Progress Rear Sway Bar for '09+ TL FWD
Old Oct 5, 2009 | 08:17 PM
Excelerate's Avatar
Former Sponsor
Excelerate Performance is pleased to announce for Progress Auto the release of the new 09+ TL FWD Rear Sway Bar. See below:
The Progress Group, Inc. has developed a new rear anti-sway bar for the new 2009+ Acura TL. This simple upgrade will dramatically improve driver confidence, the handling capability and chassis balance of this awesome new Acura platform.
The 24mm solid steel alloy rear anti-sway bar features two adjustment holes for tuning the chassis balance. The kit includes all necessary hardware for a complete installation including low-deflection polyurethane bushings, brackets, reinforcement plates and special bushing grease. All Progress anti-roll bars are precision-cold formed and manufactured in-house, and feature an attractive dark-gray metallic powder coat finish. The bar is designed to work with the OEM end-links.
We will have these on the website very shortly - they will be around $150 plus shipping!!!
Old Oct 8, 2009 | 01:11 AM
777mycoolangelo's Avatar
Is it pretty easy to install? Just an add on without taking out any existing parts?
Old Oct 8, 2009 | 09:52 AM
Bearcat94's Avatar
AZ Community Team
You have to remove the old bar.
On the 3G, there was a little "trick" where the mounting bolt had a hex cutout in the end of it. You had to hold the bolt with an Allen Wrech when loosening the nut. Not sure if this is the same in the 4G or not.
Other than than, plug and play; easy-peasey.
Old Oct 9, 2009 | 12:37 AM
Grigionic's Avatar
I will definitely be purchasing this haha.....=)
Old Oct 9, 2009 | 09:31 AM
Excelerate's Avatar
Former Sponsor
It is generally pretty straight forward. I haven't installed one yet b/c they haven't been released from production but it should be similar to the other setups which take maybe 30-45 mins to install.
Old Oct 9, 2009 | 12:02 PM
PiMpiN wHITe Cl-S's Avatar
Will they be making one specifically for the AWD or will this works with both models?
Old Oct 12, 2009 | 10:20 AM
Excelerate's Avatar
Former Sponsor
We're hoping it will fit the AWD but if it doesn't I'm going to encourage Progress to manufacture an AWD bar.
Old Oct 21, 2009 | 12:38 PM
Excelerate's Avatar
Former Sponsor
Progress has offered to provide us with one sway bar for a build thread. Anyone with a local FWD 09+ TL that is interested in spending some time on doing a review and having us install the bar please contact us. Progress will provide the bar free of charge and we will install the bar (labor charges will apply); we will take pics of the install but we will require that the consumer write up a review to help promote the new rear sway bar.
Old Jan 20, 2010 | 11:00 PM
Just wondering if anyone got this sway bar installed on FWD and how does it perform?
Old Jan 21, 2010 | 01:49 PM
FAST4DR's Avatar
Also, what is the stock size of the rear sway bar?
Old Jan 21, 2010 | 03:40 PM
PhoenixUnit's Avatar
Whats the difference between the stock one and the progress sway bar? While i was installing mine, i noticed that they look exactly the same and weigh just about the same. I also feel like i haven't really noticed any difference.
Old Jan 22, 2010 | 10:43 AM
Excelerate's Avatar
Former Sponsor
I believe the factory bar is around 19mm; the Progress bar is 24mm and adjustable. It will reduce the body sway and will help neutralize the understeer inherent in the TL.
Old Apr 15, 2012 | 07:29 PM
Strosek's Avatar
Has anyone else tried this sway bar...? I'd be interested if it's actually engineered for the car and actually has proven positive results.
Old Apr 15, 2012 | 07:50 PM
Edward'TLS's Avatar
6G TLX-S
Any aftermarket rear sway bar, that is stiffer than stock, will automatically reduce the understeer tendency of the front-heavy FWD car.
Old Jun 14, 2012 | 12:23 AM
stinkysab's Avatar
Ericccc
Does anyone have a review on the sway bar? Im thinking about buying one.
Old Jun 14, 2012 | 02:36 PM
NwTSXmt's Avatar
Let me c...pay for labor and write a report...uh-no
Old Jul 23, 2012 | 12:52 PM
potmilkz's Avatar
update?
Old Aug 20, 2012 | 06:31 PM
Packagingpro's Avatar
I just ordered one today from Excelerate. Has any one bought this yet? Any reviews. What is the stock Sway Bar Diameter on an AWD and Front Drive TL?
