TPM warning
Old Sep 11, 2012 | 07:15 AM
types1fan's Avatar
TPM warning
So this morning I get a TPM warning and it shows my two front tires are blinking on my display. My pressures are reading 30 all around, am I missing something here are they low at 30 or what. When I bought the car they have always set at 30 and now I get a warning, mind you I just had my coils installed last week. I have 2 con conclusions maybe the height drop is throwing them off or the guys that insatalled them fucked up
In some sort of way. I took a look at the tires and they look fine and the ride feels normal, what could it be.
Old Sep 11, 2012 | 07:20 AM
I'm guessing it got a little chilly in the BK this morning.
cooler weather will make the air in your tires contract thus making your tire pressure fluctuate.
Old Sep 11, 2012 | 08:26 AM
types1fan's Avatar
It was a little cool this morning it was 57 in NYC, Ill keep checking it and see what happens.
Old Sep 11, 2012 | 08:29 AM
when the temperature gets cooler, you'll see the tire pressure go down.
by mid day, as it gets warmer, the tire pressure will raise.
I am not sure of the limit on the TPMS for the 4G.
I know on the 3G if the pressure falls below 28psi, it will trigger the warning on the dash.
Old Sep 11, 2012 | 08:47 AM
types1fan's Avatar
Ahh, That was going to be my next Question, How low would it would be in order to trigger the warning. Thank you sir.
Old Sep 11, 2012 | 09:33 AM
Pseudomaniac's Avatar
30?
Crank those puppies up to 35 cold / 37 hot and watch your MPG go way up.
Old Sep 11, 2012 | 12:31 PM
DopeAcura's Avatar
Mine go from 38 cold and 42 warm.
Old Sep 11, 2012 | 12:52 PM
LawnPro's Avatar
Scott
The warning will come on if the tires go, at all below 32 p.s.i.
Old Sep 11, 2012 | 06:42 PM
types1fan's Avatar
Originally Posted by Pseudomaniac
30?
Will do tonight.
that's kind of high I would think cold 32 hot 38?.
Thanks man.
Old Sep 11, 2012 | 09:43 PM
types1fan's Avatar
Problem fixed guys, Raised those pressures up to 36 and no annoying beeping in the the car.
Old Sep 12, 2012 | 07:37 AM
Oswald Vater's Avatar
Just curious - are the psi's different between FWD/AWD? FWD are 33.
Old Sep 12, 2012 | 07:42 AM
^you can always look in your door jamb.
the sticker is displayed there.
and yes, i would think the awd would have a different psi setting.
Also, take in account of which tire you have.
my summer tires dont like anything over 35psi HOT.
I'll start to lose traction
neuronbob
23
Jul 16, 2019 10:48 AM
johnalfa
Nov 5, 2015 06:44 PM
RobbDizzle
Oct 15, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
jmaxima03
Sep 27, 2015 10:22 AM
