Couldn't Pump Gas
Team SSM Queen
Couldn't Pump Gas
I went to my usual gas station today but used a pump I hadn't used before. I couldn't get the tank to open to accept the nozzle. I tried different angles but nothing worked. I moved to a different pump and was able to fill the tank. Has anyone else had this happen?
Stay Out Of the Left Lane
There is a 'ring' around the trap door in the filler neck. When you insert the nozzle, it must depress/move this ring to open the trap door. I don't know why some trigger it easier than others, but 90% of the time it's not a problem.
Also, it seems like some nozzles provide such a tight fit that the fuel flow keeps shutting off (as if it the tank were full). I found that pulling the nozzle back 1" helped it to fill more smoothly without kicking off.
Team SSM Queen
I was just wondering if anyone else experienced this. If it happens again I'll take my car over to the dealer.
For you, I'm talking about the segmented ring in front of the hatch/trap door. This ring moves side to side and up-and-down. This ring must be "moved" in order for the hatch to open. Inserting the nozzle normally causes this ring to move and allows the trap door to open. However, if you manage to get the nozzle past the ring and not move it (ie going straight in), it won't allow the door to open because it hasn't been "triggered".
I've only filled up twice since I bought it, once at Chevron and once at Shell and didn't have any issues. I have to confess the cap-less gas tank port is a first for me.
I really need to get this car out on a road trip. It's been almost 4 weeks and I don't even have 500 miles on it.
Team SSM Queen
Maybe this happens when the nozzle is slightly thicker, or the shape is irregular.
I've used other pumps at this station and didn't have this problem, so I'll just avoid this pump going forward.
I've had the same issue 3 times at 2 different stations all on same day. Went to 3th station and nozzle went in with no trouble.
Situation happened late on a Sunday night and not at highly populated area, luckily worked at 3rd station.
IBankMouse
Jun 13, 2020 12:53 PM
