springs????
Old Jan 17, 2010 | 03:22 PM
djtanveer's Avatar
springs????
so ive been thinking of lowering my fwd TL and i have a few questions.
first off
if i go with the
Eibach Pro-Kit Performance Lowering Springs
will i have to get camber kits or anything like that?
Also what would i need in addition(if anything) to the springs to lower the car?
and if you guys have any other suggestions.
sorry for the noob questions and thanks
Old Jan 17, 2010 | 03:23 PM
djtanveer's Avatar
heres a link
http://eibach.com/cgi-bin/htmlos.exe...12408800023062
Old Jan 17, 2010 | 10:21 PM
FallenTSX's Avatar
first off
if i go with the
in my experience in modifying imports, lowering a car with just a spring/strut combo will not significantly alter your camber/toe settings. Going to a coilover setup usually requires a camber kit. if you are just swapping the springs, you won't need anything else, but the question is a little vague.
-DeL
Old Jan 19, 2010 | 04:10 PM
djtanveer's Avatar
ok thanks for the reply.. so was wondering if i only replace the springs and not the struts, will i have any problems? bouncy?
Old Jan 19, 2010 | 05:39 PM
BLACKURA_NY's Avatar
I have car ADD
Eibach Pro-Kit should not require an additional camber kit.... you should be able to get your car to stock specifications.
If you add an aftermarket strut kit (i.e, Koni) and you lower the settings more, you may need to get a camber kit, but not likely...
I had my 06 TL lowered about 2.0".. with no camber kit, and my tires got destroyed. My 08 TL-S has lowered 2" also, with a camber kit... no problems
I recommend getting struts eventually, because the sport springs will wear your struts down sooner... its not required, but its a good idea... Also, i dont think they even make any aftermarket struts for our car yet
Old Jan 19, 2010 | 05:52 PM
djtanveer's Avatar
ok thanks for the info.... and just wondering, how much are you currently dropped?
Old Jan 19, 2010 | 06:38 PM
I have car ADD
I am stock height now on my 4G... I have the H&R Springs in my garage (AWD Model only)
Those will drop the car about 1.3F 1.2R.... i plan to install them soon hopefully
Old Jan 20, 2010 | 09:37 AM
FallenTSX's Avatar
you shouldn't have any problems as long as you install it the right way. It won't be bouncy, but will be a little stiffer than your OEM springs. The struts are the ones that makes your car ride stiff or soft.
-DeL
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