Old Aug 20, 2012 | 06:49 PM
potmilkz's Avatar
i really hope your tl is not a AWD because this sway bar is only for FWD
Old Aug 20, 2012 | 07:06 PM
My TL is front wheel drive! Thanks for looking out! I just found out the sway bar is $20.00 cheaper on the Progress website then Excelerate. Not sure what to do! Kinda pissed!
Old Oct 10, 2012 | 01:15 PM
23109VC's Avatar
any chance that anyone will make a sway bar for the aWD model? I have searched all over and the only sway bar I see on the market for 4th gen TLs is this one, but only for FWD models.
I don't know what the size of the sway bars are for the AWD TLs... but unless they are super thick..I would assume there woudl be room to make them even stiffer and help reduce body roll even more?
any update if a sway bar will come out for the AWD TLs???
Old Oct 10, 2012 | 01:24 PM
potmilkz's Avatar
i think they need a awd for testing to get one made.
so far, there isnt a awd one yet.
Old Mar 4, 2013 | 02:31 PM
leedogg's Avatar
RAR
Excelerate, could you please come out with a reinforcement brace for this sway bar?
The bracket the sway bar is bolted to (seen here) broke off on my car.
Old Mar 4, 2013 | 04:02 PM
Alexander.'s Avatar
^^ wow - reminds me of when the ITR swaybar was fitted onto the rear of integras back in the day and would crack the rear subframe over time, later beaks and another manufacturer created mounting brackets to beef up the mounting points.
Old Mar 4, 2013 | 07:20 PM
Edward'TLS's Avatar
6G TLX-S
I used to have a 2G Integra with the suspension completely modded out. The stock brackets on the thick-ass rear sway bar kept breaking off, and had to be replaced every 9-12 months' of use.
Old Mar 4, 2013 | 07:54 PM
CerberusKy's Avatar
Bring it into any fabricator, and they will weld in a support cheap. If I still lived in DC I would do it for you.
Old Mar 5, 2013 | 02:41 PM
leedogg's Avatar
RAR
Thanks for the advice. Looking around for a good fab shop.
Old Mar 5, 2013 | 03:11 PM
potmilkz's Avatar
damn.. i gotta go check mine when i get home..
Old Mar 5, 2013 | 03:43 PM
Booya4139's Avatar
very common issue on the last gen civic Si's... The extra stiff rear sways needed beefed up brackets... Although i used a progress RSB without reinforncement and it held up fine for me, though i didn't track it or really abuse it either.
Old Mar 5, 2013 | 11:13 PM
Edward'TLS's Avatar
6G TLX-S
You don't need to track the car to break those brackets.
In some cases, when a rear wheel runs over large pot-holes and big bumps, the resulting tension from twisting the thick sway bar is all that it takes to break the bracket(s).
Old Mar 6, 2013 | 12:10 AM
datTeeCK's Avatar
Anyone know who's familiarized in installing this bad boy? :p
Old Mar 6, 2013 | 02:36 AM
potmilkz's Avatar
all you really need is a some sockets with a socket wrench, 2 jackstands, a jack, a drill bit and a drill..
not hard at all
Old Mar 6, 2013 | 09:38 AM
leedogg's Avatar
RAR
FYI, advice from IHC regarding this is to make sure the sway bar is parallel with the ground, not cantered up or down. Adjustable end links should help with this.
Old Mar 6, 2013 | 10:41 AM
potmilkz's Avatar
too bad they dont make it.. i would have bought them
Old Mar 6, 2013 | 10:53 AM
Mr Marco's Avatar
Any good machine/speed shop can fix and reinforce this.
Old Mar 7, 2013 | 11:23 AM
leedogg's Avatar
RAR
http://www.heeltoeauto.com/fastline-...ua6-cg-cm.html
Old Mar 7, 2013 | 12:14 PM
potmilkz's Avatar
list shows that it fits almost all sedan models besides besides ua8..
Old Mar 12, 2013 | 08:52 PM
PeterPort's Avatar
I would definitely be interested in a bar for my AWD 6 mt, which I think leans too much in turns.
Old Mar 12, 2013 | 10:50 PM
23109VC's Avatar
http://store.excelerateperformance.c.../i-285295.aspx
this link says the Progres RSB fits ALL models of TL... does this mean it works on an AWD model? I IM'd one member who has an SH-AWD and says he put it on his car...
it does fit AWD models right???
Old Mar 13, 2013 | 01:08 AM
Edward'TLS's Avatar
6G TLX-S
The AWD TL already has a stiffer/thicker rear OEM sway bar when compared to the FWD TL.
So before swapping it into the AWD TL, make sure that the aftermarket rear one is even stiffer than the AWD OEM rear sway. Otherwise, it's a waste of money and also hurts performance.
