Need help on offset and tire size.
Old Nov 23, 2017 | 02:12 PM
Chrispy225's Avatar
I found some 20x8.5 5x120 et13 wheels. My TL is lowered about 1.7 inches or something like that. I am still learning about offsets on wheels. I was wondering if this would fit my vehicle flush and what size tires would I need? Also does anyone have this size on their ride and could you post pictures? Thanks in advance.
Old Nov 24, 2017 | 11:04 AM
MarcoNorthPolo's Avatar
KCCO
The backspacing on an oem wheel is +55, so those 20’s will stick out 42mm (4.2cm) further than stock (if my understanding is correct.) That’s 1.654 inches, so I would assume they’ll rub like hell on the fender lip unless you roll the fenders. .
Old Nov 29, 2017 | 07:00 PM
Schnitz's Avatar
Check this thread - https://acurazine.com/forums/4g-tl-t...d-pics-898010/
Old Nov 29, 2017 | 07:43 PM
Chrispy225's Avatar
Thank you
Old Nov 30, 2017 | 12:20 AM
carbonTSEX's Avatar
The Original Shawdy
I’m running 20x9 -4 in the front on 235/30 which is skinny and small but have always cleared. I use to be a -1.6 degrees of camber but have been running -2.4 degrees for better clearance since I’m on air. I did run this same setup at 20x9 +16 when I was on coilovers. 20x8.5 +13 is doable.
