TPMS question
Old Sep 12, 2012 | 07:02 PM
msubee's Avatar
TPMS question
My front left tire pressure is slightly higher than the other tires. I went to a local tire shop to check it out, the tech says its normal. What do you guys think? Is it normal to have one tire pressure higher than the other?
Old Sep 12, 2012 | 07:41 PM
KarKraze's Avatar
Yes, it is normal,mine vary depending on how long i drive and the time of the day,temp difference etc.
Old Sep 12, 2012 | 08:04 PM
types1fan's Avatar
That's normal, and it's almost impossible to get them to match.
Old Sep 12, 2012 | 08:12 PM
Pseudomaniac's Avatar
If the same tires are always low the day after you even them out....
Old Sep 12, 2012 | 08:24 PM
msubee's Avatar
Thanks for the quick reply guys. I've owned this car for 3 months, the front left tire pressure always higher than the other (approx. 2-3 psi higher). Since yesterday after i brought it to the tire shop, the differences are increased (4-5 psi higher). Should i even them out? or just ignore it?
Old Sep 12, 2012 | 08:37 PM
KarKraze's Avatar
You can try,preferably after the car has cooled down,maybe first thing in the morning.Very difficult for them to stay that way though.
Old Sep 12, 2012 | 09:06 PM
Treblig's Avatar
I'm not sure that wide of a variance is necessarily normal. My gauge reads the same pressure for all four tires and if they vary they don't by more than 1 lb. You may want to check the pressures with a handheld pressure gauge.
Old Sep 12, 2012 | 09:55 PM
LawnPro's Avatar
Scott
You want the front tires to have 35 - 37 psi.
And the rear tires to have 32 - 34 psi.
Check them before you take your first drive and add to the front that is lower then the other.
Old Sep 13, 2012 | 08:55 AM
lji's Avatar
lji
If the readout continues to show 36 psi when a manual reading via a gauge shows 31-32 like the other tires, you might want to have the front right tire TPMS sensor reset. I've seen Discount Tire do this. The dealer may also be an option if the car is under warranty.
I would think variation of 1 psi would be within specs, but not 3-4 psi.
Old Sep 13, 2012 | 08:59 AM
^on the 3G TL, you can tell if the sensor goes bad...
it'll read 58psi.
OP, physically check with a tire gauge.
and add or subtract air if needed.
Remember, its getting cooler.
cooler air contracts.
which will lower the air pressure in the tire.
Old Sep 13, 2012 | 10:15 AM
eazy's Avatar
WDP 4G
36 31 is not normal. cold reading or warmed up. Fill in air and buy a tire pressure gauge to help you get the PSI's even on each side. You can let excess air out of the tpms with the gauge as needed to get your psi's to match
Old Sep 13, 2012 | 10:50 AM
potmilkz's Avatar
yea its not normal..
my psi is always either -1 or +1 off.. but never more than that..
cold weather should read 32psi
hot weather hot weather 37psi
Old Sep 13, 2012 | 05:19 PM
msubee's Avatar
Thanks for the input guys, now the issue have been resolved
Old Sep 14, 2012 | 08:43 AM
ucf_bronco's Avatar
Originally Posted by Treblig
My gauge reads the same pressure for all four tires...
Manual states AWD should have 37 front and 32 rear.
Old Sep 14, 2012 | 09:04 AM
lji's Avatar
lji
^ Owner's manual states 37 psi in the front tires only on vehicles equipped with HPT (High Performance Tires), otherwise it's 32 psi all around.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
johnalfa
Nov 5, 2015 06:44 PM
RobbDizzle
Oct 15, 2015 11:16 AM
