tech package, but I want the 2.4 version with AWD, simple as that. BMW/Audi/Merc all offer AWD as stand alone option. Oh well.
What I would LOVE is if they offered a stand alone option of a special order and get 6sp stick.
Many of us would love a 6MT option, and at first I expected to see it on the I4 and V6 SH-AWD models, like we had with the TSX and TL. After watching the Matt Hartgett interviews, however, I'm thinking it's probably destined only for the V6 SH-AWD model, if at all. It seems the torque converter in the I4 model's DCT has a torque magnifying effect, which combined with the 8DCT might offer genuinely strong performance.
With this, the performance gap between 8DCT and 6MT versions of the TLX might be much wider than in most cars (like 6MT v. 8AT in the BMW 3 Series), which would disappoint the enthusiasts among us, who are almost the only ones that would consider a 6MT anyway. This, in turn, could mean a 6MT option wouldn't increase sales as much as usual. If that's the case, why bother?
Pure speculation here, of course, but it does seem like Acura went to great lengths to engineer the 8DCT to maximize performance and efficiency with the I4, so they simply might not see the point of offering MT on that version.
I'm a die hard MT guy myself, but must say I can't wait to try the I4 TLX, and I'm really intrigued by the 8DCT.
It's pretty interesting that there's really no new press about this car. I was interested for a bit when it debuted at the auto shows, but since Acura doesn't seem to be in any hurry to bring it to market, I've really lost interest- putting off the production date guarantees loss of at least some sales, as people will get disillusioned at having to wait to get one and will get something else. I've owned nothing but Hondas and Acuras, but I'm fairly unimpressed at the Acura offerings these days.
I'm not so much getting disillusioned as I am getting suspect of what is wrong with this car. I don't want to be the new owner finding out why it was delayed.
I'm right there with you ... lack of info ... rumors ... delays ... all these things combined aren't exactly a "plus" for Acura.
I am not sure what are causing the delays, and why Acura would not try and provide some information to try and squash the rumor mill. It is getting embarassing for them, seeing teh sales slide, problems rise, delays being more and more frequent. It seems that Honda has given their luxury brand the permission to go loose and create a success story....but forgot to tell them how to do it. Acura just seems unable to get any momentum going. The prototype was amazing and so well received and since then, its been hideous wheels, toned down production (which I am aware that accessories can fix) and delays. Lets not even talk about teh reactive dampers in both the ILX and RDX and the delays in the RLX SH-SH-AWD.....and with no explanations!
Volvo's AWD isn't nearly as good as Acura's, BMW's or Audi's.
It's a FWD that transfers traction to the rear wheels if the front wheels spin.
If you like the driving pleasure of a RWD, or of a good AWD, you could be disapointed.
Even with BMW (DCS I think) and Audi, I think you have to opt for a better package or the AWD system won't be the very best.
At the same time they also dropped the wishbones that were their claim to front end suspension fame.
New Competitor
Talking about new competitor.. I saw the all new 2015 Hyundai Genesis in person yesterday. I must say that car does not look like a typical Hyundai! They definitely step up their game. That car is pretty good looking. So I went on line and did a build up to see how much it would cost. ~50K...
Don't know how it drives but I am pretty impressed by how Hyundai has improved!! Acura... TLX better be a hit otherwise.... I don't know where they will end up..
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
