Quick Offset question
Old Dec 1, 2012 | 08:24 AM
Matts_Acura's Avatar
Would 19x10 with a +22 offset fit all around, the hub is 72.6?
Old Dec 1, 2012 | 10:04 AM
Treblig's Avatar
What I do know is that hub size is too big. Standard hub size is 64.1 I believe. Hubcentric rings will be needed. Otherwise, my guess is that that size and offset is going to be quite aggressive and may require fender rolling and camber adjustments, based on what I've read here on the forums.
Old Dec 1, 2012 | 10:37 AM
Thanks for the input. I had thought about 20x10.5 all around but figured 19x10 might be easier to pull off. Good to know about the hub size.
I'm going to lower the car about 1.5 inches also so not sure since its a mild drop if fender rolling will be a must but I don't mind if I have to do it. I definitely don't want the wheels to poke out from the fenders.
Old Dec 1, 2012 | 10:53 AM
Treblig's Avatar
I would wait for more responses to come, particularly from those that have done what you have proposed. I went with 19x8.5 with a +40mm offset, which for my tastes fits perfectly. I can only imagine how much further out the wheels would stick if I had gone with +22. In my opinion +35's were marginal, particularly in the rear, that is why I went with +40's. Consider this, the OEM 19 inch wheels have an offset of 55mm. 19's should definitely make a difference when it comes to lowering however. Good luck.
Old Dec 1, 2012 | 05:25 PM
potmilkz's Avatar
if anything im 20x9.5 +12 and i am required to roll fenders.. so 20x10 will require a fender roll or cut..
my fronts are rolled, my rears are cut..
you will have to run stretched tires as wheels will be sticking out from fender.
Old Dec 2, 2012 | 12:37 PM
FYAH TL's Avatar
Chapter Leader (Northeast Florida)
As mentioned before you'll need hub rings. the +22 offset can work but be prepare to roll fenders to prevent rubbing.
The wheel will stick out pass the fender slightly and all you have to do is camber it in to sit flush or to your liking. so you'll need a camber kit to allow you to do that.
You're still in the safe zone with +22 offset just require some work to make it look good.
BTW going with aggressive offset will only look good if the car is lowered. if you don't plan on lowering the car much stick to the norm of the higher offsets.
Old Dec 2, 2012 | 05:44 PM
Yea after our chat I think I'm gonna pass on those 19's and just go for 20's. Thanks helping me out!
Old Dec 2, 2012 | 05:54 PM
FYAH TL's Avatar
^ The right looking wheel in 20's on the 4G is all win. Hit me up if you need help.
Old Dec 3, 2012 | 05:36 PM
Mr Marco's Avatar
^Your car is a win.
Old Dec 3, 2012 | 09:56 PM
FYAH TL's Avatar
^ Mr Marco thanks Sir. Really appreciate the compliment.
KB1_EJ6
Aug 28, 2016 08:25 AM
BreezyTL
Jul 26, 2016 12:52 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
datadr
Sep 12, 2015 09:12 PM
bailey24
Aug 31, 2015 05:38 PM
