Test fitting BBS RG-R 19x8.5 et 32 on base TL
First, let me make this clear, the tires are not the proper size for the TL, so the wheels look tiny on the car!
Specs: 19" x 8.5" BBS RG-R with offset of 32mm.
Tires are 235/35/19 again, not the correct size which should be 245/40/19. Big difference.
Now, the reason I put the wheels on was to see if it would clear the brakes, and not stick out beyond the fenders before I went ahead and ordered tires. Which they don't, so now it's time for some tires.
Looks like with a drop, fender rolling will be required with this offset.
Update. Sorry, been busy with work.
ok, no pictures. ran into a problem
Bought tires, new tpms sensors, and wheels to tire mounters. Had old tires dismounted and had trouble getting the new sensors on.
Basically, the hole for the valve stem is just large enough for the traditional Schroeder valve, but not the valve that Honda uses for TPMS. The BBS comes with nice metal valve stems that are the diameter of a Schroeder valve throughout.
so options are:
run without tpms (live w tire light, or defeat it somehow)
turn tpms valve stem down (not sure if this is possible)
find new valve for tpms (searching this option now, doesn't look too good)
I didn't have the tires mounted for this reason, I guess i should just to get the pics up for some eye candy.
so options are:
Not sure if you want to go this route but I saw a 3pc wheel with a hidden valve stem that the TPMS valve wouldn't fit so they just strap the sensor on the inside of the wheel.
Here it is, Check this link (I hope Ronjon doesn't mind) http://ronjonwheels.com/tpms.html
DunesCreations
09-09-2015 12:03 PM
