TPMS sensor, suggestions for a replacement?
All,
My tire pressure sensor inside the tire broke and is loose inside the tire--i jacked up the car and can hear it bouncing off the inside walls when i spin the tire.
I found this genuine part on Amazon.
https://www.amazon.com/Acura-42753-T...+42753-TY2-A51
Look correct? Are there better ones that Genuine Acura?
I was going to buy it and have it replaced at my next tire rotate/balance.
I don't mind spending $80 on this, i just want to get the correct one.
Thanks in advance.
Thanks in advance.
Beak14 (05-03-2019)
Yes, the tire stores have generic units that work with our TL. I had one replaced while getting new tires (they busted it installing the new tire). The unit they installed works fine after 11.000+ miles
2013 Acura TL SHAWD on tire rack
Tire Rack sells TPMS (if you want new) working fine for 3 years and counting.
- Part #: 1214 for 2013 Acura TL SH-AWD with Advance Package for 38 dollars per. No problems in 3 years of usage. http://www.tirerack.com/tpms/results.jsp?autoMake=Acura&autoModel=TL+SH-AWD&autoYear=2013&autoModClar=with+Advance+Package
- Make sure you run a search using your car just in case there is a slight different between rims, years or whatever. (I am sure there isnt however no hard in checking)
Laletta Leelee Hunter
08-13-2016 10:00 AM
Blaze9
07-19-2016 03:47 PM
